板子为STM32F407. 在官网上下载了STMFlashLoader Demo.exe 和 STMFlashLoader.exe。把BOOT0置为1,通过STMFlashLoader Demo.exe可以成功下载程序。出于某些原因需要用命令行的方式。
同样BOOT0置为1. 命令行输入: STMFlashLoader.exe -c --pn 3 --br 115200 --co ON -Rts --Hi -Dtr --Lo -e --all -i STM32F4_05_07_15_17_1024K.STmap -d --a @08000000 --fn monitor.hex --v 但是提示无法擦除,哪位大神知道是什么原因呢?是哪里设置不对么? Opening Port [OK] Set Rts line [OK] Reset Dtr line [OK] the MapFile name is MapSTM32F4_05_07_15_17_1024K.STmap.STmap This version is not intended to support the rget Press any key to continue ... |
15个回答
不设置DTR和RTS后,
Opening Port [OK] ERASING STM32... Enter STBL_ERASE... erasing all pages [KO] the MapFile name is MapSTM32F4_05_07_15_17_1024K.STmap Activating device [OK] DOWNLOADING ... downloading page/sector 0 @0x 8000000 size 16.00(KB) [OK] downloading page/sector 1 @0x 8004000 size 16.00(KB) [OK] downloading page/sector 2 @0x 8008000 size 16.00(KB) [OK] downloading page/sector 3 @0x 800C000 size 16.00(KB) [OK] downloading page/sector 4 @0x 8010000 size 35.63(KB) [OK] disabling read protection [OK] reseting device [OK] 手动复位之后把Boot0置为0,无法启动。文件大小也不对,在window上显示有280KB。 有哪位大神知道嘛? |
发现stam的名字写错了,更改了下。
STMFlashLoader.exe -c --pn 3 --br 115200 --co ON -Rts --Hi -Dtr --Lo -e --all -i STM32F4_05_07_15_17_1024K -d --a @08000000 --fn monitor.hex --v 提示: Opening Port [OK] Set Rts line [OK] Reset Dtr line [OK] the MapFile name is MapSTM32F4_05_07_15_17_1024K.STmap Activating device [KO] No response from the target, the Boot loader can not be started. Please, verify the boot mode configuration, reset your device then try again. Please, reset your device then then press any key to continue |
加上擦除提示擦除失败。Opening Port [OK]
ERASING STM32... Enter STBL_ERASE... erasing all pages [KO] the MapFile name is MapSTM32F4_05_07_15_17_1024K.STmap Activating device [KO] No response from the target, the Boot loader can not be started. Please, verify the boot mode configuration, reset your device then try again. Please, reset your device then then press any key to continue |
学习学习
启动模式配置不正确。
rget 不是提示版本不支持么? |
版本不支持
提示模式配置不正确呀
学习学习
学习学习
提示模式配置不正确呀
第一次看见有人用这个命令行模式,真是学习了。
我的神,这里有高人,我想都没想到这都能做
请问这个问题解决了吗?能具体描述下解决方式吗,目前也在做用命令行升级STM8的程序,但是也遇到了类似的问题。求解答
1999 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1202 浏览 0 评论
2759 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
2534 浏览 3 评论
5216 浏览 0 评论
GMT+8, 2025-1-11 23:26 , Processed in 0.686140 second(s), Total 68, Slave 63 queries .
