嗨,
我刚刚安装了ISE 14.7系统版本,并将System Generator链接到matlab(2014a)。 但是当我尝试打开simulink以使用Xilinx System Generator for DSP blockset时,Matlab命令窗口会显示以下警告: “警告:在”PATH“环境中找不到路径”C: Xilinx2 14.7 ISE_DS ISE bin nt64“。无法在”路径“中找到路径”C: Xilinx2 14.7 ISE_DS ISE lib nt64“ “环境。路径下的库需要使用来自Xilinx System Generator for DSP模块组的模块进行模拟和网表设计。 在“PATH”环境中找不到路径“C: Xilinx2 14.7 ISE_DS PlanAhead bin”。为了确保您的设计按照预期模拟Xilinx模块组和网表,需要使用“Xilinx设计工具 ISE”启动MATLAB 从Windows开始按钮下的所有程序菜单中“设计Suite14.7 System Generator Sysgen Generator”。 这与环境变量设置有关吗? 安装完成后,我运行了批处理文件“settings64”。 在安装指南中,有一个我不太关注的步骤: (安装完成后,安装程序将创建一个环境变量批处理文件。所有相应的桌面和程序组快捷方式在启动目标应用程序之前调用此文件。已创建设置环境的命令行提示符的快捷方式。 位于Xilinx设计工具> ISE Design Suite 14.2>附件> ISE Design Suite 32(或64)位命令提示符。在make或脚本文件中设置环境变量:将 settings32.bat或settings64.bat添加到脚本中。 数字32或64对应于计算机上安装的操作系统的位宽) 也许这一步是导致Matlab警告的关键因素? 任何帮助,将不胜感激! 谢谢, 郑 以上来自于谷歌翻译 以下为原文 Hi, I have just installed ISE 14.7 system edition, and linked System Generator to MATLAB(2014a). But when I try to open simulink to play with Xilinx System Generator for DSP blockset, the Matlab command window shows the following warnings: "Warning: Cannot find path "C:Xilinx214.7ISE_DSISEbinnt64" in "PATH" environment. Cannot find path "C:Xilinx214.7ISE_DSISElibnt64" in "PATH" environment. The libraries under the path are needed to simulate and netlist designs using blocks from Xilinx System Generator for DSP blockset. Cannot find path "C:Xilinx214.7ISE_DSPlanAheadbin" in "PATH" environment. To make sure that your design simulates and netlists with Xilinx blockset as expected it is required that you start MATLAB using "Xilinx Design ToolsISE Design Suite 14.7System GeneratorSysgen Generator" from All Programs menu under Windows Start button." Is this related to environment variable settings? I have run the batch file "settings64" after the installation completed. In the installation guide, there is a step I don' t quite follow: (When installation is complete, the installation program creates an environment variable batch file. All appropriate Desktop and Program Group shortcuts call this file before launching the target application. A shortcut to a command-line prompt which sets the environment has been created. The shortcut is located at Xilinx Design Tools > ISE Design Suite 14.2 > Accessories > ISE Design Suite 32 (or 64) Bit Command Prompt. To set environment variables in make or script files: Add your script. The numbers 32 or 64 corresponds to the bit-width of the operating system installed on the computer) Maybe the step is the critical factor causing the Matlab warnings? Any help would be appreciated! Thanks, Zheng |
你好
从开始菜单打开sysgen,如下面的快照所示,设置将正确应用,并注意到 Matlab R2014a与ISE 14.7不兼容 使用可从以下链接中找到的兼容工具。 http://www.xilinx.com/support/answers/17966.htm 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi Open sysgen from the start menu as shown in snap shot below,the settings will be applied correctly and also note that Matlab R2014a is not compatible with ISE 14.7 Use compatible tools which you can find from the below link. http://www.xilinx.com/support/answers/17966.htm Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
2429 浏览 7 评论
2831 浏览 4 评论
2298 浏览 9 评论
3378 浏览 0 评论
2468 浏览 15 评论
1357浏览 1评论
596浏览 1评论
460浏览 1评论
2013浏览 0评论
738浏览 0评论
GMT+8, 2024-12-29 01:42 , Processed in 1.150468 second(s), Total 46, Slave 40 queries .
