扫一扫,分享给好友
你好,
我购买了kc705开发板/系统。 在我获得开发板之前,我下载了Vivado的评估版并安装在我的Linux服务器上。 通过开发板,我获得了一个用于与电路板一起工作的工具的凭证。 当我去更改许可证时 Vivado从评估到?,似乎我无法改变它并重新颁发新的许可证。 我在开发板上获得的Vivado版本是我下载评估版的几个版本。 我的凭证已进入myprofile。 Willmyvoucheraly给我生成的所有许可证? 我是否必须下载新版本的Vivado才能获得新的许可证? 文档说明我应该在开发板上充分利用Vivado作为设备。 任何建议都会很好。 我试图避免再次下载完整的应用程序... 肯 以上来自于谷歌翻译 以下为原文 Hello, I purchased a kc705 development board / system. Before I got the development board I downloaded an evaluation copy of Vivado and installed in on my Linux server. With the development board I got a voucher for tools for working with the board. When I go to change the license on Vivado from evaluation to ? , it seems I can not change it and re-issue a new license. The Vivado version I got with the development board is several versions behind what I downloaded for evaluation. My voucher has been entered into my profile. Will my voucher apply to all licenses I generate? Do I have to download a new version of Vivado to get a new license generated? The documentation states that I should have full use of Vivado for the device on the development board. Any suggestions would be nice. I am trying to avoid downloading the full applicaiton again ... Ken |
9个回答
嗨,您使用该套件获得了哪个许可证?
它是基于激活还是基于认证的许可证?我们开始从vivado2014.1提供激活许可证。 因此激活许可证可以从vivado 2014.1开始与vivado工具一起使用。 您可以使用的工具版本取决于许可证的版本限制。 有关版本限制的详细信息,请参阅http://www.xilinx.com/support/answers/33770.html您的计算机上安装了哪个版本的vivado工具?谢谢,Deepika。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Which license did you get with the kit? Is it activation based or certification based license? We started delivering activation licenses from vivado2014.1. So the activation license can be used with vivado tools starting from vivado 2014.1. The tool version you can use depends on the version limit of your license. For version limit details refer to http://www.xilinx.com/support/answers/33770.html Which version of vivado tool do you have installed on your machine? Thanks, Deepika.Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
你好肯,
在此处附上您的许可证文件,这有助于我们找到版本限制,您可以使用Vivado等, 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello Ken, Attach your license file here which helps us to find version limit, which Vivado you can use etc., Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
感谢您的答复。
查找附加的当前许可证文件。 我已经加载了Vivado的评估版,因为我不知道何时会有我的开发板。 当sys管理员忙的时候,我在我的工作区安装了vivado。 现在我有了董事会,我们有 下载了Vivado的完整版本。 (我希望我们可以再次避免大量下载)管理员安装它以包含机器上的可信区域。 我想要做的是返回当前的许可证。 (我无法弄明白该怎么办) 获取我的完整产品的新许可证,并看到我可以生成比特流。 我们还没有找到如何申请新的许可证,尽管我离开了我的系统管理员 中间的下载。 我会尝试和他一起申请新的执照 今天早上。 肯 Xilinx.lic 17 KB 以上来自于谷歌翻译 以下为原文 Thank you for the replies. Find attached my current license file. I had loaded up the evaluation copy of Vivado as I did not know when I would have my develompent board. I installed vivado in my working area as the sys admin was busy. Now that I have the board, we have downloaded a full version of Vivado. (I had hoped we could avoid the large download again) The admin installed it to include the trusted area on the machine. What I want to do is to return the current license. (Which I have not been able to figure out how to do) Get a new license for my full product and see that I can generate a bit stream. We have not been able to find out how to request a new license, though I left my sys admin in the middle of the download. I will try and go through the process of requesting a new license with him this morning. Ken |
进一步讨论这个话题。
我正在查看文档,我发现它非常令人困惑。 在套件提供的信息表中,它声明我有权使用ISE Embedded Edition。 (PN:0402916-02信息表) 在网站上:http://www.xilinx.com/products/boards-and-kits/DK-K7-CONN-G.htm它声明我有一个 Vivado设计套件设计版。 那是哪个呢? 我要加载ISE还是Vivado? 这可能就是为什么我不能获得除评估之外的vivado许可证? 肯 以上来自于谷歌翻译 以下为原文 Further on this topic. I am looking over the docs and I find it very confusing. In the info sheets provided by the kit it states I have entitlement to ISE Embedded Edition. (PN: 0402916-02 info sheet) On the web at : http://www.xilinx.com/products/boards-and-kits/DK-K7-CONN-G.htm it states I have a Vivado Design Suite Design Edition. So which is it? Am I to load ISE or Vivado? Could this be why I can not get a vivado license other than evaluation? Ken |
嗨Ken,您可以在Manage License选项卡中删除以前的许可证。
请访问http://www.xilinx.com/cn/support/answers/41885.html要获得新许可证,请联系您获得董事会的经销商.Regards,Sean -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi Ken, You can delete your previous license in the Manage License tab. See http://www.xilinx.com/support/answers/41885.html To get the new license, please contact the distributor from whom you get board. Regards, Sean------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
我还有问题....
有太多的信息需要阅读,似乎我找不到合适的状态。 回顾一下...... 我获得了一些各种工具的评估许可证。 vivado就是其中之一。 我在购买开发之前就做过这个 板。 我们可以通过此评估许可完成一些工作,但它将在12月结束。 我购买了开发板KC-705连接.... 我用其他工具安装了一个新的vivado。 在intall完成之后,我们尝试运行vlm。 我们为“可信区域”许可方法设置了一些东西。 这意味着我正在获得基于激活的许可证? 当我到达产品许可页面“entitlenow ...”时,基于激活的许可证将变为灰色。 我快要去了 并阅读常见问题。 但是从我过去一周发现的情况来看,我很可能没有找到我需要解决的问题 一个简单的问题。 是的,我花了一个星期的时间浏览你的文档,并且还没有在这一点上进一步了解。 能够和真人交谈并在我问他们时回答一些简单的问题会很高兴。 或者甚至更好,有人知道发生了什么,问我几个问题。 但不是每人24小时 谈话方向.... Sckoarn;( 以上来自于谷歌翻译 以下为原文 I still have a problem .... There is so much information to read that it seems I can not find the right statemetns. Just to recap ... I got a few evaluation licenses for various tools. vivado being one of them. I did this before I had purchased a development board. We are able to get some work done with this evaluation license, but it will end begining December. I purchased a development board KC-705 connectivity .... I have installed a new vivado with the rest of our tools. After the intall is complete we try to run vlm. We have set up things for the "trusted area" license method. This means I am getting an activation based license? When I get to the product licensing page "entitlenow..." the activation based licensed are greyed out. I am about to go and read the faq. But from what I have found in the past week, I will most likely NOT find what I need to fix what should be a simple problem. Yes, I have spent a week going over your docs, and have not managed to get any further on this point. It would be nice to be able to talk to a real person and get some simple questions answered as I ask them. Or even better, have someone that knows what is going on, ask me a few questions. But not take a full 24 ours per conversation direction .... Sckoarn ;( |
嗨,
是的,可信存储用于基于激活的许可。 看起来你的许可证是灰色的,这种情况主要发生在三种情况下。 如果用户未通过VLM调用许可证站点。 如果用户使用错误的实用程序,例如访问具有节点锁定许可证请求的许可证站点并且用户具有基于浮动的许可证,则在这种情况下,节点锁定许可证将显示为灰色。 如果未正确安装可信存储。 谢谢,Anusheel ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - - 搜索 在论坛上发布查询之前,与您的设备和工具相关的文档/答案记录。搜索相关论坛并确保您的查询不会重复。 请将帖子标记为“接受为解决方案”,以防它有助于解决您的查询。帮助回答 - >给予赞誉----------------------- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi, Yes, Trusted Storage is used for Activation based licensing. It looks like your license is grayed-out, this condition occurs mainly in three cases.
Anusheel ----------------------------------------------------------------------------------------------- Search for documents/answer records related to your device and tool before posting query on forums. Search related forums and make sure your query is not repeated. Please mark the post as an answer "Accept as solution" in case it helps to resolve your query. Helpful answer -> Give Kudos ----------------------------------------------------------------------------------------------- |
Anusheel,
谢谢你的重播。 我不是系统管理员,我不知道他们为安装工具做了什么。 他们声称他们遵循了指示。 最后,vlm从未允许我将许可证设置为基于激活。 我刚刚删除了我的旧许可证,并重新发布了一个基于节点锁定的新.lic文件。 许可似乎现在正在运行,我很高兴完成这项任务。 Sckoarn;( 以上来自于谷歌翻译 以下为原文 Anusheel, Thank you for the replay. I am not the system admin, and I have no idea what they did to install the Tools. They claim they followed the instructions. In the end, vlm never enabled me to set up the license as activation based. I just deleted my old license and reissued a new .lic file based node locked. The license seems to be working now and I am happy to be finished with this task. Sckoarn ;( |
嗨,
请通过标记帮助您的帖子来关闭主题。 谢谢,Anusheel ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - - 搜索 在论坛上发布查询之前,与您的设备和工具相关的文档/答案记录。搜索相关论坛并确保您的查询不会重复。 请将帖子标记为“接受为解决方案”,以防它有助于解决您的查询。帮助回答 - >给予赞誉----------------------- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi, Please close the thread by marking the post that helped you. Thanks, Anusheel ----------------------------------------------------------------------------------------------- Search for documents/answer records related to your device and tool before posting query on forums. Search related forums and make sure your query is not repeated. Please mark the post as an answer "Accept as solution" in case it helps to resolve your query. Helpful answer -> Give Kudos ----------------------------------------------------------------------------------------------- |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2448浏览 1评论
659浏览 1评论
521浏览 1评论
2075浏览 0评论
801浏览 0评论
GMT+8, 2025-2-24 09:34 , Processed in 1.397455 second(s), Total 90, Slave 74 queries .
