大家好,
我正在使用Ubuntu 14.04 LTS并成功安装了ISE。 我正在研究Zynq所以我需要XPS。 我第一次将许可文件甚至XILINX_LINCENCE_FILE(或类似的东西)变量设置为propper文件夹和文件。 尝试导出到VHDL文件后出错(请参阅attatchment)。 此外,每次我从ISE内部启动XPS时,都会收到“未找到许可证,启动许可证管理器”的错误。 当许可证管理器弹出时,XPS突然在后台解除,一切正常,无需再次设置许可证文件(只需关闭licManager)。 我不知道该怎么办。 有人可以帮忙吗? 问候, G2 [PL] 以上来自于谷歌翻译 以下为原文 Hello everybody, I'm using Ubuntu 14.04 LTS and succesfully installed the ISE. I'm working on Zynq so I need the XPS. For the first time, I've set the licence file and even the XILINX_LINCENCE_FILE (or someting like that) variable to the propper folder and file. I get an error after trying to export to a VHDL file (see attatchment). Furthermore, every time I launch XPS from inside ISE I get an error about 'No licence found, start licence manager'. When the licence manager pops-up, the XPS suddenly unfreazes in the background and everything is ok, without setting the licence file again (just closing the licManager). I don't know what to do. Can anyone help? Regards, G2 [PL] |
6个回答
嗨,
您可以运行以下命令并附加xinfo文件并共享您拥有的许可证文件吗? 信佛 以上来自于谷歌翻译 以下为原文 Hi, Can you run the below command and attach the xinfo file and share the license file that you are having? xinfo |
我不确定我是对的,但它认为这是Vivado 2013.10而不是ISE 14.7许可证。
这是真的? G2 [PL] Xilinx.lic 2 KB xinfo.txt 12 KB 以上来自于谷歌翻译 以下为原文 I'm not sure I'm right but it seams that this is Vivado 2013.10 not ISE 14.7 licence. Is this true? G2 [PL] |
嗨2013.10是您的许可证的版本限制.2013.10表示2013年10月(非Vivado 2013.10).http://www.xilinx.com/support/answers/33770.htmlThanks,Yash
以上来自于谷歌翻译 以下为原文 Hi 2013.10 is version limit of your license. 2013.10 means Oct-2013 (Not Vivado 2013.10). http://www.xilinx.com/support/answers/33770.html Thanks, Yash |
嗨,您的许可证对ISE 14.7有效,但是此许可证被节点锁定到您尝试在不同机器上访问的其他某台机器。您可以检查XINFO HOSTID匹配部分是否为NO.FYI >> UEntu OS不支持ISE。
谢谢,佳日 以上来自于谷歌翻译 以下为原文 Hi, Your license is valid for ISE 14.7 but this license is node locked to some other machine you are trying to access on different machine. You can check that in XINFO HOSTID match section is NO. FYI>> Ubuntu OS is unsupported for ISE. Thanks, Yash |
你好,许可证中有XPS功能,但它被锁定到其他一些机器上。
许可证文件中的Hostid:您系统的10BF48DDAB24Hostid:28d244e87eff您需要迁移到支持的操作系统,您可以在下面的文档第7页上找到http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf然后你 需要按照以下步骤重新托管许可证:http://www.xilinx.com/support/answers/36136.html 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello, The license has XPS feature in it but it is locked to some other machine. Hostid in license file : 10BF48DDAB24 Hostid of your system : 28d244e87eff You need to migrate to supported OS which you can get on page #7 of below document http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf Then you need to rehost the license by following steps in below AR http://www.xilinx.com/support/answers/36136.htmlRegards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨,请通过标记已接受的解决方案关闭此主题,如果您获得了信息。谢谢,Yash
以上来自于谷歌翻译 以下为原文 Hi, Please close this thread by marking accepted solution, if you got the information. Thanks, Yash |
2487 浏览 7 评论
2865 浏览 4 评论
2324 浏览 9 评论
3415 浏览 0 评论
2506 浏览 15 评论
2318浏览 1评论
650浏览 1评论
515浏览 1评论
2063浏览 0评论
791浏览 0评论
GMT+8, 2025-2-13 10:43 , Processed in 1.688047 second(s), Total 85, Slave 69 queries .
