嗨,我用PIC32 MZ2048 EFH144I开发了一个板,尝试使用标准的驾驶板和RJ11 PGC PGD信号使用真正的冰。我使用IPE,但是我不能连接到目标DECICE。在过去,得到了“端点2上的传输失败”,我用成功的MPLAB IDE代替了PIC32 MX器件的IPE。但是MPLAB IDE不重新编译PIC32 MZ家族,然后我跳入IPE,但是这个工具无法识别我的目标设备。我做错了什么?谢谢你,Ricard。
以上来自于百度翻译 以下为原文 Hi, I developed a board with PIC32MZ2048EFH144 I'm trying tu use REAL ICE with standard driverboard and RJ11 PGC PGD signals. I'm using IPE but I'm unable to connect to the target decice. Allyays getting "Transmission on endpoint 2 failed" In the past, I used with success MPLAB IDE instead IPE for Pic32MX devices. But MPLAB IDE don't reconginzes Pic32MZ family and then I swaped to IPE but this tool is unable to recognize my target device. What I'm doing wrong? Thanks in advance, Ricard. |
4个回答
每当我在我的调试器(ICD3或Realice)中有一个“在端点2上传输失败”的问题时,从USB设备断开/重新连接或重新启动计算机通常会为我解决问题。当然是YMMV。我敢肯定这是一个司机/ USB的问题。
以上来自于百度翻译 以下为原文 Whenever I've had this "Transmission on Endpoint 2 failed" problem with any of my debuggers (ICD3 or RealICE), a disconnect/reconnect of the tool from USB or a reboot of the computer has usually fixed it for me. YMMV of course. I'm pretty sure it's a driver/USB issue. |
如果MPLB IDE不承认(诚实地)?-如何创建代码?PIC32 MZ,可能是更新MPLAB的时间。几年后一次。…
以上来自于百度翻译 以下为原文 If the MPLB IDE does not recognize (honestly? - how do you create the code?) the PIC32MZ, it might be time to update MPLAB. Once in a couple of years . . . |
我更新了USB驱动程序,现在IPE重新整理了拖动设备。固件是用MPLAB X IDE 4.0制作的。谢谢您的帮助…RICARD。
以上来自于百度翻译 以下为原文 I updated the USB driver and now IPE recongizes the targed device. Firmware was made with Mplab X IDE 4.0. Thanks for your help... Ricard. |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3104 浏览 3 评论
2175 浏览 5 评论
615浏览 1评论
486浏览 1评论
344浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-21 03:30 , Processed in 1.304945 second(s), Total 50, Slave 45 queries .
