嗨,LoRa RN2903模块配备默认引导加载器吗?如果我们需要定制引导加载程序,是不是有规定?我想我们必须使用MPLAB IDE,在一些内置的引导加载程序中会用到哪里?而且,我们需要有自己的固件,应该在RN2903上运行。有足够的空间来容纳固件代码吗?谢谢,Anish K
以上来自于百度翻译 以下为原文 Hi All, LoRa RN2903 module comes with default boot loader ?. If we need to customize the Boot loader , Is that provision is there ? . I think we have to do using MPLAB IDE where in some built-in BootLoader utility will be there ? . And also , We need to have our own firmware which should run on RN2903 . Is there enough space to accommodate Firmware code ? . Thanks, Anish K |
你好,阿尼什,是的,这里有很多资源可以帮助:RN2903产品页面包括生产固件映像和命令参考用户指南。说到这里,我只看了命令参考指南,看到RN2903版本还没有包含引导加载程序DRCR。引用。取而代之的是RN2443版本,第3章。如果你想遵循一个例子,这里有一个固件更新器,用于在GITHUB上的ARDUINO,以及AlsOWW.Microchip .com /PROVO/8位Bootloader。我建议在启动一个Gen之前,使用上面提到的标准固件映像来运行引导加载程序。用MCC库修改你自己的形象。
以上来自于百度翻译 以下为原文 Hello Anish, Yes, there are lots of resources available to help here: The RN2903 product page includes the production firmware image and command reference users guide. Having said that, I just looked at the command reference guide and see that the RN2903 version doesn't yet include the bootloader description. Instead check out the RN2483 version, Chapter 3. Its the same process. If you want to follow an example, there is a firmware updater implemented for Arduino here at Github, and also www.microchip.com/promo/8-bit-bootloader. I would suggest getting the bootloader working with the standard firmware image mentioned above, before moving on to try an generate your own image with the MCC library. |
5362 浏览 9 评论
2093 浏览 8 评论
1992 浏览 10 评论
3274 浏览 3 评论
2305 浏览 5 评论
870浏览 1评论
758浏览 1评论
699浏览 1评论
750浏览 0评论
644浏览 0评论
GMT+8, 2025-2-24 15:27 , Processed in 1.201462 second(s), Total 44, Slave 39 queries .
