嗨,
Webpack许可证仅支持有限的设备。 Virtex-5 LX110T无法与webpack许可证一起使用。 请在下面的non pageno:8中查看以查看ISE webpack许可证支持的设备。 http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf 以上来自于谷歌翻译 以下为原文 Hi, Webpack license is only supports limited devices. Virtex-5 LX110T is not avaible to use with webpack license. Please check this below irn pageno:8 to see which devices are supported with ISE webpack license. http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf |
TT,
许可证支持是通过您的学校。 联系您的教授或实验室助教。 Austin Lesea首席工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 tt, The license support is through your school. Contact your proffessor or lab teaching assistant. Austin Lesea Principal Engineer Xilinx San Jose |
您好,您可以查看以下链接,了解WebPack License的功能/限制.http://www.xilinx.com/tools/faq.htm
问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello, You can check below link to know features/limitations of WebPack License http://www.xilinx.com/tools/faq.htmRegards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
2308 浏览 7 评论
2718 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
631浏览 1评论
1684浏览 1评论
441浏览 1评论
196浏览 1评论
652浏览 0评论
GMT+8, 2024-9-20 14:29 , Processed in 1.178741 second(s), Total 47, Slave 42 queries .
