我在Mac OS X Yosemite上使用VMWare Fusion创建的Centos 7 64位VM上安装了Vivado 2014.4。
我将VMWare设置设置为2个处理器和4 GB RAM,虚拟磁盘的大小为40 GB。 我以root身份安装了Vivado,因为我无法将其安装到/ opt目录,因为我没有以用户身份登录的权限。 安装完成后,我使用我的用户ID登录并使用以下命令启动Vivado: [user @ localhost~] $ / opt / Xilinx / Vivado / 2014.4 / bin / vivado& ****** Vivado v2014.4(64位)**** SW Build 1071353 on Tue Nov 18 16:47:07 MST 2014 **** IP Build 1070531 on Tue Nov 18 01:10:18 MST 2014 **版权所有1986-2014 Xilinx,Inc。保留所有权利。 start_gui / opt / Xilinx / Vivado / 2014.4 / bin / loader:第123行:25717分段错误(核心转储)“$ RDI_PROG”“$ @” 我尝试以root身份登录,但我仍然遇到同样的错误。 这是我的问题: (1)为什么我会出现这种分段错误? (2)我是否以root身份正确安装? (3)为什么Vivado没有桌面图标? MRI 以上来自于谷歌翻译 以下为原文 I installed Vivado 2014.4 on a Centos 7 64 bit VM created using VMWare Fusion on a Mac OS X Yosemite. I have the VMWare settings set to 2 processors and 4 GB of RAM and the size of the virtual disk is 40 GB. I installed Vivado as root since I could not install it to the /opt directory because I did not have the permissions signed in as a user. After the install, i signed in using my userid and started Vivado using the command: [user@localhost ~]$/opt/Xilinx/Vivado/2014.4/bin/vivado & ****** Vivado v2014.4 (64-bit) **** SW Build 1071353 on Tue Nov 18 16:47:07 MST 2014 **** IP Build 1070531 on Tue Nov 18 01:10:18 MST 2014 ** Copyright 1986-2014 Xilinx, Inc. All Rights Reserved. start_gui /opt/Xilinx/Vivado/2014.4/bin/loader: line 123: 25717 Segmentation fault (core dumped) "$RDI_PROG" "$@" I tried signing in as root, but I still got the same error. Here are my questions: (1) Why am I getting this segmentation fault? (2) Did I do the install correctly as root? (3) Why are there no desktop icons for Vivado? MRI |
你好@mikeiz
首先,我想提一下CentOS 7是一个不受支持的操作系统。 请参阅以下链接中的操作系统部分:http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug973-vivado-release-notes-install-license.pdf -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @mikeiz First of all, I would like to mention that CentOS 7 is an unsupported OS. See the operating system section in the following link: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug973-vivado-release-notes-install-license.pdf -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
一个好的起点是:
ldd /opt/Xilinx/Vivado/2014.4/bin/vivado 寻找缺少或看起来不合适的动态库。 strace -f / opt / Xilinx / Vivado / 2014.4 / bin / vivado 1> /dev/shm/vivado.strace. $$。log 2>& 1 这将向您展示vivado正在做什么 - 或尝试做什么 - 直到它崩溃的程度。 丹尼尔 以上来自于谷歌翻译 以下为原文 A good place to start would be with: ldd /opt/Xilinx/Vivado/2014.4/bin/vivado Look for dynamic libraries that are missing or look out of place. strace -f /opt/Xilinx/Vivado/2014.4/bin/vivado 1>/dev/shm/vivado.strace.$$.log 2>&1 This will show you just what vivado is doing--or trying to do--up to the point where it crashes. Daniel |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2453浏览 1评论
660浏览 1评论
521浏览 1评论
2075浏览 0评论
801浏览 0评论
GMT+8, 2025-2-24 15:56 , Processed in 1.437042 second(s), Total 79, Slave 63 queries .
