你好!
我对LSM303DLHC有疑问。在数据表中,我找不到有关加速度和磁数据输出格式的任何信息。因此我认为它适用于16位值。在使用传感器时,我注意到我得到的加速度数据是错误的。在网上进行一些搜索并进行一些测试后,我发现加速度数据是12位左对齐,磁数据是12位右对齐。我在上面找到的信息:http://www.pololu.com/catalog/product/2124 现在我希望有人能证实我的经历吗?! 问候Oliver Lubritz #accelerometer#lsm303dlhc-data-format #data 以上来自于谷歌翻译 以下为原文 Hello! I have a question about the LSM303DLHC. In the data sheet i can't found any information about the output format for the acceleration and magnetic data. Therefore i thought it works with 16-bit values. While using the sensor I noticed that the acceleration data I get are wrong. After some search in the web and some test I recognized that the acceleration data are 12-bit left-justified and the magnetic data are 12-bit right-justified. The information I found on: http://www.pololu.com/catalog/product/2124 Now I hope anyone can confirm my experience?! Greetings Oliver Lubritz #accelerometer #lsm303dlhc-data-format #data |
你好奥利弗,
是的,您的经验是正确的,磁力计数据是右对齐的,加速度计数据是合理的,在正常模式下,数据是12位表示,这意味着LSB中最低的4位始终为0。在低功耗模式下,数据以8位表示,这意味着只有MSB具有实数,LSB始终为00h。 我希望这能澄清您的问题,并随时发布您想要讨论的任何其他主题。 谢谢, 蒂亚戈雷斯 以上来自于谷歌翻译 以下为原文 Hello Oliver, Yes, your experience is correct, the magnetometer data is right-justified and the accelerometer data is leftâ€�justified, in normal mode, the data is in 12â€�bit representation which means the lowest 4 bit in LSB are always 0s. In low power mode, the data is in 8â€�bit representation which means only MSB has real dataand LSB is always 00h. I hope this clarifies your question, and please feel free to post any other topics that you would like to discuss. Thank you, Thiago Reis |
2877 浏览 1 评论
3282 浏览 1 评论
1861 浏览 1 评论
3710 浏览 6 评论
6124 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
353浏览 2评论
GMT+8, 2025-2-23 12:40 , Processed in 1.124072 second(s), Total 76, Slave 60 queries .
