我正在测试一台发电机,想测试脉冲之间的相位一致性。
第一个脉冲是雷达的发射脉冲。 可以说它的频率为3.1 GHz。 第二个脉冲是接收脉冲,它将以3.0 GHz的频率进入混频器。 假设每个脉冲长度为100微秒,PRI为1毫秒。 如何检查这两个脉冲的相位相干性? 以上来自于谷歌翻译 以下为原文 I'm testing a generator and would like to test the phase coherency between pulses. The first pulse is transmit pulse for the radar. Lets say it has a frequency of 3.1 GHz. The second pulse is the receive pulse which will go to the mixer, at a frequency of 3.0 GHz. Assume each pulse is 100 usec longs, and the PRI is 1 ms. How can I check the phase coherency of these two pulses? |
图片和一些定义可能会有所帮助。
通常相对于标准测量相。 鉴于这两个脉冲可能不重叠,我想看看你在做什么。 我已经对安捷伦示波器进行了雷达脉冲测量,这样做可能需要额外的SW,例如MATLAB或VSA。 免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦威廉希尔官方网站 呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决威廉希尔官方网站 问题的最快方式。 以上来自于谷歌翻译 以下为原文 A picture and some definitions might be helpful. Phase is generally measured relative to a standard. Given that these 2 pulses may not overlap, I'd like to see what you are doing. I have done radar pulse measurements on Agilent scopes, and doing this may require additional SW, such as MATLAB or VSA. Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
1342 浏览 0 评论
2400 浏览 1 评论
2224 浏览 1 评论
2088 浏览 5 评论
2980 浏览 3 评论
1272浏览 1评论
788浏览 0评论
1064浏览 0评论
1342浏览 0评论
GMT+8, 2025-1-23 14:58 , Processed in 1.195812 second(s), Total 75, Slave 59 queries .
