我想绘制扫描系统模拟的结果,其中包含系统参数的几种变化。
当您执行另一个系统分析时,如何防止先前系统分析的结果被删除。 关于保留旧结果,我在图表属性中看不到任何内容。 如何将每个数据集导出为excell或者其他东西。 以上来自于谷歌翻译 以下为原文 I want to plot the results of a swept system simulation with several variations on the system parameters. How do you prevent results from a previous system analysis from being erased when you do another. I don't see anything in graph properties about keeping old results. How do I do this short of exporting each dataset to excell or something. |
我想到了。
为了其他newbs的好处...要在一个图上获得几个模拟的结果,您只需更改每个模拟的数据集名称。 然后,在“常规”选项卡中的一个图形属性中,添加其他模拟的结果。 小心模仿变量名称的行。 从“其他测量”中选择应该是相同的测量结果可能会不可避免地弄乱标尺。 最好输入它们。 以上来自于谷歌翻译 以下为原文 I figured it out. For the benefit of other newbs... To get the results of several simulations on one plot you just change the name of the dataset for each simulation. Then, in the "general" tab one of the graph properties, you add the results of the other simulations. Be careful to mimic the variable name from line to line. Selecting what should be identical measurements from the "other measurements" can irrecoverably screw up the scales. Better to type them in. |
1497 浏览 0 评论
2485 浏览 1 评论
2327 浏览 1 评论
2183 浏览 5 评论
3114 浏览 3 评论
1687浏览 1评论
906浏览 0评论
1498浏览 0评论
GMT+8, 2025-4-14 05:36 , Processed in 1.201032 second(s), Total 76, Slave 60 queries .
