当显示“程序存储器”窗口时,显示标签和变量的符号名。但是大多数可变符号是错误的。这是非常混乱的,而单步执行和试图分析代码。很明显的原因是IDE比较只有7位地址的变量。有没有补救办法?PIC16F1519 MPLAB 8.73
以上来自于百度翻译 以下为原文 When displaying the "Program Memory" window, symbol names of labels and variables are shown. But most of the variable symbols are wrong. This is very confusing while single stepping and trying to analyze the code. The obvious reason is that the IDE compares only 7 bit addresses of variables. Is there any remedy? PIC16F1519 MPLAB 8.73 |
3个回答
没有补救办法。解析器就是这样工作的,并不是那么聪明。;)
以上来自于百度翻译 以下为原文 No remedy. That's how the disassember works; it's not that smart. ;) |
当然,您可以切换到PIC24:),但是为什么不切换到STM32:)我理解DASASMEBLE限制,因为不分析指令的程序流上下文是不可能检测正确的符号的。这在大多数情况下都很容易,但永远不会奏效100%。
以上来自于百度翻译 以下为原文 >> You can switch to PIC24 :) Of course, but why not switch to STM32 :) I understand the disassmebler limitation, because it is impossible to detect the correct symbol without analyzing the program flow context of the instruction. This could be easy in most cases, but would never work 100%. |
5341 浏览 9 评论
2084 浏览 8 评论
1988 浏览 10 评论
3265 浏览 3 评论
2301 浏览 5 评论
846浏览 1评论
741浏览 1评论
683浏览 1评论
739浏览 0评论
630浏览 0评论
GMT+8, 2025-2-12 11:20 , Processed in 1.051816 second(s), Total 48, Slave 43 queries .
