扫一扫,分享给好友
下载vivado 2015.1时出现以下错误
由于您的帐户导出合规性验证失败,我们无法满足您的要求 谁将验证我的数据并允许我下载? 以上来自于谷歌翻译 以下为原文 While downloading vivado 2015.1 I get the following error We cannot fulfill your request as your account has failed export compliance verification Who will verify my data and allow me to download ? |
嗨@ a4speaker,检查此AR。
该AR讨论了原因http://www.xilinx.com/support/answers/44043.html -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 Hi @a4speaker, Check this AR. This AR talks about the reasons http://www.xilinx.com/support/answers/44043.html -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨,填写此表并向客户服务团队提出请求:http://www.xilinx.com/askx/customer_service_form.htm
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Fill this form and raise a request with customer service team: http://www.xilinx.com/askx/customer_service_form.htmThanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
2464 浏览 7 评论
2855 浏览 4 评论
2316 浏览 9 评论
3400 浏览 0 评论
2498 浏览 15 评论
2059浏览 1评论
640浏览 1评论
498浏览 1评论
2047浏览 0评论
776浏览 0评论
GMT+8, 2025-1-29 06:56 , Processed in 0.990311 second(s), Total 44, Slave 39 queries .
