扫一扫,分享给好友
嗨,
我在MacBook Pro视网膜上安装了Ubuntu 14.04 LTS。 问题是,在我安装Vivado 2014.4并尝试获取webpack许可证后,基于激活的许可证是灰色的。 有一次,我可以生成一个,但当我开始下载它chrased,我不能完成程序。 无论我想做什么,例如创建一个新帐户,情况总是一样的。 我还尝试在PC上生成许可证并加载.xml文件,但后来我收到消息“无法将许可证权限加载到可信存储” 我不知道导致问题的原因,我该如何解决? 最好, 杰尼 以上来自于谷歌翻译 以下为原文 Hi, I installed Ubuntu 14.04 LTS on a MacBook Pro retina. The problem is that after I installed Vivado 2014.4 and try to get a webpack license, the activation based licenses are grey. One time I could generate one, but when I started to download it chrased, and I coulnd't finish the procedure. No matter what I'm trying to do, for example create a new account, the situation is always the same. I also tryed to generate a license on a PC and load that .xml file, but then I got the message "unable to load license rights into trusted storage" I don't know what causes the problem, and how should I solve it? Best, Deni |
11个回答
你好
现在使用以下命令生成新请求:xlicclientmgr -cr request1.xml“ref = new” 并打开生成的request1.xml并检查许可证是否仍然是灰色的。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello Now generate the new request using the following command: xlicclientmgr -cr request1.xml "ref=new" And open the generated request1.xml and check whether the licenses are still greyed out. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
你好@molnardeni
Xilinx许可证是节点锁定到计算机的,因此您无法使用为其他计算机生成的许可证。 关于许可证变灰,请查看此答复记录:http://www.xilinx.com/support/answers/61574.html 如果提供的答案记录没有帮助,请尝试以下步骤: 1.使用sudo权限运行脚本:install_fnp.sh(你会在Vivado安装目录中找到它) 2.使用以下命令创建请求:xlicclientmgr -cr request.xml 3.在任何Web浏览器中打开此request.xml。 4.使用您的凭据登录。 现在您将看到许可证不是灰色的。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @molnardeni Xilinx licenses are nodelocked to machine, so you cannot use the license that was generated for other machine. Regarding licenses greyed out, check this answer record: http://www.xilinx.com/support/answers/61574.html If the provided answer record didnt help, try these steps: 1. run the script with sudo permissions: install_fnp.sh (you will find it in Vivado installation directory) 2. Create a request using the command: xlicclientmgr -cr request.xml 3. Open this request.xml in any web browser. 4. Login with your credentials. Now you will observe that the licenses are not greyed out. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
我试过你提到的方法,不幸的是它没有帮助。
我得到了相同的结果。 知道为什么会这样吗? 以上来自于谷歌翻译 以下为原文 I tried the method you mentioned, and unfortunatelly it didn't helped. I got the same result. Any idea why can it happen? |
你好@molnardeni
你能在这里附加生成的request.xml和request.html吗? 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @molnardeni Can you attach the generated request.xml and request.html here? Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨@vuppala
我附上了文件。 如果你知道他们有什么问题,请告诉我。 并告诉我你是否知道如何解决问题。 谢谢, 杰尼 request.html 1 KB request.xml 2 KB 以上来自于谷歌翻译 以下为原文 Hi @vuppala I attached the files. If you know what is wrong with them, please tell me. And also tell me if you know how to solve the problem. Thanks, Deni |
你好Deni,
从附加的文件中可以看出,这些文件没有系统信息。 因此,激活许可证将显示为灰色。 查看此答复记录:http://www.xilinx.com/support/answers/30526.html 根据答案记录,它说“flexlm仅检查eth0接口”。 通过运行以下命令检查接口:ifconfig 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello Deni, From the attached files, it is clear that these files do not have system information. For this reason, the activation licenses are greyed out. Check this answer record: http://www.xilinx.com/support/answers/30526.html As per the answer record, it says " flexlm checks only eth0 interfaces". Check your interfaces by running the command: ifconfig Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
MacBook Pro视网膜模型没有以太网端口,所以我在ifconfig中没有eth0(或任何eth接口)。
以上来自于谷歌翻译 以下为原文 The MacBook Pro retina model doesn't have ethernet port, so I don't have eth0 (or any eth interface) in ifconfig. |
你好Deni,
您可以在运行脚本时共享日志消息:install_fnp.sh? 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello Deni, Can you share the log messages when you run the script: install_fnp.sh? Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
deni @ MacBook-Pro:/opt/Xilinx/Vivado/2014.4/bin/unwrapped/lnx64.o$ sudo ./install_fnp.sh[sudo]密码为deni:从./FNPLicensingService安装锚点服务到/ usr / local / share
/FNP/service64/11.11.0可信存储区域的检查系统...配置Linux,可信存储路径/usr/local/share/macrovision/storage.../usr/local/share/macrovision/storage已经存在.. 。设置/usr/local/share/macrovision/storage...Permissions集的权限...检查复制锚点区域的系统...配置复制锚点区域...复制锚点区域已经存在...设置复制的权限 锚点区域...复制锚点区域权限集...配置临时区域...创建临时区域...设置临时区域权限...临时区域权限设置...配置成功完成.deni @MacBook-Pro: /opt/Xilinx/Vivado/2014.4/bin/unwrapped/lnx64.o$ 以上来自于谷歌翻译 以下为原文 deni@MacBook-Pro:/opt/Xilinx/Vivado/2014.4/bin/unwrapped/lnx64.o$ sudo ./install_fnp.sh [sudo] password for deni: Installing anchor service from ./FNPLicensingService to /usr/local/share/FNP/service64/11.11.0 Checking system for trusted storage area... Configuring for Linux, Trusted Storage path /usr/local/share/macrovision/storage... /usr/local/share/macrovision/storage already exists... Setting permissions on /usr/local/share/macrovision/storage... Permissions set... Checking system for Replicated Anchor area... Configuring Replicated Anchor area... Replicated Anchor area already exists... Setting permissions on Replicated Anchor area... Replicated Anchor area permissions set... Configuring Temporary area... Creating Temporary area... Setting permissions on Temporary area... Temporary area permissions set... Configuration completed successfully. deni@MacBook-Pro:/opt/Xilinx/Vivado/2014.4/bin/unwrapped/lnx64.o$ |
None
以上来自于谷歌翻译 以下为原文 Hello Now generate the new request using the following command: xlicclientmgr -cr request1.xml "ref=new" And open the generated request1.xml and check whether the licenses are still greyed out. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
现在它有效!
:D谢谢! 我按照你的指示,现在它工作,它没有变灰,所以我能够生成许可证xml,下载并在vivado许可证管理器中激活它。 在我遵循你的指示但我现在正在工作的时候,我对我做了什么没有任何线索。 非常感谢你。 你是个天才。 以上来自于谷歌翻译 以下为原文 Now it works! :D Thank you! I followed your instructions, and now it works, it wasn't greyed out, so I was able to generate license xml, download it and activate it in vivado license manager. I don't have any clue on what have I done while I was following your instructions but now it is working. Thank you very much. You are a genius. |
2702 浏览 7 评论
3018 浏览 4 评论
2437 浏览 9 评论
3553 浏览 0 评论
2639 浏览 15 评论
3432浏览 1评论
843浏览 1评论
703浏览 1评论
GMT+8, 2025-7-13 14:15 , Processed in 1.503644 second(s), Total 95, Slave 79 queries .
