扫一扫,分享给好友
嗨,
我尝试在Vivado 2013.4中构建我们的设计并构建Xilinx JESD204B设计示例,我收到以下错误: 错误:[Common 17-69]命令失败:此设计包含不支持比特流生成的内核: i_jesd204_tx_support_block / jesd204_i / inst / i_jesd204_tx(jesd204_txjesd204_v5_1_top) 执行时 “write_bitstream -force jesd204_tx_example_design.bit” 我的许可证经理似乎表明我们的JESD204B核心许可证仍然有效(至少到2013年12月)。 许可证管理器显示IP:Design_Linking许可证为jesd204,版本限制为2013.12,到期日期为永久,许可证类型为Nodelocked,Count为Uncounted,Information为License_Type:Design_Linking; ipman,jesd204,ip,permanent,_0_0_0,文件名为 /opt/Xilinx/Vivado/2013.4/data/ip/core_licenses/Xilinx.lic,主机ID为ANY,主机ID匹配为是,许可CRC为好,搜索顺序为7。 注意:我之前在许可证管理器中有一个条目似乎与版本限制为2013.06的ISE有关,该版本限制在目录/opt/Xilinx/Vivado/2013.4/ids_lite/ISE/coregen/core_licenses/xilinx.lic中。 我删除了这个文件,我不再在许可证管理器中看到JESD204条目了。 许可证服务器上是否有与我看到的许可证版本日期冲突的信息? 我得到的印象是,此错误仅适用于我们没有的模拟许可证。 任何人都可以确认核心是否过期,如何检查? 谢谢, 特雷弗 以上来自于谷歌翻译 以下为原文 Hi, I have tried building our design and building the Xilinx JESD204B design example in Vivado 2013.4 and I get the following error: ERROR: [Common 17-69] Command failed: This design contains a core for which bitstream generation is not supported: i_jesd204_tx_support_block/jesd204_i/inst/i_jesd204_tx (jesd204_txjesd204_v5_1_top) while executing "write_bitstream -force jesd204_tx_example_design.bit" My license manager seems to indicate that our license for the JESD204B core is still valid (at least until December 2013). The license manager shows an IP:Design_Linking license for jesd204, version limit is 2013.12, expiration date is Permanent, License type is Nodelocked, Count is Uncounted, Information is License_Type:Design_Linking;ipman,jesd204,ip,permanent,_0_0_0, File Name is /opt/Xilinx/Vivado/2013.4/data/ip/core_licenses/Xilinx.lic, Host ID is ANY, Host Id Matches is Yes, License CRC is Okay, Search Order is 7. Note: I previously had an entry in the license manager that seemed to relate to ISE that had a version limit of 2013.06 that was in the directory /opt/Xilinx/Vivado/2013.4/ids_lite/ISE/coregen/core_licenses/xilinx.lic. I removed this file and I do not see that JESD204 entry in the license manager any more. Could there be information on the license server that conflicts with the license version dates that I see? I got the impression that this error applies to simulation licenses only which we don't have. Can anybody confirm whether the core is expired, how to check for sure? Thanks, Trevor |
8个回答
链接许可证的设计不允许比特流生成IP。
http://www.xilinx.com/support/answers/42379.htm 您必须使用IP来获取完整许可证。 http://www.xilinx.com/products/intellectual-property/ipaccess_fee.htm -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 A design linking license doesn't allow bitstream generation of the IP. http://www.xilinx.com/support/answers/42379.htm You must purcase the IP for a full license. http://www.xilinx.com/products/intellectual-property/ipaccess_fee.htm ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
嗨格雷斯,
我们购买了IP,根据我们的安富利代表,它将在12月底或1月初到期。 我不确定Vivado 2013.4的官方发布日期是什么,但我想知道我们是否已经出了几周,这就是为什么它不起作用。 我们可以在Vivado 2013.1中构建我们的设计并生成一个没有任何问题的比特流。 (许可证在2013.1中显示IP:Design_Linking。) 我今天注意到的一个奇怪的事情是,在2013.1中,许可证管理器显示的版本限制为2013.03(不是Vivado 2013.4中报告的版本限制= 2013.12),这可以解释IP无法在Vivado 2013.4中运行(如果其发布时间是3月) 。 这对我来说似乎很奇怪,因为我们从服务器检索Vivado 2013.1和2013.4的许可证信息。 (注意:我在Windows平台上尝试过Vivado 2013.1,在Linux上运行2013.4 - 我不确定这是否重要) 谢谢,特雷弗 以上来自于谷歌翻译 以下为原文 Hi Graces, We purchased the IP and it was set to expire at the end of December or early January according to our Avnet rep. I'm not sure what the official release date of Vivado 2013.4 was, but I'm wondering if we are out by a few weeks and that's why it isn't working. We can build our design in Vivado 2013.1 and generate a bitstream still without any issues. (The license shows IP:Design_Linking in 2013.1 as well.) A strange thing I noticed today is that in 2013.1 the license manager shows a version limit of 2013.03 (not version limit=2013.12 as reported in Vivado 2013.4), which would explain the IP not working in Vivado 2013.4 (if its release is past March). This seems really odd to me since we retrieve the license information from a server for both Vivado 2013.1 and 2013.4. (Note: I tried Vivado 2013.1 on a Windows platform and 2013.4 is running on Linux - I'm not sure if that matters) Thanks, Trevor |
如果您购买IP并正确安装许可证,您应该能够看到完整许可证。
以下是完整许可证可用时的许可证状态示例(在IP catelog中,选择JESD204,右键单击并选择“许可证状态”)。 所需的最低版本限制为2013.06。 因此,如果您的许可证于2013年12月到期,则版本限制为2013.12,仍然可以启用此IP。 它是节点锁定许可证吗? 你是怎么安装的? -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 If you purchase the IP and install the license correctly, you should be able to see a full license. Here's an example of license status when a full license is available (in IP catelog, select JESD204, right-click and select 'License Status'). The minimum version limit required is 2013.06. So if your license exprire in December 2013, the version limit would be 2013.12 which still enables this IP. Is it a node locked license? How did you install it? ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
嗨,谢谢你的回复。
我在Vivado中生成了许可证状态并获得以下信息: 我们现在正在尝试生成具有两个核心许可证的比特流。 一个是购买的许可证,将于2013年12月底到期(在许可证管理器中显示为2013.12),另一个是仍然有效的评估许可证。 两种情况都会产生相同的错误。 购买的许可证安装在许可证服务器上,评估许可证是节点锁定的。 当我尝试构建JESD204B核心示例设计时,我得到了相同的错误。 (注意,示例设计是使用共享逻辑生成的)。 谢谢 特雷弗 以上来自于谷歌翻译 以下为原文 Hi thanks for your response. I generated the license status in Vivado and get the following: We now are trying to generate the bitstream with two licenses for the core. One is a bought license that expires at the end of December 2013 (showing as 2013.12 in the license manager) and the other is an evaluation license that is still valid. Both situations generate the same error. The bought license is installed on a license server and the evaluation license is nodelocked. I get the same errors when I try to build the JESD204B core example design. (Note the example design was generated with shared logic). Thanks Trevor |
最可能的原因是原始IP是在没有有效许可证的情况下生成的,现在他们拥有完整的许可证。
您是否在购买了许可证的计算机上构建了示例设计? 如果没有,则需要重新生成IP。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 The most likely cause is that the original IP was generated without a valid license and now that they have a full license. Did you build the example design on a machine with the bought license? If not, you need to regenerate the IP. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
我认为在最初生成JESD核心时未正确安装许可证。
重建核心需要什么? 只需重新生成输出产品或者我需要擦除文件系统吗? 我通过擦除与核心相关的所有文件来对所有组件进行分类去除。 构建现已成功完成。 为了将来参考,刚刚再生核心已经足够了? 感谢你的帮助! 特雷弗 以上来自于谷歌翻译 以下为原文 I think the license was incorrectly installed when the JESD core was originally generated. What is required to regenerate the core? Simply regenerate the output products or do I need to wipe the file system clean? I did the scortched earth removal of all components by wiping all files related to the cores. The build has now completed successfully. For future reference would just regenerating the core have been sufficient? Thanks for all your help! Trevor |
嗨,
每次都不需要重新生成核心。 在生成核心之前,检查IP的许可证状态,如果状态为“Bought”,则无需重新生成IP。 如果在生成核心时,许可证状态为“Design_linking”,则需要在安装购买的许可证后重新生成核心。 谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Regenerating the core is not necessary everytime. Before generating the core, check the license status of the IP and if the status is "Bought", then no need of regenerating the IP is required. If while generating the core, the license status is "Design_linking", then you need to regenerate the core after installing bought license. Thanks -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
只需从弹出菜单中重新生成核心即可。
-------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Simply regenerate the core from the pop-up menu would be fine. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2702 浏览 7 评论
3018 浏览 4 评论
2435 浏览 9 评论
3546 浏览 0 评论
2639 浏览 15 评论
3431浏览 1评论
843浏览 1评论
703浏览 1评论
GMT+8, 2025-7-12 09:04 , Processed in 1.385601 second(s), Total 61, Slave 55 queries .
