扫一扫,分享给好友
Hiteam,
我有一个zedboard和vivado 13.4许可证。 一切都很好,我已经成功实现了一些设计 我调查了adau1761 ADC并试图通过logico axi4lite spdif来提供它 合成和实施成功运行 但是这个问题导致比特流生成失败: 命令失败:此设计包含不支持比特流生成的内核:design_1_i / spdif_0(spdif_v2_0 Version 3) 谢谢你的帮助 以上来自于谷歌翻译 以下为原文 Hiteam, I have a zedboard and vivado 13.4 licence. everything is okay, I have succesfully implemented some designs I investigate adau1761 ADC and try to feed it through logico axi4lite spdif synthesis and implementation run successfully but bitstream generation failed with this issue : Command failed: This design contains a core for which bitstream generation is not supported: design_1_i/spdif_0 (spdif_v2_0 Version 3) thanks for your help |
您还需要SPDIF内核的许可证。
您可以在此处获得硬件评估许可证: http://www.xilinx.com/products/intellectual-property/EF-DI-SPDIF.htm www.xilinx.com 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 You will need a license for the SPDIF core as well. You can get a hardware evaluation license here: http://www.xilinx.com/products/intellectual-property/EF-DI-SPDIF.htm www.xilinx.comView solution in original post |
您还需要SPDIF内核的许可证。
您可以在此处获得硬件评估许可证: http://www.xilinx.com/products/intellectual-property/EF-DI-SPDIF.htm www.xilinx.com 以上来自于谷歌翻译 以下为原文 You will need a license for the SPDIF core as well. You can get a hardware evaluation license here: http://www.xilinx.com/products/intellectual-property/EF-DI-SPDIF.htm www.xilinx.com |
2518 浏览 7 评论
2883 浏览 4 评论
2340 浏览 9 评论
3435 浏览 0 评论
2520 浏览 15 评论
2662浏览 1评论
675浏览 1评论
538浏览 1评论
824浏览 0评论
GMT+8, 2025-3-9 08:51 , Processed in 1.337879 second(s), Total 77, Slave 61 queries .
