您好,我在哪里可以获得有关签证命令(labview)SCPI(如WAV; SOUR; PRE?)的手册,与DSO 7012B一样,有任何有用的文档可以理解这个命令。
谢谢 :) 以上来自于谷歌翻译 以下为原文 Hello, Where do i get a manual with the visa commands(labview) SCPI(such WAV;SOUR;PRE?) as for DSO 7012B ,there are any helpful document to understand this command . thank you :) |
你可以做我完成的事情。
访问www.agilent.com,在右上方的搜索框中输入“DSO7012B”。 在出现的页面上选择“威廉希尔官方网站 支持”,您可以访问:http://www.home.agilent.com/agilent/techSupport.jspx?pid = 1787286& pageMode = OV& cc = US& pl = 选择“手册”,“程序员指南”应在列表中。 您还可以尝试Command Expert,它将指导您完成正确获取命令和语法的过程,并导出应该执行您想要的操作的代码。 有关信息,请访问:http://www.home.agilent.com/en/pd-2036130-pn-E2300/command-expert-11?nid=-33002.992473&cc=US&lc=eng Al免责声明: 要获得更可靠的响应,您应该考虑致电当地的安捷伦威廉希尔官方网站 呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决威廉希尔官方网站 问题的最快方式。 以上来自于谷歌翻译 以下为原文 You could do exactly what I did. Go to www.agilent.com, and type "DSO7012B" in the search box in the upper right. Choose "Technical Support" on the page that comes up, and you should get here: http://www.home.agilent.com/agilent/techSupport.jspx?pid=1787286&pageMode=OV&cc=US&lc=eng Choose "Manuals", and the "Programmers Guide" should be in the list. You could also try Command Expert, which will guide you through the process of getting the commands and syntax right, and export code that should do what you want. Information on that is here: http://www.home.agilent.com/en/pd-2036130-pn-E2300/command-expert-11?nid=-33002.992473&cc=US&lc=eng Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
1327 浏览 0 评论
2394 浏览 1 评论
2213 浏览 1 评论
2084 浏览 5 评论
2971 浏览 3 评论
1223浏览 1评论
781浏览 0评论
1023浏览 0评论
1328浏览 0评论
GMT+8, 2025-1-11 20:18 , Processed in 1.349799 second(s), Total 77, Slave 61 queries .
