嗨,
如果我购买Vivado设计套件2013和ISE系统版2014节点锁定版本,并且在一台机器上安装后,我可以将其安装在另一台机器上吗? 如果没有,我可以从该计算机上卸载它并将其安装在具有该单一许可证的另一台计算机上吗? 等待你的回复。 以上来自于谷歌翻译 以下为原文 Hi, If i buy Vivado design suite 2013 and ISE System edition 2014 node locked version,and after installing in one machine,can I install it in another machine? If not, can I uninstall it from that machine and install it on another machine with that single license? Waiting for your reply. |
5个回答
嗨,ISE和Vivado工具可以安装在N台具有相同下载文件的机器上。注意许可证,你必须使用其他机器hostid信息重新生成许可证才能在其他机器上工作。谢谢
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, ISE and Vivado tools can be installed in N number of machines with the same downloaded files. Regarding license, you have to regenerate the license with other machine hostid information to work on other machine. Thanks-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
如果您希望在多台计算机上使用节点锁定许可证而无需重新生成/重新托管,则可以购买HW-LICENSE-DONGLE-USB-G并为加密狗生成许可证。
这可以从Avnet这里获得 以上来自于谷歌翻译 以下为原文 If you wish to use your node locked license on multiple machines without having to regenerate/rehost you can purchase a HW-LICENSE-DONGLE-USB-G and generate the license to the dongle. This is available from Avnet here |
与此主题相关;
我已经购买了一个节点锁定的Vivado工具,但我还没有生成许可证文件。 现在我决定购买USB-Dongle以在多台机器上使用它,但是需要时间才能使用加密狗。 在此期间,我可以使用具有节点锁定许可证的Vivado(例如,为HDD ID生成),然后当我获得USB加密狗时,我可以将许可证更改为USB Dongle许可证吗? 以上来自于谷歌翻译 以下为原文 Related to this subject; I have already purchased a node-locked Vivado Tool but I haven't generate a license file, yet. And now I have decided to buy a USB-Dongle to use it on multple machines, but it takes time to get dongle. During this time, May I use the Vivado with node-locked license(for example, produced for HDD ID) and then when I get the USB dongle, May I change the license to USB Dongle License? |
嗨,
是的,这是可能的。 您现在可以生成锁定到您的计算机的许可证。 获得加密狗后,您可以在www.xilinx.com/getlicense上修改许可证以定位到加密狗ID。 有关更多详细信息,请参阅http://www.xilinx.com/tools/faq.htm。 以下是相同的快照。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Yes, this is possible. You can generate the license locked to your machine now. Once you get the dongle you can modify the license at www.xilinx.com/getlicense to target to the Dongle ID. Refer to http://www.xilinx.com/tools/faq.htm for more details. Below is a snapshot from the same. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
嗨,
有关将许可证重新托管到加密狗的步骤,请参阅此答复记录:http://www.xilinx.com/support/answers/36136.htm 谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, See this answer record for steps to re-host the license to dongle: http://www.xilinx.com/support/answers/36136.htm Thanks -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
2308 浏览 7 评论
2718 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
631浏览 1评论
1684浏览 1评论
443浏览 1评论
201浏览 1评论
652浏览 0评论
GMT+8, 2024-9-21 04:23 , Processed in 1.031631 second(s), Total 50, Slave 45 queries .
