我已经使用Xilinx设计套件的许可副本近一年了。
今天我收到了错误: 错误:安全:8 - 找到了ISE的功能但已过期。 来自xilinx的人可以帮忙吗? Xilinx不再支持网络摄像头? 这是解决此问题的最合适的位置吗? 谢谢 山姆 以上来自于谷歌翻译 以下为原文 I've been using my licensed copy of Xilinx Design suite for close to a year now. Today I recieved the error: ERROR:Security:8 - A feature for ISE was found but is expired. Can someone from xilinx please help? Xilinx no longer supports the webcases? It this the most appropriate location for me to get this issue resolved? Thanks Sam |
10个回答
嗨,
从输出,它确认在我的帖子中提到的服务器上的问题。 您的系统管理员必须提供帮助。 如果您的系统管理员需要任何帮助,请在此处发布 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, From the output, its confirm that the issue at the server as mentioned in my post. Your system admin has to help. If your system admin needs any help, post here. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
嗨Sam,你升级了你的ISE / Vivado版本吗?如果是的话,版本限制很可能已经过期了新版本.Regards,Krishna
-------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 Hi Sam, Have you upgraded your ISE/Vivado version? If yes, there is a high chance that version limit might have got expired with the new version. Regards, Krishna----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
感谢您的答复,
不,我没有更新我的许可证版本。 我收到了一些关于此的警告信息,我将附加到此消息中 山姆 xilinxLicenseError.txt 3 KB 以上来自于谷歌翻译 以下为原文 Thanks for your response, No I have not updated my license version. I recieved some warning messages about this which Iv'e attached to this message Sam |
你好山姆,
从txt文件看,你看起来像是在14.4 webpack中重新定位XC4VFX20。 请注意,这不是webepack支持的设备。 有关详细信息,请参阅http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_4/irn.pdf的表3-1。 -------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 Hi Sam, From the txt file, it looks like youa re targeting XC4VFX20 in 14.4 webpack. Please note that this is not a supported device with webepack. For details, refer to table 3-1 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_4/irn.pdf ----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
嗨,
从错误消息中的以下行,我怀疑问题是在服务器端。 即,您无法从服务器获取许可证。 FLEXnet Licensing错误:-15,10。 系统错误:10061“WinSock:Connectionrefused” 出现此错误的原因有两个: 1.许可证服务器计算机未运行。 它运行在不同的端口号上。 在ISE命令提示符下运行以下命令并在此处共享输出。 lmutil lmstat -c port_no @ servername 另请与许可服务器管理员联系。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, From the below lines in the error message, I suspect the issue is at server end. i.e., you are unable to get the license from the server. FLEXnet Licensing error:-15,10. System Error: 10061 "WinSock: Connection refused" This error occurs due to two reasons: 1. The license server machine is not running. 2. It is running on a diffrent port number. Run the below command in ISE command prompt and share the output here. lmutil lmstat -c port_no@servername Also contact your license server administrator. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
我拥有此软件的完整许可证,并且根本不使用此软件版本的webpack许可证。
我不知道为什么或如何使用网络包许可证。 我现在正在看我的执照经理,一切看起来都没问题,他们应该看看他们的任何具体信息,试图找出最新情况? 山姆 以上来自于谷歌翻译 以下为原文 I have a full license for this software, and havnt used a webpack license with this software version at all. I don't know why or how it could be using a web-pack license. I'm looking at my license manager now, everything seems to look okay, is their any specific information I should be looking at to try and figure out whats going on? Sam |
嗨,也在这里分享你的xinfo文件。
要生成xinfo,请启动 - >所有程序 - > Xilinx设计工具 - > ISE Design Suite 14.x - >附件 - > Xinfo System Checker.Thanks,Vinay -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Also share your xinfo file here. To generate xinfo, Start --> All Programs --> Xilinx Design Tools --> ISE Design Suite 14.x --> Accessories --> Xinfo System Checker. Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
谢谢vuppala和smarell,
这是输出: 命令> lmutil lmstat -c 2100 @ LS01 lmutil - 版权所有(c)1989-2008 Acresso Software Inc.保留所有权利。 2014年4月21日星期一10:11灵活的许可证管理器状态 [检测lmgrd进程...] 获取状态时出错:无法连接到许可证服务器系统。 (-15,10:10061“WinSock:连接被拒绝”) 被杀的孩子:SIGABRT 我联系了我的系统管理员.. 山姆 以上来自于谷歌翻译 以下为原文 Thanks vuppala and smarell , Here is the output: Command>lmutil lmstat -c 2100@LS01 lmutil - Copyright (c) 1989-2008 Acresso Software Inc. All Rights Reserved. Flexible License Manager status on Mon 4/21/2014 10:11 [Detecting lmgrd processes...] Error getting status: Cannot connect to license server system. (-15,10:10061 "WinSock: Connection refused") child killed: SIGABRT I've contacted my system admin.. Sam |
嗨,
从输出,它确认在我的帖子中提到的服务器上的问题。 您的系统管理员必须提供帮助。 如果您的系统管理员需要任何帮助,请在此处发布 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, From the output, its confirm that the issue at the server as mentioned in my post. Your system admin has to help. If your system admin needs any help, post here. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
2511 浏览 7 评论
2880 浏览 4 评论
2337 浏览 9 评论
3430 浏览 0 评论
2518 浏览 15 评论
2625浏览 1评论
670浏览 1评论
535浏览 1评论
821浏览 0评论
GMT+8, 2025-3-6 12:45 , Processed in 1.503261 second(s), Total 95, Slave 79 queries .
