扫一扫,分享给好友
我将Vivado下载到Windows 7笔记本电脑上。
Vivado和许可证加载正常,但Vivado加载到所有者帐户,而不是我的帐户,没有什么大不了我可以在那里运行它。 我需要ISE webpack所以我将其加载到不同的目录中。 快捷方式出现在我的帐户和所有者帐户中。 当我尝试加载发送给我的ISE webpack的许可证文件时,我收到错误消息: 无法将许可权限加载到受信任文件中。 我尝试从两个帐户加载许可文件并获得相同的错误消息。 当我在网站上查找许可证时,会显示一个带有过期时间的选择Petal Linux。 这两个程序是否允许在同一台机器上? 如何修复许可证问题? 约翰 以上来自于谷歌翻译 以下为原文 I downloaded Vivado to a windows 7 laptop. Vivado and the license loaded fine but Vivado loaded into the owner account, not my account, no big deal I can run it there. I needed ISE webpack so I loaded that into a different directory. The shortcut came up in my account and the owner account. When I try to load the license file sent to me for ISE webpack I get the error message: Unable to load license rights into trusted file. I tried loading the license file from both accounts and get the same error message. When I look for the license on the website it displays a selection Petal Linux with an expiration time. Are both programs allowed on the same machine? How do I fix the license problem? John |
12个回答
你好约翰,
第一个许可证是ISE Webpack,仅与ISE一起使用。 (基于证书的许可证) 第二个许可证是Vivado Webpack许可证,与Vivado一起使用。 (基于激活的许可证) 让我知道您使用的是哪种工具? ISE或Vivado。 取决于我们可以提供安装这些许可证的步骤吗? 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello John, The first license is ISE Webpack and used with ISE only. (Certificate based license) The second license is Vivado Webpack license and used with Vivado. (Activation based license) Let me know which tool are you using? ISE or Vivado. Depends on that we can provide the steps to install these licenses? Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
你好,约翰,
使用管理员权限打开Vivado License Manager并尝试加载许可证文件。 如果仍然收到相同的错误消息,请从命令提示符中的location bin运行以下命令:xlicclientmgr -p License.xml 另请在此处附上yoru许可证文件。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi John, Open Vivado License Manager with administrator privileges and try loading the license file. If you still get the same error message, run the following command from the location Also attach yoru license file here. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
我得到的是“xlicclientmgr不被识别为内部或外部命令,程序或批处理文件”
我从 bin和 bin目录中尝试了它。 以上来自于谷歌翻译 以下为原文 What I get is "xlicclientmgr is not recognized as an internal or external command, program or batch file" I tried it from both the the |
嗨,
你能在 bin位置看到xlicclientmgr.exe吗? 如果您没有找到此.exe,请从http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2014-2.html下载许可证管理工具。 解压缩已下载的.zip并运行命令:xlicclientmgr -p License.xml 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Are you able to see xlicclientmgr.exe in the If you are not finding this .exe, download license management tools from http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2014-2.html Extract the downloaded.zip and run the command: xlicclientmgr -p License.xml Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,转到安装和许可板。
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Moving to Installation and Licensing board.Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我返回了许可证,卸载了所有内容,然后只加载了ISE Web Pack。
许可证管理器第一次运行它以加载许可证。 当我运行应用程序时,它告诉我我没有许可证,当我尝试加载我最初加载的那个时失败。 和之前一样。 我运行了你告诉我的许可证管理器,我得到了错误:无法找到FNP安全运行时共享对象 我可以模拟一个文件,但不能florplan,我看到有关未找到以下键值的错误消息。 我在注册表中查找了XILINXD_LICENSE_FILE并将C:/ xilinx作为值 当我寻找LM_LICENSE_FILE它不存在。 我接下来应该尝试什么? 以上来自于谷歌翻译 以下为原文 I returned the licenses, uninstalled everything and then only loaded the ISE Web Pack. The first time the license manager runs it apears to load the license ok. When I run the application it tells me I don't have a license and fails when I try to load the one I originally loaded. Same as before. I ran the license manager you told me to and I got the Error: Unable to find FNP security runtime shared object I can simulate a file but can't florplan, I saw the error message about not finding values for the following keys. I looked in the registry for XILINXD_LICENSE_FILE and got C:/xilinx as a value when I looked for LM_LICENSE_FILE it didn't exist. What should I try next? |
嗨,xlicsrvrmgr.exe / xlicclientmgr.exe需要FNP安全运行时共享对象。解决方法:设置PATH = C: Tools Vivado 2014.1 lib win64.o如果您仍然遇到任何许可问题,请分享错误消息,版本
您正在使用的Vivado / ISE?还附上您的许可证文件。谢谢,Vinay -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, xlicsrvrmgr.exe/xlicclientmgr.exe requires FNP security runtime shared object. Solution: set PATH=C:ToolsVivado2014.1libwin64.o If you still face any issues with licensing, share the error message, version of Vivado/ISE you are using? And also attach your license file here. Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,
激活许可证无法在ISE上运行! 如果您只想在ISE上使用WebPack许可证,则可以使用基于证书的许可证,文件扩展名为.lic。 肖恩 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi, Activation licenses cannot run on ISE! If you just want to use WebPack license on ISE, you can use a certification based license with file extension of .lic. Sean ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
肖恩,
我有证书许可证和节点锁定的许可证。 我第一次尝试设置证书时安装了证书lic。 这里是: #此许可证的有效期为2014年6月11日星期三03:42:31 UTC。##这是许可NODELOCKED到HOSTID = 96dfd7e0;#没有必要为此许可证运行lmgrd。###这是一个永久许可证 Wed Jun 11 03:42:31 UTC 2014INCREMENT ISE_WebPACK xilinxd 2015.06永久不计数 F7E4511A28FE VENDOR_STRING = jperkins537,ISE_WebPACK,软件,永久,_210909367_0_0_346 HOSTID = DISK_SERIAL_NUM = 96dfd7e0 ISSUER =“Xilinx Inc” START = 2014年6月11日TS_OK ### ----------------------------------------------- -----------------------#以下PACKAGE定义是此许可证的必需部分:#PACKAGE ISE_WebPACK xilinxd 2015.06 620DB5EEAA32 COMPONENTS =“SDK xps_tdp XC7Z010 WebPACK XC7Z020 XC7Z030 PlanAhead“ OPTIONS = SUITE# 这是节点锁定许可证 66COMPOSITE8323795674BA16A69D2828311874D8D182B8D61AA149881C1F26DBB76D0E9B90BF0DABC4E08BBBC49D22906FF41E01CB0F94B5F8FB3A7D58A110DB4FD873411211444519fulfillmentType6expirypermanentfulfillmentIdChainFIL-E0actServerChainServer1serverHostIDFLEXID = 9- a6300156servOrLocal2productId209855574entitlementIdfeaturesINCREMENT Vivado_WebPACK xilinxd 2015.06永久9999 0219FFDED6CF VENDOR_STRING = TRUSTED_STORAGE,jperkins537,Vivado_WebPACK,软件,永久的,_210909367_0_0_009 ISSUER = “赛灵思公司” START = 26君2014 TS_OKPACKAGE Vivado_WebPACK xilinxd 2015.06 F40FC03D7EC0 COMPONENTS =“SDK V_WebPACK“OPTIONS = SUITECOMMENTThis激活许可证文件生成于星期六6月27日00:35:40 UTC 2014116735B37F9935F088DF0E531CD1650E30D8A064982831D2008E4850CD8551BD56D2584622CE4915C2C576A07B6DDB2EFD2E915515ED9C6AE405FBB143 我如何理顺这个烂摊子? 约翰 以上来自于谷歌翻译 以下为原文 Sean, I have the certificate license and the node locked ones. The certificate lic was installed the first time I tried to set this up. here it is: # This license is valid from Wed Jun 11 03:42:31 UTC 2014. # # This is license NODELOCKED to HOSTID=96dfd7e0; # there is no need to run lmgrd for this license. # # # This is a permanent license generated on Wed Jun 11 03:42:31 UTC 2014 INCREMENT ISE_WebPACK xilinxd 2015.06 permanent uncounted F7E4511A28FE VENDOR_STRING=jperkins537,ISE_WebPACK,software,permanent,_210909367_0_0_346 HOSTID=DISK_SERIAL_NUM=96dfd7e0 ISSUER="Xilinx Inc" START=11-Jun-2014 TS_OK # # # ---------------------------------------------------------------------- # The following PACKAGE definition is a REQUIRED part of this license: # PACKAGE ISE_WebPACK xilinxd 2015.06 620DB5EEAA32 COMPONENTS="SDK xps_tdp XC7Z010 WebPACK XC7Z020 XC7Z030 PlanAhead" OPTIONS=SUITE # Here is the node locked license VENDOR_STRING=TRUSTED_STORAGE,jperkins537,Vivado_WebPACK,software,permanent,_210909367_0_0_009 ISSUER="Xilinx Inc" START=26-Jun-2014 TS_OK PACKAGE Vivado_WebPACK xilinxd 2015.06 F40FC03D7EC0 COMPONENTS="SDK V_WebPACK" OPTIONS=SUITE How do I straighten this mess out? John |
你好约翰,
第一个许可证是ISE Webpack,仅与ISE一起使用。 (基于证书的许可证) 第二个许可证是Vivado Webpack许可证,与Vivado一起使用。 (基于激活的许可证) 让我知道您使用的是哪种工具? ISE或Vivado。 取决于我们可以提供安装这些许可证的步骤吗? 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello John, The first license is ISE Webpack and used with ISE only. (Certificate based license) The second license is Vivado Webpack license and used with Vivado. (Activation based license) Let me know which tool are you using? ISE or Vivado. Depends on that we can provide the steps to install these licenses? Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
谢谢肖恩,
我去了许可站点并重新获得了证书许可证。 一个新的发送给我。 Web包现在可以工作了。 约翰 以上来自于谷歌翻译 以下为原文 Thanks Sean, I went to the licensing site and resurected the certificate license. A new one was sent to me. The Web pack now works. John |
2281 浏览 7 评论
2694 浏览 4 评论
2176 浏览 9 评论
3250 浏览 0 评论
2321 浏览 15 评论
582浏览 1评论
1650浏览 1评论
145浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2299浏览 0评论
612浏览 0评论
GMT+8, 2024-8-24 08:52 , Processed in 1.346813 second(s), Total 100, Slave 84 queries .
