你好,
我已经与FX3 UART接口工作了一段时间。我尝试通过两个板在字节模式下与UTAC接口通信,超时1秒。我一直在为此尝试许多工作案例。一个这样的情况是,发射机将在一秒钟之后发送数据(作为数据1),从而接收机将返回超时错误。但是下一次当接收方尝试从发送器接收数据DATA2时(使用CYU3PUARTRAVER BYTESH()),它需要以前发送的DATA1。我认为DATA1存储在UART接口的FIFO中。在超时错误之后,每当我调用CyU3PuaTeCuffBySee()时,是否有一种方法来清除UART FIFO或UART入口数据寄存器???? 提前感谢, 当做, Ashlin Surey。一 以上来自于百度翻译 以下为原文 Hi, I have been working with the FX3 UART interface for a while. I am trying to communicate between two boards through UART interface in BYTE MODE with a timeout of 1 second. I have been trying many work cases for this. One such case is that, the transmitter will transmit data(take as data1) after one second so that the receiver will return a TIMEOUT ERROR. But the next time when the receiver tries to receive data2 from the transmitter(using CyU3PUartReceiveBytes() ) , it takes the data1 which was send before. I think that the data1 gets stored in the FIFO of the UART interface. Is there a way to clear the UART FIFO or the UART ingress data register as I get previous state values whenever I call the CyU3PUartReceiveBytes() after a timeout error???Thanks in Advance, Regards, Ashlin Surey. A |
760个成员聚集在这个小组
加入小组2156 浏览 1 评论
1904 浏览 1 评论
3726 浏览 1 评论
1837 浏览 6 评论
1582 浏览 1 评论
791浏览 2评论
549浏览 2评论
489浏览 2评论
448浏览 2评论
1276浏览 2评论
GMT+8, 2025-3-7 08:16 , Processed in 0.762428 second(s), Total 40, Slave 35 queries .
