大家好,
我正在尝试将PSoC 5与国家半导体的传感器接口, 该传感器适用于微丝协议。 (微丝经常拼写μ线,本质上是SPI的前身), 我知道在PSoC 4中有一个用于微丝总线的内置块(在SPI块内,子模式设置为国家半导体), 但是在SPI块内部的PSoC 5中没有这样的特征, 有没有人在PSOC5上工作过?? 如果PSOC5中没有内置块,你建议我如何与这个传感器接口? 感谢油灯 以上来自于百度翻译 以下为原文 hello all , i am trying to interface psoc 5 with a National Semiconductor's sensor, This sensor works with the Microwire protocol (Microwire often spelled μWire, is essentially a predecessor of SPI), i know that in psoc 4 there is a built in block for the Microwire bus (inside the spi block with submode set to National Semiconductor), but in psoc 5 inside the spi block there isn't such a feature , does anyone hes any experience working with this bus on PSOC5 ?? if there isn't a built in block in psoc5 how do you suggest i can interface with this sensor ? thanks lampel |
4个回答
谷歌说:
微丝是由国家半导体公司定义的3MbPS[全双工]串行3线接口标准。 微丝协议本质上是SPI接口的子集,CPOL=0和CPHA=0。 HTTP://www. McCHIP.COM/FUMMS/M202051.ASPX 以上来自于百度翻译 以下为原文 Google says: MICROWIRE is a 3Mbps [full-duplex] serial 3-wire interface standard defined by National Semiconductor. The MICROWIRE protocol is essentially a subset of the SPI interface, CPOL = 0 and CPHA = 0. http://www.microchip.com/forums/m202051.aspx |
chenzhenbo1984 发表于 2018-12-6 06:37 谢谢你,Evgeniy, 如果我理解正确,你是说如果我用 具有CPOL=0和CPHA=0参数的PSoC 5的正常SPI块 我应该能和我的国家半导体公司的传感器接口吗? 以上来自于百度翻译 以下为原文 thank you Evgeniy , if i understand you correctly are you saying that if i will use the normal SPI block of the psoc 5 with CPOL = 0 and CPHA = 0 parameters i should be able to interface with my National Semiconductor's sensor ? |
我希望如此…这只是一句引语。 HTTP//OrgIn www. CyPr.com/FoMU/PSOC-4架构/SPI微WiRE模式 微丝与SPI和I2C比较容易用科学方法进行 多好的感应器啊!也许有人已经和他一起工作了。 附笔 也许不是这样。 HTTP://www. CyPress .COM/FIL/131646/下载 第52页 以上来自于百度翻译 以下为原文 I hope so ... This is just a quote. http://origin-www.cypress.com/forum/psoc-4-architecture/spi-microwire-mode Microwire compared to SPI and I2C | | Do It Easy With ScienceProg What a sensor. Perhaps someone already has experience working with him. p.s. Perhaps this is not so .. http://www.cypress.com/file/131646/download page 52 |
您还可以尝试SPI模式1(CPPHA=1),参见微控制器接口,第2部分进行更深层次的讨论。你也应该阅读传感器数据表,它应该解释接口是如何工作的。 以上来自于百度翻译 以下为原文 You might also try SPI mode 1 (CPHA=1), see Microcontroller Interfaces, Part 2 for a deeper discussion. You also should read the sensors data sheet, it should explain how the interface actually works. |
757个成员聚集在这个小组
加入小组2129 浏览 1 评论
1871 浏览 1 评论
3688 浏览 1 评论
1806 浏览 6 评论
1552 浏览 1 评论
622浏览 2评论
461浏览 2评论
457浏览 2评论
412浏览 2评论
1101浏览 2评论
GMT+8, 2025-1-26 14:39 , Processed in 0.879069 second(s), Total 48, Slave 43 queries .
