嗨,
我下载Vivado2014.3并尝试申请30天的评估许可证! 当我通过vivado许可管理器工具连接到xilinx许可证网站时,我将网站显示为附件。 1)基于证书的许可证只有3个: ISE WebPACK许可证 PetaLinux工具许可证 Vivado HLS评估许可证 哪个许可证支持Vivado RTL合成/实现/写入比特流? 2)基于激活的许可证显示为灰色。 我无法访问它们? 我该怎么办才能获得30天的评估许可? 谢谢, 凯茜 以上来自于谷歌翻译 以下为原文 Hi, I download Vivado2014.3 and try to apply 30-days Evaluation license! When I connect to xilinx license website by vivado license manager tool, I got website display as the attached file. 1) Certifcate Based Licenses just have 3: ISE WebPACK license PetaLinux Tool License Vivado HLS Evaluation License Which license support Vivado RTL systhesis/implementation/write bitstream? 2) Activation Based Licenses is grayed out. I can't access them? What should I do to get 30-days evaluation license? Thanks, Cathy |
6个回答
是的,你是shou; ld将使用Vivado for RTL的30天评估许可证来进行bistream。
这是基于激活的许可证。 对于Vivado 30天的eveluation许可证,请访问:http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug973-vivado-release-notes-install-license.pdf(第5章) 希望这可以帮助。 问候 Sikta 以上来自于谷歌翻译 以下为原文 Yes you shou;ld be usiing the 30 day evaluation license for Vivado for RTL to bistream. This is under teh activation based licenses. For Vivado 30 days eveluation license refer http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug973-vivado-release-notes-install-license.pdf (chapter # 5) Hope this helps. Regards Sikta |
vivado webpack将帮助您设计,实施和
生成比特流。所以你可以为webpack生成许可证。 唯一的限制是您将拥有更少的设备/架构。检查第15页,了解webpack& amp ;; 通过评估,您可以定位所有架构,但此许可证有效期为30天。因此,如果您定位webpack架构,那么最好生成webpack.Thanks 以上来自于谷歌翻译 以下为原文 vivado webpack will help you in designing,implementing & generating the bitstream. So you can generate the license for webpack. Only limitation is you will be having less device/architecture. Check page 15 for the architecture supported by webpack & with evaluation you can target all the architecture but this license is valid for 30 days. So if you targeting the webpack architecture then it is better to generate webpack. Thanks |
嗨,凯茜,
您需要生成基于激活的许可证(Vivado webpack)。 你正在做什么操作系统? 即使您使用VLM连接到许可站点,您也会看到基于激活的许可证显示为灰色。 1.打开命令提示2。 导航到 Xilinx Vivado 2014.1 bin 3.要创建激活许可证请求,请运行以下命令。 这会创建一个HTML文件。 xlicclientmgr -cr test.xml 打开HTML文件,然后单击下一步。 生成所需的激活许可证。 看看这是否有帮助。 如果您遇到任何错误,请在此处发布。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi Cathy, You need to generate Activation based license (Vivado webpack). What is the OS you are working up on? It looks like even though you connected to Licensing site using VLM you see that the activation based licenses are greyed out. 1. Open Command prompt 2. Navigate to 3. To create activation license request, run the below command. This creates a HTML file. xlicclientmgr –cr test.xml Open the HTML file and click on next. Generate the desired activation license. See if this helps. If you face any error please post the same here. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
嗨,Cathy,您正在使用Vivado License Manager,但仍然注意到激活许可证是灰色的。
导致此问题的原因有两个。 您没有使用支持的操作系统。 请参阅以下用户指南中支持的操作系统部分:http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug973-vivado-release-notes-install-license.pdf 2.可信存储不存在于 machine。按照以下步骤运行此命令以创建可信存储:a。 打开命令提示符。 导航到 2014.1 binc。 命令:installanchorservice.exe xilinxd Vivado-Softwared。 然后在之前的帖子中由Deepika从Vivado License Manager生成许可证或提供的步骤(命令行流程)。谢谢,Vinay -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Cathy, You are using Vivado License Manager and still observes that activation licenses are greyed-out. There are two reasons for causing this issue. 1. You are not using supported OS. See supported OS section in the following user guide: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug973-vivado-release-notes-install-license.pdf 2. Trusted Storage was not present on the machine. Run this command by following below steps to create trusted storage: a. Open Command Prompt b. Navigate to c. command: installanchorservice.exe xilinxd Vivado-Software d. Then generating the license from Vivado License Manager or steps provided (command line flow) by Deepika in earlier post. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
你怎么有2014.3?
我只能在网站上看到2014.2 以上来自于谷歌翻译 以下为原文 How come you have 2014.3? I can only see 2014.2 on the website |
您好,2014.3的修复发布日期尚未确定。谢谢,Yash
以上来自于谷歌翻译 以下为原文 Hello, The fix release date for 2014.3 is not yet decided. Thanks, Yash |
2306 浏览 7 评论
2716 浏览 4 评论
2197 浏览 9 评论
3278 浏览 0 评论
2351 浏览 15 评论
631浏览 1评论
1682浏览 1评论
439浏览 1评论
193浏览 1评论
652浏览 0评论
GMT+8, 2024-9-20 09:43 , Processed in 1.112859 second(s), Total 53, Slave 48 queries .
