电子发烧友论坛扫一扫,分享给好友
我该怎么办呢?
重要信息 下面的激活许可部分被禁用,因为Vivado License Manager未用于启动此Web会话,或者因为激活请求ID已用于生成许可证。 以上来自于谷歌翻译 以下为原文 how do I get past this? Important Information The activation licensing section below is disabled either because Vivado License Manager was not used to initiate this web session or because the Activation Request ID has already been used to generate a license. Please see http://www.xilinx.com/tools/faq.htm for more information. |
10个回答
嗨,
如错误消息中所述,您必须通过Vivado License Manager来激活激活许可证部分。 你是如何打开这个网页的? 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, As mentioned in the error message, you have to come thorugh Vivado License Manager to activate the activation license section. How are you opening this webpage? Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,
打开Vivado LicenseManager,选择“获取许可证”,选择“获取免费许可证 - Vivado WebPACK,SDK,免费IP等”,选择“立即连接”。 单击“立即连接”后,您将进入您的帐户许可页面,您的基于激活的WebPACK许可证将不再显示为灰色。 以上来自于谷歌翻译 以下为原文 Hi,
嗨,
有几个原因可能导致这个问题。 首先,xlicsrvrmgris不用于激活激活许可证部分。 例如,客户可以使用VLM或xlicclientmgr来激活激活许可证,并发现他只能生成节点锁定许可证。 其次,恰好已经为当前机器生成了许可证,但用户忘记安装它。 问候, 肖恩 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi, There are several reasons which may lead to this problem. First, xlicsrvrmgr is not used to activate the activation license section. For example, customer may use VLM or xlicclientmgr to activate the activation license and find that he can only generate node-locked license. Secondary, it happens that a license has already been generated for current machine but user forget to install it. Regards, Sean ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
嗨@ ep621c
你的问题解决了吗? 如果没有,请告诉我们当前的问题状态。 如果问题得到解决,请通过将帖子标记为有助于解决问题的解决方案来关闭该主题。 以上来自于谷歌翻译 以下为原文 Hi @ep621c Is your issue resolved? If not please let us know current status of the issue. If the issue is resolved please close the thread by marking the post as solution which helped in resolving the issue. |
我需要从网站下载许可证,但框中显示为灰色。
我可以看到许可证但无法访问该区域。 以上来自于谷歌翻译 以下为原文 I need to download the license from the site but the box is greyed out. I can see the License but dont have access to the area. |
嗨,
您是如何开设Xilinx许可站点的? 按照以下步骤激活浮动部分: 1.从ww.xilinx.com - >下载下载Xilinx许可实用程序 2.解压缩下载的.zip文件 3.打开命令提示符或终端并导航到解压缩的文件夹。 4.运行命令:installanchorservice.exe xilinxd Vivado-Software(Windows)或./install_fnp.sh(linux) 5.运行以下命令:xlicsrvrmgr -cr create_request.xml 最后一个命令创建.xml和.html文件。 在浏览器中打开任何此文件,它将导航到Xilinx许可站点。 现在您将观察到许可是活跃的。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, How are you opening Xilinx Licensing Site? Follow below steps to activate the floating section: 1. Download Xilinx Licensing Utilities from ww.xilinx.com -> Downloads 2. Extract the downloaded .zip file 3. Open command prompt or terminal and navigate to extracted folder. 4. Run command: installanchorservice.exe xilinxd Vivado-Software (Windows) or ./install_fnp.sh (linux) 5. Run the command: xlicsrvrmgr -cr create_request.xml The last command creates a .xml and .html file. Open any of this files in browser and it will navigate to Xilinx Licensing Site. And now you will observe that the licensing is active. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,
从2014年起,Xilinx许可计划发生了变化。 我们使用基于激活的许可来实现传统的基于证书的许可。 在基于激活的许可方案中,激活使用客户端或服务器硬盘驱动器上的受信任区域来存储授权凭证,而不是要求存在文件来授权计算机。 从Vivado 2014.1安装程序开始,将自动安装并初始化此可信存储区域。 当Vivado工具查找许可证功能时,如果此可信存储区域包含正确的授权,则允许它们运行。 有关基于激活的许可的详细信息,请参阅此发行说明。 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug973-vivado-release-notes-install-license.pdf 您需要通过Vivado License Manager(用于节点锁定许可证)和通过命令行实用程序导航到许可站点,而不是直接打开Xlinx许可站点。 如果您尝试生成节点锁定lciense,请按照以下步骤操作。 从开始菜单 - >所有程序 - > Xilinx设计工具 - > Vivado 2014.1 - >管理Xilinx许可证 它将打开VLM GUI,如图所示。 选择获取许可 - >立即连接 它将引导您进入Xilinx许可站点。 使用您的帐户详细信息登录,您将能够看到基于激活的许可证。 激活许可证部分下的许可证将不再显示为灰色。 如果您正在尝试生成浮动许可证,请按照之前发布的vinay中提到的步骤进行操作。 以上来自于谷歌翻译 以下为原文 Hi, From 2014.1 there has been changes in Xilinx Licensing schemes. Instaed of conventional certificate based licensing we are using activation based licensing. In Activation based licensing scheme,Instead of requiring a file to be present to authorize a machine, Activation uses a trusted area on the client or server’s hard-drive to store the authorization credentials. This trusted storage area will automatically be installed and initialized beginning with the Vivado 2014.1 installer. When the Vivado tools look for a license feature, they are allowed to run if this trusted storage area contains the proper authori zation. Please refer to this release notes,for more info on activation based licensing. http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug973-vivado-release-notes-install-license.pdf Rather than directly opening the Xlinx Licensing site you need to navigate to licensing site through Vivado License Manager ( for node-locked license) and through commandline utilities for Floating license generation. If you are trying to generate Node-locked lciense please follow the below steps. From start menu ->All Programs ->Xilinx Design Tools -> Vivado 2014.1 -> Manage Xilinx Licenses It will open VLM GUI as shown bleow. Select Obtain License -> Connect Now It will navigate you to the Xilinx Licensing Site. Login with your account details you will be able to see the activation based licenses. The licenses under Activation based license section will be no more greyed out. If you are trying to generate floating license please follow the steps that are mentioned by vinay in earlier post. |
嗨@ ep621c
你的问题得到解答了? 如果是,请通过标记答案来关闭主题。 如果没有,请告知我们当前的问题状态。 以上来自于谷歌翻译 以下为原文 Hi @ep621c Is your questions answered? If yes, please close the thread by marking the answer. If not, please let us know current status of the issue. |
谢谢您的帮助。
我已准备好激活我的许可证 以上来自于谷歌翻译 以下为原文 Thanks for the help. Im all set wth activating my Licences |
嗨@ ep621c
很高兴您的问题现在得到解决。 请将帖子标记为已接受的解决方案,以关闭该主题。 IT是一个很好的论坛实践,将帮助面临类似问题的用户。 以上来自于谷歌翻译 以下为原文 Hi @ep621c Glad that your issue is resolved now. Please close the thread by marking the post as accepted solution. IT is a good forum practice and will help the users who are facing similar issue. |
2432 浏览 7 评论
2831 浏览 4 评论
2300 浏览 9 评论
3379 浏览 0 评论
2471 浏览 15 评论
1435浏览 1评论
597浏览 1评论
463浏览 1评论
2016浏览 0评论
739浏览 0评论
GMT+8, 2024-12-31 07:13 , Processed in 1.340953 second(s), Total 61, Slave 56 queries .
