我有两个ICD3调试器,一个是好的,另一个是坏的。当使用坏的一个做ICSP时,它会报告下面的错误:“没有发现目标设备(无法检测到目标电压VDD)。你必须连接到一个目标设备来使用ICD3。“使用另一个好的ICD3调试器将如下所示:下面的内存区域将被编程:程序存储器:开始地址=0x0,结束地址=0x3AeConnect存储器设备擦除…编程/验证完成:只有DE。Bug在操作中发生了变化,坏的调试程序也是一个新的调试程序。
以上来自于百度翻译 以下为原文 I have two ICD3 debugers, one is good, the other is bad.When use the bad one to do ICSP, it will report the error below: "Target device was not found (could not detect target voltage VDD). You must connect to a target device to use ICD3." Use another good ICD3 debuger will be ok like below: The following memory area(s) will be programmed: program memory: start address = 0x0, end address = 0x3ae configuration memory Device Erased... Programming... Programming/Verify complete NOTE: Only the debuger changed in the operation and the bad debuger is also a new debuger. |
5个回答
当我测试VDD和VSS之间的连接时,我发现坏的VDD短于VSS。
以上来自于百度翻译 以下为原文 When i test the connection between VDD and VSS i find the VDD of bad one is short to VSS. |
你用自测板测试了吗?什么版本的MPLAB?它有多大?如果自检失败了,请到这里:HTTP://www. McCHIP.COM/CISAR/HOM.ASPX
以上来自于百度翻译 以下为原文 Did you Test it with the Self Test Board it came with? What version of MPlab? How old is it? If it fails the self test, Go here: http://www.microchip.com/cisar/Home.aspx |
我断定,但调试程序无法连接测试板报告电流太大。
以上来自于百度翻译 以下为原文 I dit it, but debuger can't connect the test board reporting that the current is too large. |
如果你说的是ICD3附带的小测试板。另一个经过。那算是失败了。按照我发布的链接。
以上来自于百度翻译 以下为原文 If you are speaking of the little test board that came with the icd3. And the other one passes. That would count as failed. Follow the link I posted. |
5360 浏览 9 评论
2092 浏览 8 评论
1991 浏览 10 评论
3273 浏览 3 评论
2304 浏览 5 评论
867浏览 1评论
755浏览 1评论
698浏览 1评论
749浏览 0评论
643浏览 0评论
GMT+8, 2025-2-23 15:17 , Processed in 1.323522 second(s), Total 83, Slave 67 queries .
