扫一扫,分享给好友
嗨,
我正在尝试在我的VM许可证服务器上安装我的VIVADO系统版浮动许可证,该服务器托管我们正在使用的所有其他许可工具。 据我所知,xilinx许可证工具实际上无法处理VM安装的操作系统 - 有没有解决方法呢? 我想我现在可以在工作站上安装许可证服务器吗? 如果下一次更新(2014.3)能够支持VM上的许可证工具(按计划) - 将许可证从工作站移动到服务器是否有任何潜在的问题? 谢谢你的帮助,最好的问候 麦克风 以上来自于谷歌翻译 以下为原文 Hi, I'm trying to get my VIVADO System edition floating license setup on my VM license server, which is hosting all other licensing tools we're using. As I understand, the xilinx license tool is actually not able to handle a VM installed OS - is there any workaround for this? I guess I can install the license server on a workstation to get started for now? In case the next update (2014.3) will be able to support license tools on a VM (as planned) - are there any pootential issues with moving the license from the workstation to the server? Thanks for yor help, best regards Mike |
6个回答
嗨,
据我所知,xilinx许可证工具实际上无法处理VM安装的操作系统 - 有没有解决方法呢? - >由于VM不支持基于激活的许可,您可以将其更改为传统的基于证书的许可(.lic)。 如果下一次更新(2014.3)能够支持VM上的许可证工具(按计划) - 将许可证从工作站移动到服务器是否有任何潜在的问题? - >为此,您需要返回许可证,然后再次为服务器计算机生成它。 有关返还许可证的程序,请查看此AR,http://www.xilinx.com/support/answers/60525.html 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, As I understand, the xilinx license tool is actually not able to handle a VM installed OS - is there any workaround for this? --> Since the activation based licensing is not supported with VM, you can change this to conventional certifiate based license(.lic). In case the next update (2014.3) will be able to support license tools on a VM (as planned) - are there any pootential issues with moving the license from the workstation to the server? --> For this you need to return your license and then again generate it for the server machine. For the procedure to return license check this AR,http://www.xilinx.com/support/answers/60525.html View solution in original post |
嗨Mike,是的,虚拟机上的许可安装将得到Vivado 2014.3的支持(最可能)。谢谢,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Mike, Yes, License installation on VM will be supported from Vivado 2014.3 (Most Probably). Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,
据我所知,xilinx许可证工具实际上无法处理VM安装的操作系统 - 有没有解决方法呢? - >由于VM不支持基于激活的许可,您可以将其更改为传统的基于证书的许可(.lic)。 如果下一次更新(2014.3)能够支持VM上的许可证工具(按计划) - 将许可证从工作站移动到服务器是否有任何潜在的问题? - >为此,您需要返回许可证,然后再次为服务器计算机生成它。 有关返还许可证的程序,请查看此AR,http://www.xilinx.com/support/answers/60525.html 以上来自于谷歌翻译 以下为原文 Hi, As I understand, the xilinx license tool is actually not able to handle a VM installed OS - is there any workaround for this? --> Since the activation based licensing is not supported with VM, you can change this to conventional certifiate based license(.lic). In case the next update (2014.3) will be able to support license tools on a VM (as planned) - are there any pootential issues with moving the license from the workstation to the server? --> For this you need to return your license and then again generate it for the server machine. For the procedure to return license check this AR,http://www.xilinx.com/support/answers/60525.html |
感谢你的帮助。
我正在尝试从1天开始将“部分”生成的许可证从我的VM移动到我正在运行VIVADO的工作站。 我按照说明将许可证返还给xilinx,以便为另一台机器获取新的许可证。 问题是,许可证似乎被锁定到我的VM,但是当我运行程序(命令行)来释放许可证时,该工具告诉我安全spce中没有内容 - 我想这是因为它没有' 工作正常。 看看Xilinx lincese管理网站,我看到为VM激活了2个许可证,但我无法访问webbrowser中的“修改许可证”按钮 - 它显示为灰色。 我可以再次询问您的帮助,或任何描述类似行为的文件/网站吗? 以上来自于谷歌翻译 以下为原文 Thanks for all your help. I'm trying since 1 day to move the "partially" generated license from my VM to the workstation on which I'm running VIVADO. I've followed the instructions to return a license to xilinx in order to get a new one for the other machine. The problem is, the license seems to be locked to my VM, but when I run the procedure (command line) to release the license, the tool is telling me there is no content in the secure spce - I guess thats because it didn't work properly. Looking at the Xilinx lincese management web site, I see 2 licenses activated for the VM, but I can't access the "modify license" button in the webbrowser - it's greyed out. May I ask once more for your assistance, or any document / site that describes a similar behaviour? |
嗨,
我猜您已经从Xilinx许可站点请求了许可证密钥,许可证将通过电子邮件发送给您。 无论您是否将.xml许可证密钥处理到可信存储中,许可证授权都将记录在网站上。 通常,您需要处理许可密钥,然后如果要重新托管它,则将许可证密钥返回给Xilinx。 由于许可证请求来自目前基于激活的许可证不支持的VM,因此您需要联系Xilinx威廉希尔官方网站 支持部门以回收您的许可证授权,并将其从激活更改为基于证书的许可。 问候, 肖恩 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi, I guess you have already requested for a license key from Xilinx Licensing site and the license will be sent to you via email. The license entitlement is recording on the website no matter if you process the .xml license key into trusted storage or not. In generally you need to process the license key and then return the license key to Xilinx if you want to rehost it. Since the license request is from a VM which is not supported by Activation based license for now, you need to contact Xilinx Technical Support to reclaim your license entitlement and have it changed from Activation to Certificate based licensing. Regards, Sean ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
嗨,
感谢您的所有帮助 - 我将尝试更改此证书,并希望在许可证服务器支持VM后重新更改它。 最好的祝福 麦克风 以上来自于谷歌翻译 以下为原文 Hi, Thanks for all your help - I'll try to get this certificate changed, and hopefully get it re-changed once VM are supported for license servers. best regards Mike |
2509 浏览 7 评论
2879 浏览 4 评论
2336 浏览 9 评论
3429 浏览 0 评论
2515 浏览 15 评论
2605浏览 1评论
668浏览 1评论
533浏览 1评论
818浏览 0评论
GMT+8, 2025-3-5 04:51 , Processed in 1.327127 second(s), Total 54, Slave 49 queries .
