扫一扫,分享给好友
亲,
我买了一个Vivado系统版浮动许可证,订单#:3645624-1。 我必须按照文件UG973中的说明和文件.xml& .html已创建。 但无法激活Vivado浮动许可证,如下所示。 以上来自于谷歌翻译 以下为原文 Dear, I bought a Vivado System Edition Floating License, Order #: 3645624-1. I have to follow the instructions in the file UG973, and the file .xml & .html have been created. But can't activate Vivado floating license as shown below. |
10个回答
在Windows上:以administrator1身份打开命令提示符。
导航到/win32.o(对于32位计算机)或/win64.o(对于64位计算机)2。 运行命令:installanchorservice.exe xilinxd.exe Vivado-Software(在计算机上创建可信存储)3。 运行命令:xlicsrvrmgr.exe -cr request.xml(创建request.html文件以生成许可证)在步骤3之后,您将获得request.xml和request.html。在您的Internet浏览器中使用该html并生成所需的许可证 。生成许可证后,您将获得新的* .xml文件。 使用该xml并运行步骤#4.4。 运行命令:xlicsrvrmgr.exe -p Xilinx_Licenese.xml(处理收到的许可证文件并保存到可信存储).5。 使用以下三行创建一个.lic文件样本:(手动,您必须使用以下三行创建此* .lic文件)o SERVER o USE_SERVERo供应商xilinxd6。 运行命令:lmgrd -c sample.lic -l debug.logThanks,Yash 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 On Windows: Open Command prompt as administrator 1. Navigate to the 2. Run the command: installanchorservice.exe xilinxd.exe Vivado-Software (Creates a trusted storage on the machine) 3. Run the command: xlicsrvrmgr.exe -cr request.xml (Creates a request.html file to generate the license) After step 3 you will get request.xml and request.html. Use that html in your internet browser and generate the required license. After generating the license you will get new *.xml file. Use that xml and run step # 4. 4. Run the command: xlicsrvrmgr.exe -p Xilinx_Licenese.xml (Process the received license file and saved to trusted storage). 5. Create a sample .lic file with below three lines: (manually you have to create this *.lic file using below three lines) o SERVER o USE_SERVER o VENDOR xilinxd 6. Run the command: lmgrd -c Thanks, YashView solution in original post |
嗨,请查看http://forums.xilinx.com/t5/Installation-and-Licensing/Installing-Vivado-Design-Suite-Floating-License-on-FlexLM/td-p/468312
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Please check http://forums.xilinx.com/t5/Installation-and-Licensing/Installing-Vivado-Design-Suite-Floating-License-on-FlexLM/td-p/468312Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
嗨,你必须使用xlicsrvrmgr命令来创建.xml和.html文件.FYI .. xlicsrvrmgr - >激活浮动许可证xlicclientmgr - >激活节点锁定许可证谢谢,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, You have to use xlicsrvrmgr command for creating .xml and .html files. FYI.. xlicsrvrmgr --> activates floating licenses xlicclientmgr --> activates node-locked licenses Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
请查看这些FAQ:http://www.xilinx.com/tools/faq.htm
谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 check these FAQs http://www.xilinx.com/tools/faq.htmThanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
导航到/win32.o(对于32位计算机)或/win64.o(对于64位计算机)2。 运行命令:installanchorservice.exe xilinxd.exe Vivado-Software(在计算机上创建可信存储)3。 运行命令:xlicsrvrmgr.exe -cr request.xml(创建request.html文件以生成许可证)在步骤3之后,您将获得request.xml和request.html。在您的Internet浏览器中使用该html并生成所需的许可证 。生成许可证后,您将获得新的* .xml文件。 使用该xml并运行步骤#4.4。 运行命令:xlicsrvrmgr.exe -p Xilinx_Licenese.xml(处理收到的许可证文件并保存到可信存储).5。 使用以下三行创建一个.lic文件样本:(手动,您必须使用以下三行创建此* .lic文件)o SERVER o USE_SERVERo供应商xilinxd6。 运行命令:lmgrd -c sample.lic -l debug.logThanks,Yash 以上来自于谷歌翻译 以下为原文 On Windows: Open Command prompt as administrator 1. Navigate to the 2. Run the command: installanchorservice.exe xilinxd.exe Vivado-Software (Creates a trusted storage on the machine) 3. Run the command: xlicsrvrmgr.exe -cr request.xml (Creates a request.html file to generate the license) After step 3 you will get request.xml and request.html. Use that html in your internet browser and generate the required license. After generating the license you will get new *.xml file. Use that xml and run step # 4. 4. Run the command: xlicsrvrmgr.exe -p Xilinx_Licenese.xml (Process the received license file and saved to trusted storage). 5. Create a sample .lic file with below three lines: (manually you have to create this *.lic file using below three lines) o SERVER o USE_SERVER o VENDOR xilinxd 6. Run the command: lmgrd -c Thanks, Yash |
嗨,
我试过但仍然没有激活。 我的Vivado浮动许可证可能取决于该软件的哪个版本? 我正在使用Vivado版本2014.2。 谢谢! 以上来自于谷歌翻译 以下为原文 Hi, I tried but still not activated. My Vivado Floating license may depend on which version of the software? I'm using Vivado version 2014.2. Thanks! |
嗨,
按照Yash提到的步骤,您是否收到任何错误? 尝试从Xilinx站点下载许可证管理工具,http://www.xilinx.com/support/download/index.htm 然后尝试Yash提到的步骤。 以上来自于谷歌翻译 以下为原文 Hi, Are you getting any errors while following the steps mentioned by Yash? Try downloading the License Mnagement tools from Xilinx site,http://www.xilinx.com/support/download/index.htm and then try the steps mentioned by Yash. |
嗨,
我的电脑上的操作系统是Windows 7 Ultimate 64bit。 必须在运行Windows Server操作系统的计算机上安装浮动许可证吗? 问候, 以上来自于谷歌翻译 以下为原文 Hi, The operating system on my computer is Windows 7 Ultimate 64bit. Floating License must be installed on computer running the Windows Server operating system? Regards, |
嗨,你能分享这个命令的输出:xlicsrvrmgr -vThanks,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Can you share the output of this command: xlicsrvrmgr -v Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
2509 浏览 7 评论
2879 浏览 4 评论
2336 浏览 9 评论
3429 浏览 0 评论
2515 浏览 15 评论
2607浏览 1评论
669浏览 1评论
533浏览 1评论
818浏览 0评论
GMT+8, 2025-3-5 09:51 , Processed in 1.345795 second(s), Total 62, Slave 57 queries .
