你好,
我有一个在Linux机器上使用的Vivado(2014.2)WebPACK许可证。 我必须重新构建Linux机器,所以我尝试使用VLM返回许可证(因此我可以在新安装上重新获取它而没有任何问题)。 遗憾的是,VLM中的代理设置错误,因此许可证返回未正确完成。 现在,许可证没有出现在VLM中,因此我无法再次尝试返回,但在许可网站上显示“Activated Seats - 1”,因此我将无法重新获取它 在新安装上(我还没有重新构建机器;我想先解决许可证问题)。 如果我从网站重新下载许可证并尝试使用VLM激活它,我会收到“无法将许可权限加载到可信存储中。最可能的原因是此响应已经被处理。” 此外,它在许可网站上显示为“许可证类型 - 节点”,我认为我在这里阅读的内容对于Vivado WebPACK许可证是不正确的。 基本上,我正在寻找一种方法来完成返回或重置此许可证,因此它不会显示为已激活。 提前感谢您提供的任何帮助。 (顺便提一下,一个小小的问题 - 如果您的支持网站只是自动发送邮件告诉请求者从论坛获得支持,请不要提供一个字段供人们解释他们的问题,所以他们必须解释两次。 ..) 以上来自于谷歌翻译 以下为原文 Hello, I have a Vivado (2014.2) WebPACK license that I was using on a Linux machine. I have to re-build the Linux machine, so I tried to use VLM to return the license (so I could re-obtain it on the new installation with no issues). Unfortunately, the proxy settings were wrong in VLM so the license return didn't complete correctly. Now, the license doesn't show up in VLM, so I can't attempt to return it again, but on the licensing web site it shows "Activated Seats - 1", so I won't be able to re-obtain it on the new installation (I haven't re-built the machine yet; I wanted to get the license issue cleared up first). If I re-download the license from the web site and attempt to activate it using VLM, I get "Unable to load License Rights into Trusted Storage. The most likely reason is that this reponse has already been processed." Also, it shows up on the licensing web site as "License Type - Node," which I thought I read somewhere on here is incorrect for Vivado WebPACK licenses. Basically, I'm looking for a way to complete the return or reset this license so it doesn't show as activated. Thanks in advance for any help you can provide. (Incidentally, a minor peeve - If your support web site is just going to automatically send a mail telling the requester to get support from the forums, please don't provide a field for people to explain their problem, so they have to explain it twice...) |
3个回答
嗨,
由于返回请求已经在VLM中显示许可证密钥,但是履行仍然存储在可信存储中,直到已经处理了返回响应。 在这种情况下,您需要使用命令行返回许可证密钥。 以下是步骤: 1.使用root权限和源设置64.sh打开Linux shell 2.运行commandxlicclientmgr -cr return.xml -r 3.run commandxlicclientmgr -returnTransaction“request = return.xml”“response = response.xml”proxy =“[]” 4.使用以下命令处理response.xml文件。 它将从可信存储中删除履行。 xlicclientmgr -p response.xml -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, The license key doesn't show up in VLM due to the return request has been made, but the fulfillment is still being stored in trusted storage untill the return response has been processed. In this case you need to return the license key with command line. Here are the steps: 1. open a Linux shell with root privilege and source settings64.sh 2. run command xlicclientmgr -cr return.xml -r 3. run command xlicclientmgr -returnTransaction "request=return.xml" "response=response.xml" proxy=" 4. Process the response.xml file with the following command. It will delete the fulfillment from trusted storage. xlicclientmgr -p response.xml ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. -------------------------------------------------------------------------View solution in original post |
嗨,
由于返回请求已经在VLM中显示许可证密钥,但是履行仍然存储在可信存储中,直到已经处理了返回响应。 在这种情况下,您需要使用命令行返回许可证密钥。 以下是步骤: 1.使用root权限和源设置64.sh打开Linux shell 2.运行commandxlicclientmgr -cr return.xml -r 3.run commandxlicclientmgr -returnTransaction“request = return.xml”“response = response.xml”proxy =“[]” 4.使用以下命令处理response.xml文件。 它将从可信存储中删除履行。 xlicclientmgr -p response.xml -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi, The license key doesn't show up in VLM due to the return request has been made, but the fulfillment is still being stored in trusted storage untill the return response has been processed. In this case you need to return the license key with command line. Here are the steps: 1. open a Linux shell with root privilege and source settings64.sh 2. run command xlicclientmgr -cr return.xml -r 3. run command xlicclientmgr -returnTransaction "request=return.xml" "response=response.xml" proxy=" 4. Process the response.xml file with the following command. It will delete the fulfillment from trusted storage. xlicclientmgr -p response.xml ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
嗨肖恩,
谢谢回复。 在我昨天发布问题后的一段时间,我检查了许可证。 我没有做任何事情,somaybe有些超时并恢复状态良好,或有人对我怜悯并将其修复到许可证服务器上。 无论哪种方式,我都能够重新获得许可证,一切似乎都在重新开始。 我将记住您的命令行以供将来参考。 以上来自于谷歌翻译 以下为原文 Hi Sean, Thanks for the reply. A while after I posted my question yesterday, I checked and the license was once again available. I didn't do anything, so maybe something timed out and got back in a good state, or someone took pity on me and fixed it on the license server. Either way, I was able to re-obtain the license and everything seems to be working again. I'll keep your command lines in mind for future reference. |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2447浏览 1评论
659浏览 1评论
521浏览 1评论
2075浏览 0评论
801浏览 0评论
GMT+8, 2025-2-24 09:10 , Processed in 1.387247 second(s), Total 51, Slave 45 queries .
