我有一台采用Xeon E3-1200v2处理器的英特尔1200BTL主板,几个小时前在启动过程中可悲地开始发出哔哔声。
它不久发出六声哔哔声然后保持沉默。 我不确定这些哔哔声是来自BIOS还是BMC。 我想它应该是BMC,因为在这种情况下,蜂鸣声序列应该只发生一次,而BIOS蜂鸣声序列应该重复。 同样来自早期故障的iirc,与当前序列相比,BIOS序列具有更高的音调噪声。 手册并没有真正有用,我也找不到网上六声嘟嘟声。 对于AMI BIOS,这意味着一些A20门故障并没有真正有用.https://www.intel.com/content/dam/support/us/en/documents/motherboards/server/***/g13326007_s1200bt_tps_r2_4.pdf但是如上所述 ,我甚至不知道它是否是BIOS。 我也不知道错误是与主板有关还是与处理器有关。 我已经改变了RAM,所以我想我可以排除它。 任何帮助赞赏。 以上来自于谷歌翻译 以下为原文 I have an Intel 1200BTL motherboard with Xeon E3-1200v2 processor which sadly started beeping a few hours ago during boot. It beeps shortly six times and then remains silent. I'm not sure though if the beeps come from the BIOS or BMC. I guess it should be the BMC since in this case the beep sequence is supposed to happen only one time whereas the BIOS beep sequence should repeat itself. Also iirc from some earlier failures the BIOS sequence has a higher pitched noise compared to the current sequence. The manualwas not really helpful and I also could not find much for six beep tones on the web. For the AMI BIOS it would mean some A20 gate failure which is not really helpful.https://www.intel.com/content/da ... 0bt_tps_r2_4.pdfBut as said, I don't even know if it is the BIOS. I also don't know if the error is related to the mainboard or maybe to the processor. I already changed the RAM so I guess I can exclude that. Any help appreciated. |
3个回答
Hellofl1,希望你做得很好。为了解决这个问题,我们需要玩服务器。服务器发帖吗?你试图清除c / mos吗?你有没有连接USB?问候,Charlie_Intel
以上来自于谷歌翻译 以下为原文 Hello fl1, Hope you are doing fine. In order to solve that issue, we would need to play around with the server. Does the server post? Did you try to clear the c/mos? Do you have any USB connected? Regards, Charlie_Intel |
Hellofl1,我们想知道您是否需要进一步的帮助?问候,Charlie_Intel 以上来自于谷歌翻译 以下为原文 Hello fl1, We are wondering if you need further assistance? Regards, Charlie_Intel |
Hellofl1,我们想知道您是否还有其他问题,或者我们是否能够关闭此主题?问候,Charlie_Intel 以上来自于谷歌翻译 以下为原文 Hello fl1, We are wondering if you have further questions or if we are able to close this thread? Regards, Charlie_Intel |
448浏览 0评论
GMT+8, 2024-11-10 16:16 , Processed in 0.458379 second(s), Total 49, Slave 44 queries .
