我曾经在STM32F103 MCU上用PMSM FOC SDK 2.0开发伺服驱动器。我想用STM32F417ZG制造一个新的控制板,因为它的浮点单元。我可以直接在F4中使用SDK2.0或做些什么。我在ST网站上找不到F1和F4之间的任何迁移信息。
我计划将SDK从2.0更新到3.0,但我不能从中国经销商那里获得PMSM SDK3.0的源代码,所以有人可以给我发送源代码。非常感谢。 #condiential - 网络分布 以上来自于谷歌翻译 以下为原文 I used to developing a servo driver with PMSM FOC SDK 2.0 in STM32F103 MCU. And I wanna make a new control board with STM32F417ZG because of its floating point unit. Can I use the SDK2.0 in F4 directly or do something. I can't find any migration information between F1 and F4 on ST website. And I plan to update the SDK from 2.0 to 3.0, but I can�t get the source code of PMSM SDK3.0 from Chinese distributor, so can someone send me the source code. Thanks a lot. #condiential-web-distribution |
13个回答
你好丁,
STM32F103和STM32F4xx在外设方面略有不同。使用SDK v2.0我认为在FW上应用正确的修改并不是非常用户友好。 另一方面,我们正在开发SDK v3.2,除了F100和F103系列之外,它还支持F2xx和F4xx系列(暂时只有整数表示)。 我们希望在2012年2月之前在这个新图书馆进行网络发布;根据业务细节,我们还可能会在1月底/ 2月底之前为您安排相同FW的测试版。 要获取Web分发v3.0的源文件(即所谓的机密分发),请要求您的分销商联系ST销售办事处。 最好的祝福, Billino 以上来自于谷歌翻译 以下为原文 Hello Ding, STM32F103 and STM32F4xx have slight difference in terms of peripherals. Working with SDK v2.0 I think it's not very user friendly to apply the right modifications on the FW. On the other hand, we are working on the SDK v3.2, it will also support - other than F100 and F103 series - F2xx and F4xx family (always with integer number representation for the time being). We expect to have web distribution of this new library by February 2012; depending on business details we may also arrange for you a beta release of the same FW by the end of January/beg of February. To get source file of the web distribution v3.0 (that is the so called confidential distribution), ask your distributor to contact ST sales offices. Best Regards, Billino |
嗨比利诺,
谢谢您的回复。完成后,我很高兴尝试新的MC库。我总是使用Keil开发STM32s,因此Keil支持的项目会更好。我的电子邮件: 邮寄地址:xinzhong.ding@gmail.com ,期待您的新版本。谢谢。 以上来自于谷歌翻译 以下为原文 Hi Billino, Thank you for your reply. I’m glad to try the new MC library when you finished. I always use Keil to develop the STM32s, so the project supported by Keil will be better. My Email: mailto:xinzhong.ding@gmail.com , looking forward to your new release. Thanks. |
比林诺你好,
只是想知道v3.2是如何出现的...它已经是3月中旬了 - 是否已经可以下载了? 干杯 以上来自于谷歌翻译 以下为原文 Hello Billino, just wondering how v3.2 is coming along...it's already mid-March - is it already available for download? cheers |
我是一名在中国经销商工作的现场应用工程师。目前,STM32F4电机控制和变频器是最合适的应用。因此,MC库是客户评估的最重要因素。所以我们希望这个库能够尽快发布。如果不。 STM32F4很难推广。
现在TI的TMS320F2000和LM4XXX,飞思卡尔Cortex-M4正在迅速推广。 以上来自于谷歌翻译 以下为原文 I am a field application engineer working at a distributor in china. For now, STM32F4 motor control and frequency converter is the most suitable application. So MC libraries is the most important factor for customer's evaluation. so we expect to this libraries can release as soon as possible. If not. STM32F4 very difficult to promote. Now TI's TMS320F2000 and LM4XXX, freescale Cortex-M4 is quickly promote. |
如果您能给出一个,我想要更新v3.2预期日期。
埃里克 以上来自于谷歌翻译 以下为原文 I'd like an update on the v3.2 expected date as well if you can give one. Eric |
我也在寻找这个用于STM32F4-Discovery来运行无传感器的无刷FOC,我看到了对SDK 3.2的引用,但没有地方可以下载它。
UM1052 PDF可供下载,即“STM32F103xx / STM32F100xx / STM32F2xx / STM32F4xx” PMSM单/双FOC SDK v3.2'' 它也在这里引用了M4,并于3月发布。但是没有与电机控制lib v3.2的链接。 3.2 lib是否存在?这是“机密”版本吗? 以上来自于谷歌翻译 以下为原文 I'm also looking for this for use with the STM32F4-Discovery to run sensorless brushless FOC, I saw references to SDK 3.2 but no place to download it. The UM1052 PDF is available for download, that says ''STM32F103xx/STM32F100xx/STM32F2xx/STM32F4xx PMSM single/dual FOC SDK v3.2'' And it refers to the M4 here too, and it was published in March. But there's no link to a motor control lib v3.2. Does the 3.2 lib exist? Is it a ''confidential'' release? |
看看[DEAD LINK /public/STe2ecommunities/mcu/Lists/motor_control/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/motor_control/STM32%20FOC%20PMSM%20SDKv3.2%20Confidential%20distribution%20available %20under%20request& FolderCTID = 0x01200200770978C69A1141439FE559EB459D7580005A810128153A7244A21980BD49736843& TopicsView = https%3a // my.st.com / public / STe2ecommunities / mcu / Lists / motor_control / AllItems.aspx& currentviews = 0]这篇文章
梁咏琪 以上来自于谷歌翻译 以下为原文 Take a look at [DEAD LINK /public/STe2ecommunities/mcu/Lists/motor_control/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/motor_control/STM32%20FOC%20PMSM%20SDKv3.2%20Confidential%20distribution%20available%20under%20request&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580005A810128153A7244A21980BD49736843&TopicsView=https%3a//my.st.com/public/STe2ecommunities/mcu/Lists/motor_control/AllItems.aspx¤tviews=0]this post Gigi |
我今天再次联系了我当地的支持办公室,与电机控制代表进行了交谈,并被告知STM32 FOC PMSM SDKv3.2''保密分发''目前不可用,目前我没有预定的发布日期能够获得副本。
它的发布是否可根据要求提供?什么是获得副本的最佳方式? 以上来自于谷歌翻译 以下为原文 I contacted my local support office again today, spoke with the motor control rep, and was told the STM32 FOC PMSM SDKv3.2 ''Confidential distribution'' was not available at this time and there is currently no scheduled release date where I might be able to obtain a copy. Is its release available upon request or not? What would be the best way to obtain a copy? |
STM32 FOC lib。 3.2 - 保密分发已于7月6日发布。
请让他联系微控制器部门或卡塔尼亚的电机控制总部。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 The STM32 FOC lib. 3.2 - Confidential distribution has been released 6th of July. Please ask him to contact microcontroller division or the motor control headquarters in Catania. Ciao Gigi |
Gigi-
我还没有成功获得STM32 FOC lib。 3.2我们当地办事处的机密。有什么方法可以联系你吗?此论坛没有私人消息功能。 以上来自于谷歌翻译 以下为原文 Gigi- I still have not had any success in getting the STM32 FOC lib. 3.2 Confidential from our local office. Is there some way I can contact you? This forum has no Private Messaging function. |
嗨丹尼,
对于私人消息,请转到 [DEAD LINK /public/STe2ecommunities/mcu/Lists/motor_control/AllItems.aspx]https://my.st.com/public/STe2ecommunities/mcu/Lists/motor_control/AllItems.aspx,点击'联系主持人'并让我们知道谁是您当地的ST联系人。 我们会尽快处理您的请求。请注意,您需要签署机密分发的固件许可证,而网站发布现已在ST网站上提供@ http://www.st.com/internet/com/SOFTWARE_RESOURCES/SW_COMPONENT/FIRMWARE/stm32_pmsm_foc_motorcontrol_fwlib.zip 新版ST MC Workbench(与目标MC应用程序的配置和通信)也可用@ http://www.st.com/internet/com/SOFTWARE_RESOURCES/TOOL/CONFIGURATION_UTILITY/motorcontrol_workbench.zip 最好的祝福, Billino 以上来自于谷歌翻译 以下为原文 Hi Danny, For private messaging, please go to [DEAD LINK /public/STe2ecommunities/mcu/Lists/motor_control/AllItems.aspx]https://my.st.com/public/STe2ecommunities/mcu/Lists/motor_control/AllItems.aspx, click on 'Contact moderator' and let us know who is your ST local contact. We'll try to process your request as soon as possible. Be aware you will be required to sign a firmware license for the confidential distribution while web distribution is now available on ST website @ http://www.st.com/internet/com/SOFTWARE_RESOURCES/SW_COMPONENT/FIRMWARE/stm32_pmsm_foc_motorcontrol_fwlib.zip New release of ST MC Workbench (configuration and communication with target MC application) is also available @ http://www.st.com/internet/com/SOFTWARE_RESOURCES/TOOL/CONFIGURATION_UTILITY/motorcontrol_workbench.zip Best Regards, Billino |
Gigi-
您关于可用的机密版本的帖子刚刚从论坛中删除 - 这是有原因的,还是在发布3.2 Web Distribution版本时意外删除了?由于Web Distribution与Confidential不同,这不是对相同信息的更新,但我可以看到如何将其意外地作为“粘性”帖子的替代。 以上来自于谷歌翻译 以下为原文 Gigi- Your post about the Confidential release being available was just deleted entirely from the forum- is there a reason for this, or was this accidentally removed when the 3.2 Web Distribution release was posted? As the Web Distribution is not the same as the Confidential, this is not an update to the same information, but I could see how that could be accidentally done as a replacement for the ''sticky'' post. |
嗨米勒,
事实上,关于网络分发的“粘性”帖子旨在取代与机密分发相关的帖子,因为这是一个公共论坛,因此网络分发可以更好地适应...... 顺便说一下,你的评论是有效的,关于'机密'的帖子不一定要删除......所以值得一提的是,机密分发也可以联系离你最近的ST办公室。请参阅Web分发信息以了解“Web”和“机密”分发之间的差异。 最好的祝福, Billino 以上来自于谷歌翻译 以下为原文 Hi Miller, indeed the ''sticky'' post about web distribution was intended to replace the one related to confidential distribution beacuse this is a public forum so web distribution could better fit... By the way, your comment is valid, post about 'Confidential' wouldn't have to be deleted... So it is worth to mention again that confidential distribution is also available contacting your nearest ST office. Refer to web distribution information to know about the differences between 'Web' and 'Confidential' distribution. Best Regards, Billino |
2801 浏览 1 评论
3258 浏览 1 评论
1832 浏览 1 评论
3684 浏览 6 评论
6082 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
384浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
475浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
303浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
224浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
328浏览 2评论
GMT+8, 2025-1-25 06:53 , Processed in 1.402636 second(s), Total 99, Slave 83 queries .
