扫一扫,分享给好友
我试图在XCTEX的CX3上使用加密算法。我在Cx3和Windows上使用了下面的代码,但是当使用NUMINSCONE 64、V [2 ]=0x264DCC860、0x3E0DA966}和KEY={0x12345 67 8、0x12345 67 8、0x12345 67 8、0x12345 67 8}时,得到不同的结果。
空洞破译(const siZeZT NUMITSCONTS,UIT32 32 V V〔2〕,UIT32 32 t const键〔4〕) { SIZE指数; UIT32 32 t V0=V〔0〕; UIT32 32 V1=V〔1〕; UNIT32 32δ=0x9E37 79B9; UtiT32×t和=Δ*NUMFIN回合; (index=0u;index & lt;nUnthSnand;索引++) { V1- =((v0&lt;lt;4)^(v0&gt;& 5;)+v0)^(和+键[(和gt;& gt;11)&0x3]); V0- =((V1&lt;lt;4)^(v1&gt;5))+V1)^(求和+密钥[和和0x3]); } V〔0〕=V0; V〔1〕=V1; } 解密的数据应该返回0,但不在CX3上。这是一个我不知道的问题还是我做错了什么? 以上来自于百度翻译 以下为原文 I am trying to use implement an encryption algorithm on the CX3 known as XTEA. I used the following code on the CX3 and Windows, but got a different result when using 64 for Num_rounds, v[2] = {0x274DCC86, 0x3E0DA996} and key={0x12345678, 0x12345678, 0x12345678, 0x12345678}. void decipher(const size_t Num_rounds, uint32_t v[2], uint32_t const key[4]) { size_t index; uint32_t v0 = v[0]; uint32_t v1 = v[1]; const uint32_t Delta = 0x9E3779B9; uint32_t sum = Delta * Num_rounds; for (index = 0U; index < Num_rounds; index++) { v1 -= (((v0 << 4) ^ (v0 >> 5)) + v0) ^ (sum + key[(sum>>11) & 0x3]); v0 -= (((v1 << 4) ^ (v1 >> 5)) + v1) ^ (sum + key[sum & 0x3]); } v[0]=v0; v[1]=v1; } The deciphered data should return 0, but doesn't on CX3. Is this a known issue I don't know about or am I doing something wrong? |
你好,
请使用已知的一组值,并使用调试打印一步一步检查,以查看计算不匹配发生的位置。因此,我们可以得出一个关于这种差异的原因的想法。 当做, - Madhu Sudhan 以上来自于百度翻译 以下为原文 Hi, Please take a known set of values and check step by step using debug prints to see where the calculation mismatch happens. Thereby, we can come to an idea about the cause of this difference. Regards, - Madhu Sudhan |
756个成员聚集在这个小组
加入小组2124 浏览 1 评论
1866 浏览 1 评论
3682 浏览 1 评论
1802 浏览 6 评论
1549 浏览 1 评论
613浏览 2评论
456浏览 2评论
451浏览 2评论
403浏览 2评论
1089浏览 2评论
GMT+8, 2025-1-13 19:27 , Processed in 0.934643 second(s), Total 75, Slave 59 queries .
