设备:16F1824编译器:XC8V1.45 ID:XV4.01问题:I2C通信有时工作I2C配置代码:这是我的I2C代码:这是主代码。C:有时命令命令失败标志被设置,有时命令Debug失败标志被清除,我需要家伙检查我的I2C流来检查这是不是如果上述代码是正确的:从属芯片的ADC每秒扫描数据(电压、电流等),将这些数据存储到EEPROM寄存器中,然后将操作寄存器映射到EEPROM寄存器中,只有I2C可以通信的是操作寄存器。在芯片向操作寄存器中更新数据时,从芯片是否可能对主响应?非常感谢!谢谢您。
以上来自于百度翻译 以下为原文 device: 16F1824 compiler: XC8 v1.45 IDE: X v4.01 PROBLEM: I2C communication SOMETIMES works The I2C configuration code: SSPADD = 0x0a; // clock frequency of SLK = Fosc/(SSPADD+1)*4 = 100KHz have error, tuning it to 80Khz SSP1STATbits.CKE = 1; // SMBus compatible SSP1CON = 0b00101000; // bit 7: WCOL = 0 // bit 6: SSPOV = 0 Receive Overflow Indicator bit // bit 5: SSPEN = 1 // bit 4: CKP no use in I2C master mode // bit 3-0: 1000 = I2C Master mode, clock = FOSC/(4 * (SSP1ADD+1))(4) SSP1CON3 = 0b01110000; // bit 7: ACKTIM 0 = Not an Acknowledge sequence, cleared on 9TH rising edge of SCL clock // bit 6: PCIE 1 = Enable interrupt on detection of Stop condition // bit 5: SCIE 1 = Enable interrupt on detection of Start or Restart conditions // bit 4: BOEN This bit is ignored in I2C master mode // bit 3: SDAHT (I don't know what this do) // bit 2: SBCDE (I2C Slave mode only) // bit 1: AHEN (I2C Slave mode only) // bit 0: DHEN (I2C Slave mode only) This is my I2C code: bit I2C_Start(void) { while ( ( SSPCON2 & 0x1F ) || ( R_nW ) ); // Idle? SSP1CON2bits.SEN = 1; // Initial start condition while (SSP1CON2bits.SEN != 0); if (PIR2bits.BCL1IF == 1){ PIR2bits.BCL1IF = 0; return FAILURE; } else{ PIR1bits.SSP1IF = 0; return SUCCESS; } } bit I2C_RepeatedStart(void) { while ( ( SSPCON2 & 0x1F ) || ( R_nW ) ); // Idle? SSPCON2bits.RSEN = 1; while (SSP1CON2bits.RSEN != 0); if (PIR2bits.BCL1IF == 1){ PIR2bits.BCL1IF = 0; return FAILURE; } else{ PIR1bits.SSP1IF = 0; return SUCCESS; } } bit I2C_SendAddress(const unsigned char address) { while ( ( SSPCON2 & 0x1F ) || ( R_nW ) ); // Idle? SSP1BUF=address; if(SSP1CON2bits.ACKSTAT == 1){ //slave沒回應 return FAILURE; } else{ if(PIR2bits.BCL1IF == 1){ PIR2bits.BCL1IF == 0; return FAILURE; } else return SUCCESS; } } unsigned char I2C_Receive(void) { while ( ( SSPCON2 & 0x1F ) || ( R_nW ) ); // Idle? SSP1CON2bits.RCEN = 1; // 1 = Enables Receive mode for I2C while(SSP1CON2bits.RCEN != 0); PIR1bits.SSP1IF = 0; return SSP1BUF; } bit I2C_AckSequence(unsigned char AckOrNack) { while ( ( SSPCON2 & 0x1F ) || ( R_nW ) ); // Idle? SSPCON2bits.ACKDT = AckOrNack; //Ack = 0, Nack = 1 SSPCON2bits.ACKEN = 1; // tell slave while(SSPCON2bits.ACKEN != 0); if(PIR2bits.BCL1IF == 1){ return FAILURE; } else{ PIR1bits.SSP1IF = 0; return SUCCESS; } } bit I2C_Stop(void) { while ( ( SSPCON2 & 0x1F ) || ( R_nW ) ); // Idle? SSP1CON2bits.PEN = 1; while(SSP1CON2bits.PEN != 0); if (PIR2bits.BCL1IF == 1){ return FAILURE; } else{ PIR1bits.SSP1IF = 0; return SUCCESS; } } This is code in main.c: if( I2C_Start() == FAILURE ) I2C_FLAGbits.START_FAILURE = 1; else I2C_FLAGbits.START_FAILURE = 0; if( I2C_SendAddress(OZ8920_W) == FAILURE ) I2C_FLAGbits.SLAVE_W_FAILURE = 1; else I2C_FLAGbits.SLAVE_W_FAILURE = 0; if( I2C_SendAddress(VOLTAGE) == FAILURE ) I2C_FLAGbits.COMMAND_FAILURE = 1; else I2C_FLAGbits.COMMAND_FAILURE = 0; if( I2C_RepeatedStart() == FAILURE ) I2C_FLAGbits.REPEATED_FAILURE = 1; else I2C_FLAGbits.REPEATED_FAILURE = 0; if( I2C_SendAddress(OZ8920_R) == FAILURE ) I2C_FLAGbits.SLAVE_R_FAILURE = 1; else I2C_FLAGbits.SLAVE_R_FAILURE = 0; Sometimes COMMAND_FAILURE flag is set, sometimes COMMAND_FAILURE flag is cleared, I need guys to examine my I2C flow to check whether this is wrong or not. IF the code above all are right: The slave chip's ADC scan data(voltage, current etc) every second and store these data into EEPROM register, and then Operation register is mapped into EEPROM register. Only thing I2C can communicate is operation register. Is it possible that the slave chip doesn't response to master during the chip is updating data into Operation Register? Very appreciate it! Thank you. |
解决了从芯片复位I2C通信中断太多的问题
以上来自于百度翻译 以下为原文 Problem solved. Too many interrupt result in slave's chip resetting I2C communication |
5362 浏览 9 评论
2093 浏览 8 评论
1995 浏览 10 评论
3274 浏览 3 评论
2306 浏览 5 评论
870浏览 1评论
758浏览 1评论
699浏览 1评论
750浏览 0评论
644浏览 0评论
GMT+8, 2025-2-25 01:23 , Processed in 1.175517 second(s), Total 78, Slave 60 queries .
