我有一个PIC32起动器套件,带有PIC32 MZ2048 EFH144和PIC32 DA家族启动套件,带有PIC32 MZ2064 DAA28 8。它们是用我用过的USB电缆来编程的。我也可以使用这些电缆进行调试吗?我无法调试工作。我能用USB电缆进行调试吗?或者我需要另一个电缆/设备吗?我有一个PACtiT3,我用8/16位设备,但我不认为它会连接。调试时最便宜的设备是什么?是否有能够用USB进行调试的设置?提前感谢。
以上来自于百度翻译 以下为原文 I have a PIC32 Starter Kit with a PIC32MZ2048EFH144 and PIC32 DA Family Starter Kit with a PIC32MZ2064DAA288. They came with USB cables that I've been using to program them. Can I use these cables to debug also? I haven't been able to get the debugging working. Can I do debugging with the USB cables or do I need another cable/device? I have a PICKIT3 that I used for 8/16-bit devices, but I don't think it'll connect. What's the cheapest device I would need to do debugging? Are there settings to be able to debug with USB? Thanks in advance. |
4个回答
WW1.MICCHIP.COM/DeLoSt/En/DeVICECD/O7000 05311A.PDF
以上来自于百度翻译 以下为原文 ww1.microchip.com/downloads/en/DeviceDoc/70005311A.pdf |
请参阅UG第16页。使用USB MIC-B连接器进行车载调试器(J19)
以上来自于百度翻译 以下为原文 See page 16 of the UG. Use USB Micro-B connector for on-board debugger (J19) |
谢谢你的信息,但是当我拿到起动器套件时,我已经读完了那份文件。还有一些错误信息:2.1.4“当安装JP17跳线时,引脚1必须连接到引脚3,引脚2必须连接到引脚4。”它正确地说明如何在第38页上安装跳线。不管怎样,当我尝试时,调试器不能正常工作。我设置了断点,我知道PIC已经停止(通过我的代码中的LED指示),但是调试器从来没有说过它在断点处停止了!如果我暂停PIC,它永远不会告诉我它停在哪里,我不能读取任何实际的变量值。我做错什么了?在我的PrimaMac配置中有什么不对吗?
以上来自于百度翻译 以下为原文 Thanks for the info, but I've read through that document when I got the Starter Kit. There's also some wrong information: 2.1.4 "When the JP17 jumper is installed, pin 1 must be connected to pin 3, and pin 2 must be connected to pin 4." is wrong. It correctly states how to install the jumper on page 38. Anyway, the debugger won't work right when I try it. I set a breakpoint and I know that the PIC has stopped (by LED indications from my code), but the debugger never says that it stopped at the breakpoint! If I pause the PIC, it never tells me where it stopped and I can't read any actual variable values. What am I doing wrong? Do I have something wrong in my #pragma configs? /*** DEVCFG0 ***/ #pragma config DEBUG = ON // Background Debugger Enable (Debugger is enabled) #pragma config JTAGEN = OFF // JTAG Enable (JTAG Disabled) #pragma config ICESEL = ICS_PGx2 // ICE/ICD Comm Channel Select (Communicate on PGEC2/PGED2) - 2 allows debugging #pragma config TRCEN = OFF // Trace Enable (Trace features in the CPU are disabled) #pragma config BOOTISA = MIPS32 // Boot ISA Selection (Boot code and Exception code is MIPS32) #pragma config FECCCON = OFF_UNLOCKED // Dynamic Flash ECC Configuration (ECC and Dynamic ECC are disabled (ECCCON bits are writable)) #pragma config FSLEEP = OFF // Flash Sleep Mode (Flash is powered down when the device is in Sleep mode) #pragma config DBGPER = PG_ALL // Debug Mode CPU Access Permission (Allow CPU access to all permission regions) #pragma config SMCLR = MCLR_NORM // Soft Master Clear Enable bit (MCLR pin generates a normal system Reset) #pragma config SOSCGAIN = GAIN_2X // Secondary Oscillator Gain Control bits (2x gain setting) #pragma config SOSCBOOST = ON // Secondary Oscillator Boost Kick Start Enable bit (Boost the kick start of the oscillator) #pragma config POSCGAIN = GAIN_2X // Primary Oscillator Gain Control bits (2x gain setting) #pragma config POSCBOOST = ON // Primary Oscillator Boost Kick Start Enable bit (Boost the kick start of the oscillator) #pragma config EJTAGBEN = NORMAL // EJTAG Boot (Normal EJTAG functionality) #pragma config CP = OFF // Code Protect (Protection Disabled) /*** DEVCFG1 ***/ #pragma config FNOSC = SPLL // Oscillator Selection Bits (System PLL) #pragma config DMTINTV = WIN_127_128 // DMT Count Window Interval (Window/Interval value is 127/128 counter value) #pragma config FSOSCEN = ON // Secondary Oscillator Enable (Enable SOSC) #pragma config IESO = ON // Internal/External Switch Over (Enabled) #pragma config POSCMOD = EC // Primary Oscillator Configuration (External clock mode) #pragma config OSCIOFNC = OFF // CLKO Output Signal Active on the OSCO Pin (Disabled) #pragma config FCKSM = CSECME // Clock Switching and Monitor Selection (Clock Switch Disabled, FSCM Disabled) #pragma config WDTPS = PS1048576 // Watchdog Timer Postscaler (1:1048576) #pragma config WDTSPGM = STOP // Watchdog Timer Stop During Flash Programming (WDT stops during Flash programming) #pragma config FWDTEN = OFF // Watchdog Timer Enable (WDT Disabled) #pragma config WINDIS = NORMAL // Watchdog Timer Window Mode (Watchdog Timer is in non-Window mode) #pragma config FWDTWINSZ = WINSZ_25 // Watchdog Timer Window Size (Window size is 25%) #pragma config DMTCNT = DMT31 // Deadman Timer Count Selection (2^31 (2147483648)) #pragma config FDMTEN = OFF // Deadman Timer Enable (Deadman Timer is disabled) /*** DEVCFG2 ***/ // Clock frequency is 24MHz, driven by either an oscillator or a crystal. // The 24MHz input will divided by the setting of FPLLIDIV (3). // Set FPLLRNG to match the range of the divided frequency (5-10MHz). // The divided input will be multiplied by the FPLLMULT setting (50). // The final system clock value is the result of division by FPLLODIV (2). // // System clock formula: // // Fsys = Posc / FPLLIDIV x FPLLMULT / FPLLODIV // #pragma config FPLLIDIV = DIV_3 // System PLL Input Divider (3x Divider) #pragma config FPLLRNG = RANGE_5_10_MHZ // System PLL Input Range (5-10 MHz Input) #pragma config FPLLICLK = PLL_POSC // System PLL Input Clock Selection (POSC is input to the System PLL) #pragma config FPLLMULT = MUL_50 // System PLL Multiplier (PLL Multiply by 50) #pragma config FPLLODIV = DIV_2 // System PLL Output Clock Divider (2x Divider) #pragma config VBATBOREN = ON // Enable ZPBOR during VBAT Mode #pragma config DSBOREN = ON // Enable ZPBOR during Deep Sleep Mode #pragma config DSWDTPS = DSPS32 // Deep Sleep Watchdog Timer Postscaler 1:2^36 #pragma config DSWDTOSC = LPRC // Select LPRC as DSWDT Reference clock #pragma config DSWDTEN = OFF // Disable DSWDT during Deep Sleep Mode #pragma config FDSEN = ON // Disable DSEN bit in DSCON #pragma config UPLLFSEL = FREQ_24MHZ // USB PLL Input Frequency Selection (USB PLL input is 24 MHz) /*** DEVCFG3 ***/ #pragma config USERID = 0xffff // Set the User ID (0x0 to 0xffff) #pragma config EXTDDRSIZE = DDR_SIZE_128MB // External DDR2 Size is 128 MB #pragma config FMIIEN = OFF // Ethernet RMII/MII Enable (RMII Enabled) #pragma config FETHIO = ON // Ethernet I/O Pin Select (Alternate Ethernet I/O) #pragma config PGL1WAY = OFF // Permission Group Lock One Way Configuration (Allow multiple reconfigurations) #pragma config PMDL1WAY = OFF // Peripheral Module Disable Configuration (Allow multiple reconfigurations) #pragma config IOL1WAY = OFF // Peripheral Pin Select Configuration (Allow multiple reconfigurations) /*** DEVCFG4 ***/ #pragma config SWDTPS = SPS1048576 // Sleep Mode Watchdog Timer Postscaler /*** BF1SEQ0 ***/ #pragma config TSEQ = 0x0000 // Boot Flash True Sequence Number #pragma config CSEQ = 0xffff // Boot Flash Complement Sequence Number |
解决了这个问题!我不得不评论一些代码:我不知道为什么我会在那里,它可能已经被遗留下来的其他项目需要使用这些引脚。
以上来自于百度翻译 以下为原文 SOLVED Found the solution! I had to comment out some code: // Disable JTAG control of outputs //CFGCONbits.JTAGEN = 0; //CFGCONbits.TDOEN = 0; //CFGCONbits.TROEN = 0; I don't know why I had this in there, it may have been left over from some other project that needed to use these pins. |
5145 浏览 9 评论
1993 浏览 8 评论
1921 浏览 10 评论
3162 浏览 3 评论
2218 浏览 5 评论
713浏览 1评论
601浏览 1评论
484浏览 1评论
613浏览 0评论
512浏览 0评论
GMT+8, 2024-11-11 01:42 , Processed in 1.367440 second(s), Total 81, Slave 65 queries .
