ISE工具的首选项应存储在以下为原文
The preferences for ISE tools should be stored in the
If that file is not found or cannot be written to, the default preferences will always be used.
我对ISE Webpack 13.3和14.4版本有一个恼人的问题。
我试图在不同的目录下以超级用户和普通用户的身份安装它们(我在安装后使用“settings32.sh”配置了环境变量)。 我的问题是我不能让ISE记住我在一次会议期间选择的任何偏好。 例如,在启动时,我选择我不希望看到“提示窗口”,但是当我退出ISE然后返回“提示窗口”时会再次弹出。 我的环境是:Ubuntu Linux 12.04 我很感激能得到的一切帮助! 以上来自于谷歌翻译 以下为原文 I have an annoying problem with ISE Webpack 13.3 and 14.4 versions. I've tried to install them both as a super-user and as a regular user, under different directories (and I've configured environment variables with "settings32.sh" after the installation). My problem is that I can't make ISE to remember any of my preferences I sellect during one session. For example, when started-up I pick that I don't wish to see "tips window", but when I exit the ISE and then return back "tips window" pops up again. My environment is: Ubuntu Linux 12.04 I'm grateful for every help I can get! |
嗨,
单击编辑 - >首选项以更改首选项。 例如,如果要在ISE文本编辑器和ISE常规两个类别中进行更改。 首先选择一个类别并更改首选项,然后单击“应用”。 然后选择第二个类别,进行所需的修改,然后单击“应用”。 谢谢。 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Click on Edit --> Preferences to change the preferences. For example, If you want to make changes in two categories like ISE Text Editor and ISE General. First select one category and change the preferences and click on apply. Then select the second category, make the modifications required and then click on apply. Thanks. -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
ISE工具的首选项应存储在以下为原文 The preferences for ISE tools should be stored in the If that file is not found or cannot be written to, the default preferences will always be used. |
2306 浏览 7 评论
2716 浏览 4 评论
2197 浏览 9 评论
3278 浏览 0 评论
2351 浏览 15 评论
631浏览 1评论
1684浏览 1评论
441浏览 1评论
195浏览 1评论
652浏览 0评论
GMT+8, 2024-9-20 12:13 , Processed in 0.994501 second(s), Total 45, Slave 40 queries .
