嗨,
在为Windows(7)下载并安装了“Xilinx_ISE_DS_Win_14.4_P.49d.3.0”(Vivado和ISEDesign Suites)文件后,我获得了Xilinx许可证中的Petalinux功能,而不是预期的ISE或Webpack功能。 我做错了什么? 谢谢 埃里克 以上来自于谷歌翻译 以下为原文 Hi, After having dowloaded and installed the 'Xilinx_ISE_DS_Win_14.4_P.49d.3.0' (Vivado and ISEDesign Suites) file for Windows (7), I obtain the Petalinux feature in the Xilinx Licenses and not the ISE or Webpack feature as expected. What have I done wrong? Thanks Eric |
喜
某些评估板有一些BSP可以从xilinx网站下载.http://www.xilinx.com/support/download/index.htm 如果您将这些BSP安装到petalinux,则会在其BSP安装目录中为每个板安装预先构建的映像。 有链接使用这些演示的指南:http://www.xilinx.com/support/download/index.htm 问候, saurav 以上来自于谷歌翻译 以下为原文 hi, There is some BSPs for some evaluation board that can be downloaded from xilinx website. http://www.xilinx.com/support/download/index.htm If you installed these BSPs to petalinux, there will be pre-built image for each board in their BSP installed directory.There is guide to use these demos at link : http://www.xilinx.com/support/download/index.htm regards,saurav |
返回www.xilinx.com getlicense,您应该能够选择webpack许可证并生成它。
如果您已经生成了webpack许可证,请转到管理许可证文件选项卡并选择webpack许可证,然后在左下方窗口中选择下载选项。 以上来自于谷歌翻译 以下为原文 Go back to www.xilinx.comgetlicense and you should be able to select the webpack license and generate it as well. If you have already generated a webpack license, go the the manage license files tab and select the webpack license then select the download option in bottom left side window. |
2420 浏览 7 评论
2823 浏览 4 评论
2294 浏览 9 评论
3374 浏览 0 评论
2461 浏览 15 评论
1175浏览 1评论
587浏览 1评论
451浏览 1评论
2005浏览 0评论
731浏览 0评论
GMT+8, 2024-12-23 19:27 , Processed in 1.632950 second(s), Total 78, Slave 62 queries .
