嗨,我们如何针对服务器进行此修复。
我们使用的是Win2003标准,Win2003 R2和Win2008标准64位。 是否有运行和检查漏洞中的实用工具? 修补错误的固件将是灾难。 最好的祝福, 以上来自于谷歌翻译 以下为原文 Hi, How do we go about this fix for the servers. We are using Win2003 standard, Win2003 R2 and Win2008 standard 64 bit. Is there a utility tools to run and check that are in the vulnerability ? Patching the wrong firmware will be disaster. Best regards, |
您好Bombshell,您需要与系统制造商联系以获取BIOS更新,其中包含可以缓解此问题的微代码版本。
如果您的服务器来自英特尔(与戴尔,惠普等),那么您可以在此处找到相关信息:https://www.intel.com/content/www/us/en/support/articles/000028721/server-products。 html您还需要与Microsoft联系以获取服务器的安全补丁。没有一个超级简单的工具可以告诉您系统是否容易受到攻击,但Microsoft的这个页面有关于使用PowerShell确定系统是否是 易受攻击:https://support.microsoft.com/en-us/help/4072698/windows-server-guidance-to-protect-against-the-speculative-execution(此页面还提供了有关缓解侧漏洞漏洞的信息 今年早些时候)您可能还会发现此页面很有用:https://support.microsoft.com/en-us/help/4457951/windows-server-guidance-to-protect-against-l1-terminal-fault让我们知道是否 你还有其他问题。 以上来自于谷歌翻译 以下为原文 Hi Bombshell, You will need to check with the manufacturer of your systems to obtain a BIOS update that includes the microcode versions that mitigate this issue. If your servers are from Intel (vs. Dell, HP etc.) then you can find information here: https://www.intel.com/content/www/us/en/support/articles/000028721/server-products.html You will also need to check with Microsoft to obtain the security patches for your servers. There is not a super easy tool that can tell you if a system is vulnerable, but this page from Microsoft has details on using PowerShell to determine if a system is vulnerable: https://support.microsoft.com/en-us/help/4072698/windows-server-guidance-to-protect-against-the-speculative-execution (this page also has information on mitigating side-channel vulnerabilities disclosed earlier this year) You might also find this page useful: https://support.microsoft.com/en-us/help/4457951/windows-server-guidance-to-protect-against-l1-terminal-fault Let us know if you have additional questions on this. |
551浏览 0评论
GMT+8, 2025-1-25 03:24 , Processed in 0.399998 second(s), Total 66, Slave 60 queries .
