最近购买了Razer Stargazer,现在才意识到这些产品已经得到了很多支持。
让相机正常工作,在xsplit和所有其他程序中工作得很好但是,位于OBS的intel真实插件无法正常工作.https://gyazo.com/4132ea0c25daa38f5cbbdc7d65c31bb8 屏幕截图 - 4132ea0c25daa38f5cbbdc7d65c31bb8 - Gyazo 我联系过OBS,他们告诉我个人问你们英特尔,因为你们显然为他们编写了这个插件并且他们不知道。 同样令人沮丧的是,发现intels网站上列出的很多程序都是404错误,不再支持intel realsense。 Razer似乎已经完全否认了这个产品,将其从网站上删除并且没有回复支持票。 所以,如果您不知道为什么OBS可能会失败,您可能会推荐一个支持intels realsense的应用程序或程序,以便它可以与OBS一起使用。 正如香港专业教育学院所说,xsplit真实相机工作正常,但我讨厌xsplit,更多的是OBS粉丝,所以是的。 请帮帮我 以上来自于谷歌翻译 以下为原文 Recently purchased the Razer Stargazer and just realising now that there isnt much support anymore for these sorts of products. Got the camera working in general, the realsense is working fine in xsplit and all other programs however, the intel real-sense plugin located in OBS fails to function.https://gyazo.com/4132ea0c25daa38f5cbbdc7d65c31bb8 Screen capture - 4132ea0c25daa38f5cbbdc7d65c31bb8 - Gyazo Ive contacted OBS, they told me to personally ask you guys at intel as you apparently coded the plugin for them and they have no idea. Its also slightly frustrating to find that a lot of the programs listed on intels website are all 404 errors and no longer support intel realsense. Razer seems to have fully disowned this product by removing it from their website and failing to reply to support tickets. So, if you dont know why OBS might be failing could you perhaps recommend a application or program that will support intels realsense so it will work with OBS. As ive said, xsplit the realsense camera works fine but i hate xsplit and am more of an OBS Fan, so yea. Help me please |
11个回答
Razer Stargazer通常适用于与SR300配合使用的应用程序。
然而,Razer确实在OBS的绿屏功能方面存在问题。 https://obsproject.com/forum/threads/stargazer-realsense-green-screen-not-working.65913/ 下面链接的文章建议如何使用任何相机而不是RealSense软件专门在OBS中进行绿屏。 https://www.windowscentral.com/how-use-green-screen-obs-and-xsplit SR300现在已经退役,虽然它继续在这个帮助论坛上得到威廉希尔官方网站 建议(尽管不是新的驱动程序更新)的支持,就像之前的所有RealSense型号一样。 SR300与当前的RealSense SDK 2.0软件兼容。 发布·IntelRealSense / librealsense·GitHub 以上来自于谷歌翻译 以下为原文 The Razer Stargazer usually works fine with applications that work with SR300. However, the Razer does seem to have problems with OBS' green-screen function. https://obsproject.com/forum/threads/stargazer-realsense-green-screen-not-working.65913/ The article linked below suggests how to green-screen in OBS using any camera, rather than the RealSense software specifically. https://www.windowscentral.com/how-use-green-screen-obs-and-xsplit SR300 is now a retired product, though it continues to be supported on this help forum with tech advice (though not new driver updates), as are all previous RealSense models. SR300 is compatible with the current RealSense SDK 2.0 software. Releases · IntelRealSense/librealsense · GitHub |
cmh13 发表于 2018-12-3 07:16 我有点困惑。 你说你想避免在OBS中使用绿屏,但是你从菜单中选择了绿屏选项。 如果您只想要RGB视频,可以使用Display Capture或Video Capture Device等选项。 以上来自于谷歌翻译 以下为原文 I am a little confused. You said that you wanted to avoid using green-screen in OBS, but you are selecting the green-screen option from the menu. If you just want the RGB video, an option such as Display Capture or Video Capture Device might work better. |
nywerwer 发表于 2018-12-3 07:33 我不知道过去与涉及Razer Stargazer的SR300兼容应用程序不兼容的情况。 它通常作为SR300相机完全可靠。 如果您刚购买了Razer,可以尝试使用SR300深度相机管理器程序将驱动程序和相机的内部“固件”更新为可用的最终版本。 可以使用以下链接在浏览器中下载深度摄像机管理器程序。 https://downloadmirror.intel.com/25044/eng/intel_rs_dcm_sr300_3.3.27.5718.exe 以上来自于谷歌翻译 以下为原文 I'm not aware of any past cases of incompatibilities with SR300-compatible applications that involve the Razer Stargazer. It has usually been fully reliable as an SR300 camera. If you have just bought your Razer, you could try using the SR300 Depth Camera Manager program to update the drivers and the camera's internal 'firmware' to the final version that was available. The Depth Camera Manager program can be downloaded in your browser using the link below. https://downloadmirror.intel.com/25044/eng/intel_rs_dcm_sr300_3.3.27.5718.exe |
nywerwer 发表于 2018-12-3 07:43 你知道我可以使用intel realsense删除背景的任何应用程序吗? 类似于CatchEye3D的东西虽然不再是一件事。 以上来自于谷歌翻译 以下为原文 Do you know any applications that I can use to just remove the background using the intel realsense? Something similar to CatchEye3D That is not longer a thing though. |
用于为RealSense开发应用程序的“RealSense SDK 2016 R2”软件包具有预制的SR300示例应用程序,可以作为普通程序启动而无需进行任何编程。 它被称为3D分割。 2016 R2 SDK软件可以在您的浏览器中以1.8 gb的速度下载,链接如下。 http://registrationcenter-download.intel.com/akdlm/irc_nas/vcp/9078/intel_rs_sdk_offline_package_10.0.26.0396.exe 安装完成后,它会在您的PC桌面上放置一个名为Intel RealSense SDK Gold的文件夹。 其中有一个名为“Sample Browser”的程序,可用于浏览示例程序。 如果您在浏览器的搜索框中输入“细分”一词,那么您可以快速找到它。 该程序有两个版本,'C ++'和'C#'。 其中一个应该适合你。 以上来自于谷歌翻译 以下为原文 The 'RealSense SDK 2016 R2' software package that is used to develop applications for RealSense has a pre-made SR300 sample application that can be launched as a normal program without doing any programming. It is called 3D Segmentation. The 2016 R2 SDK software can be launched in your browser as a 1.8 gb download with the link below. http://registrationcenter-download.intel.com/akdlm/irc_nas/vcp/9078/intel_rs_sdk_offline_package_10.0.26.0396.exe When installation is completed, it will have placed a folder on your PC desktop called Intel RealSense SDK Gold. within this is a program called 'Sample Browser' that can be used to browse through the sample programs. If you enter the word 'segmentation' into the search box of the browser then you can find it rapidly. There are two versions of the program, 'C++' and 'C#'. One of those should work for you. |
您可以使用分段程序的实时模式实时生成背景删除,并在OBS中使用“窗口捕获”选项将窗口的实时内容流式传输到OBS视图中。 您可以通过仅定义要捕获的窗口的视频区域来删除分段窗口的选项侧面板部分。 以上来自于谷歌翻译 以下为原文 You could use the segmentation program's Live mode to generate the background removal in real-time, and in OBS use the Window Capture option to stream the window's live contents into your OBS view. You could probably remove the options side-panel part of the segmentation window by defining only the video area of the window to be captured. |
nywerwer 发表于 2018-12-3 08:31 所以基本上我运行它然而每当你启用相机它只是冻结并禁用分割:屏幕截图 - a6cc681a91abf20cf6e82453450d9c87 - Gyazo 以上来自于谷歌翻译 以下为原文 So basically i have it running however whenever you enable the camera it just freezes and disables the segmentation: Screen capture - a6cc681a91abf20cf6e82453450d9c87 - Gyazo |
nywerwer 发表于 2018-12-3 08:31 除非你在谈论像这样使用它.... https://gyazo.com/03ff6be88d09a1d44c7934818e972d49 我认为这是在流媒体时这样做的不道德的方式 以上来自于谷歌翻译 以下为原文 Unless you were talking about using it like this.... https://gyazo.com/03ff6be88d09a1d44c7934818e972d49 I think thats unethical way of doing it when streaming though |
cmh13 发表于 2018-12-3 08:49 我的意思是通过设置红线边框来捕捉灰色区域并排除界面的选项部分,如图所示。 以上来自于谷歌翻译 以下为原文 I meant just capturing the grey area and excluding the options part of the interface by setting the red line borders, as your image illustrated.. |
GMT+8, 2025-2-23 21:37 , Processed in 0.684663 second(s), Total 86, Slave 79 queries .
