嗨,我必须衡量我的LC的真实部分。
我的目标是确定LC的负载电阻,然后我可以为源(匹配)采用相同的值。 我的电压源是馈电。 我的问题是:我的电压源阻力是多少? 我不想平行测量LC的电阻和电压源的电阻...在此先感谢最好的问候BS 以上来自于谷歌翻译 以下为原文 Hi, I have to measure the real part of my LC. My goal is to determine the load resistance of the LC then i can take this same value for the source (matching). My voltage source is a feed. My question is: What for a resistance for my voltage source? I don't want to measure the resistance of the LC and the resistance of my voltage source in parallel... Thanks in advance Best regards BS |
嗨BS,你在测量螺旋线的LC吗?
如果是这样,有两种选择:1。将螺旋及其外壳放入EMPro本征模求解器中。 LC = 1 /(2πf0)^ 2,其中f0是第一谐振频率。 不需要激励。 2.如果两端未接地,则在螺旋的两端放置一个50欧姆的端口。 获得2x2 S矩阵结果。 将S矩阵变换为Y矩阵和Z矩阵。 从Y11开始你可以获得循环L.从Z11你可以得到C到地面。 根据您将螺旋解释为电路拓扑的方式,计算可能会有所不同。 由于我们将S转换为Y和Z矩阵,因此将消除激励电阻。 Martin编辑:myuan于2013年5月23日上午9:29 以上来自于谷歌翻译 以下为原文 Hi BS, Are you measuring the LC of the helix? If so there are two options: 1. Put the helix and its housing in EMPro eigenmode solver. LC = 1 / (2 pi f0)^2, where f0 is the first resonant frequency. No excitation is needed. 2. Put a 50-Ohm port at each end of the helix, if both ends are not grounded. Obtain the 2x2 S matrix result. Transform S matrix to Y matrix and Z matrix. From Y11 you could get loop L. From Z11 you could get C to ground. Depending on how you interpret the helix to a circuit topology, the calculation could be different. Since we transformed S to Y and Z matrices, the excitation resistance would be eliminated. Martin Edited by: myuan on May 23, 2013 9:29 AM |
1383 浏览 0 评论
2419 浏览 1 评论
2266 浏览 1 评论
2105 浏览 5 评论
3019 浏览 3 评论
1420浏览 1评论
827浏览 0评论
1190浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-23 19:19 , Processed in 1.353248 second(s), Total 75, Slave 59 queries .
