亲爱的先生,
我想使用GPIF 32位总线宽度在我的设计和UART调试,SPI闪存引导。但是,当使用32位GPIF时,SPI闪存信号不能被映射,因为它们与UARTARIX RX和UARTHARTX共享。 如何处理这种情况:32位宽度GPIF、UART调试和SPI闪存引导同时工作? 戴维 以上来自于百度翻译 以下为原文 Dear sir, I want to use GPIF 32bit bus width in my design and UART for debug, spi flash for booting. but it seems that SPI flash memory signals can not be mapped because they are shared with UART_RX and UART_TX when 32bit gpif is used. How to deal with this case: 32bit width gpif,uart debug and spi flash booting are working at the same time? David |
SPI接口将只用于引导期间,UART将不被使用。一旦应用固件被启动,您就可以为32位GPIF和UART配置IOMATRAIX。所以在启动后,同样的SPI线将被用于UART。 以上来自于百度翻译 以下为原文 SPI interface will be just used for booting during which the UART will not be used. Once the application firmware is booted up, you can configure the IOMatrix for 32 bit GPIF and UART. So the same SPI lines will be used for UART now after booting. |
757个成员聚集在这个小组
加入小组2147 浏览 1 评论
1890 浏览 1 评论
3714 浏览 1 评论
1824 浏览 6 评论
1570 浏览 1 评论
776浏览 2评论
530浏览 2评论
480浏览 2评论
438浏览 2评论
1134浏览 2评论
GMT+8, 2025-2-19 08:05 , Processed in 1.004195 second(s), Total 79, Slave 63 queries .
