我安装了14.4的webpack,现在我不再使用我的14.1工具和完整许可了。
在PlanAhead中,我得到了 错误:地图:258 - 尝试获取此体系结构的许可证时遇到问题。 我正在使用LM_LICENSE_FILE环境变量从服务器获取我的许可证。 这些值在我安装webpack之前没有改变。 我还使用额外的Xilinx.lic文件来添加我的部分重配置试用版。 我已在注册表中重置缓存,方法是在ISE Design Suite命令提示符下输入以下命令(开始 - >所有程序 - > Xilinx ISE Design Suite 14.1 - >附件 - > ISE Design Suite命令提示符):xlicmgr reset。 关于下一步该尝试的任何想法? 以上来自于谷歌翻译 以下为原文 I installed the webpack for 14.4, and now I cannot use my 14.1 tools with full license anymore. In PlanAhead I get ERROR:Map:258 - A problem was encountered attempting to get the license for this architecture. I am using the LM_LICENSE_FILE environment variable to obtain my licenses from a server. These values have not changed from before I installed the webpack. I do use an additional Xilinx.lic file to add my Partial Reconfiguration Trial too. I have reset the cache in the registry, by entering the following command in to the ISE Design Suite Command Prompt (Start -> All Programs ->Xilinx ISE Design Suite 14.1 -> Accessories -> ISE Design Suite Command Prompt): xlicmgr reset. Any ideas on what to try next? |
我想出了如何解决这个问题。
如果有人想知道: 我从C:/。Xilinx中删除了文件trial.lic和webpack.lic。 我的问题可能与其他问题不同,因为我还有另一个问题,我的环境变量没有正确设置,所以我不确定是什么让我以前拥有完整的许可证,但现在一切都已修复。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 I figured out how to fix this. If anybody else is wondering: I removed the files trial.lic and webpack.lic from C:/.Xilinx. My problem may be different than others since I also had another problem where my environment variable wasn't set properly, so I'm not sure exactly what enabled me to have the full licenses before, but everything is fixed now. View solution in original post |
我想出了如何解决这个问题。
如果有人想知道: 我从C:/。Xilinx中删除了文件trial.lic和webpack.lic。 我的问题可能与其他问题不同,因为我还有另一个问题,我的环境变量没有正确设置,所以我不确定是什么让我以前拥有完整的许可证,但现在一切都已修复。 以上来自于谷歌翻译 以下为原文 I figured out how to fix this. If anybody else is wondering: I removed the files trial.lic and webpack.lic from C:/.Xilinx. My problem may be different than others since I also had another problem where my environment variable wasn't set properly, so I'm not sure exactly what enabled me to have the full licenses before, but everything is fixed now. |
2429 浏览 7 评论
2831 浏览 4 评论
2298 浏览 9 评论
3378 浏览 0 评论
2468 浏览 15 评论
1357浏览 1评论
596浏览 1评论
460浏览 1评论
2013浏览 0评论
738浏览 0评论
GMT+8, 2024-12-29 01:32 , Processed in 1.504850 second(s), Total 78, Slave 62 queries .
