这是我们做的:
将ISR v14.2(Xilinx_ISE_DS_14.2_P.28xd.3.0.tar)的安装复制到CENT OS计算机。 没压缩它。 运行:sudo ./xsetup 它安装。 要初始化shell,我们会: cd /opt/Xilinx/14.2/ISE_DS source settings32.sh 导出XILINXD_LICENSE_FILE=2100@CAD-SERVER.sierraphotonics.com export LM_LICENSE_FILE='2102@CAD-SERVER.sierraphotonics.com; 2100@CAD-SERVER.sierraphotonics.com” 要运行它,我们打开VNC查看器到CENT OS计算机,打开一个终端窗口,然后运行: /opt/Xilinx/14.2/ISE_DS/ISE/bin/lin/ise& amp; 什么都没发生。 这是输出........ [dbell @ localhost lin] $ ./ise& [1] 13750 [dbell @ localhost lin] $ ps PID TTY TIME CMD 9009 pts / 6 00:00:00 bash 13411 pts / 6 00:00:00 wtxregd.ex 13751 pts / 6 00:00:00 ps [1] +完成./ise 以上来自于谷歌翻译 以下为原文 Here is what we've done: Copied installation for ISR v14.2 (Xilinx_ISE_DS_14.2_P.28xd.3.0.tar) to the CENT OS computer. Uncompressed it. run: sudo ./xsetup It installed. To init the shell, we do: cd /opt/Xilinx/14.2/ISE_DS source settings32.sh export XILINXD_LICENSE_FILE=2100@CAD-SERVER.sierraphotonics.com export LM_LICENSE_FILE='2102@CAD-SERVER.sierraphotonics.com; 2100@CAD-SERVER.sierraphotonics.com' To run it, we open VNC viewer to the CENT OS computer, open a terminal window, and run: /opt/Xilinx/14.2/ISE_DS/ISE/bin/lin/ise & Nothing happens. Here's the output........ [dbell@localhost lin]$ ./ise & [1] 13750 [dbell@localhost lin]$ ps PID TTY TIME CMD 9009 pts/6 00:00:00 bash 13411 pts/6 00:00:00 wtxregd.ex 13751 pts/6 00:00:00 ps [1]+ Done ./ise |
4个回答
问题解决了。
目标计算机是64位,但是采购settings32.sh 使用settings64.sh现在可以运行Xilinx工具。 对XILINX的推荐: 如果计算机不是32位,则增强“settingse32.sh”以警告用户。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Problem solved. Target computer is 64-bit, but was sourcing settings32.sh Using settings64.sh Xilinx tools now run. RECOMMENDATION TO XILINX: Enhance "settingse32.sh" to warn user if computer is not 32-bit. View solution in original post |
不支持此操作系统请查看此链接以获取支持的oshttp://www.xilinx.com/support/documentation/sw_manuals/xilinx14_3/irn.pdf(第36页)
以上来自于谷歌翻译 以下为原文 this os is not supported look at this link for supported os http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_3/irn.pdf (page 36) |
问题解决了。
目标计算机是64位,但是采购settings32.sh 使用settings64.sh现在可以运行Xilinx工具。 对XILINX的推荐: 如果计算机不是32位,则增强“settingse32.sh”以警告用户。 以上来自于谷歌翻译 以下为原文 Problem solved. Target computer is 64-bit, but was sourcing settings32.sh Using settings64.sh Xilinx tools now run. RECOMMENDATION TO XILINX: Enhance "settingse32.sh" to warn user if computer is not 32-bit. |
PS.Also需要运行lin64 / ise而不是lin / ise.ie./ opt / Xilinx / 14.2 / ISE_DS / ISE / bin / lin64 / ise&
以上来自于谷歌翻译 以下为原文 PS. Also needed to run lin64/ise and not lin/ise. ie. /opt/Xilinx/14.2/ISE_DS/ISE/bin/lin64/ise & |
2429 浏览 7 评论
2831 浏览 4 评论
2298 浏览 9 评论
3378 浏览 0 评论
2468 浏览 15 评论
1385浏览 1评论
596浏览 1评论
461浏览 1评论
2014浏览 0评论
738浏览 0评论
GMT+8, 2024-12-29 16:14 , Processed in 1.341004 second(s), Total 82, Slave 66 queries .
