我在64位Linux系统上更改了我的主板和我的MAC地址。
我尝试使用产品许可Web界面更新节点信息,但它经常说该主机有一个许可文件,我必须在编辑或删除该主机之前将其删除,即使我删除了该Web界面上的所有许可证。 因此,我创建了一个具有相同名称但具有新MAC地址的新节点,并成功生成了我通过邮件收到的新许可证文件。 但在我安装之后,Xilinx配置许可证管理器仍在“主机ID匹配”列中显示“否”,但“主机ID”列与网络接口卡ID完全匹配,如附图所示。 请帮助找出完全相同的主机ID不匹配的原因。 以上来自于谷歌翻译 以下为原文 I have changed my motherboard and so my MAC address on a 64-bits Linux system. I tried to update the node information using the Product Licensing web interface but it constantly say that there is a license file for that host and that I must delete it before editing or deleting this host, even after I deleted all my licenses on that web interfaces. So I created a new node with the same name but with the new MAC address and successfully generated a new license file that I received by mail. But after I installed it, the Xilinx Configuration License Manager still say "No" in the "Host Id Matches" column, but the "Host Id" column matches exactly the Network Interface Card ID, as you can see in the attached picture. Please help to find why exact same host id don't match. |
7个回答
我刚刚发现我花了很多时间试图让Xilinx Configuration License Manager满意。
即使“Host Id Matches”说“No”,使用命令: ./Vivado_HLS/2013.2/Linux_x86_64/license/lmutil lmdiag -c~ / .Xilinx / Xilinx.lic 对于所有功能,报告“这是此节点锁定许可证的正确节点”,Vivado现在发现它们是有效的。 是时候修复Xilinx Configuration License Manager中的一个错误,该错误显然不会使用与lmulti命令相同的逻辑。 以上来自于谷歌翻译 以下为原文 I just discovered that I lost my time trying to make the Xilinx Configuration License Manager happy. Even if the "Host Id Matches" say "No", using the command: ./Vivado_HLS/2013.2/Linux_x86_64/license/lmutil lmdiag -c ~/.Xilinx/Xilinx.lic Report "This is the correct node for this node-locked license" for all features and Vivado now found them valide. Time to fix a bug in the Xilinx Configuration License Manager that obviousely don't use the same logic as the lmulti command. |
嗨,您使用的是vivado 2013.2。这是vivado 2013.2中的一个已知问题。
请查看http://www.xilinx.com/support/answers/56505.html谢谢,Deepika。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Are you using vivado 2013.2.? This is a known issue in vivado 2013.2. Check this http://www.xilinx.com/support/answers/56505.html Thanks, Deepika.Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
是的我正在使用Vivado 2013.2,是的,这是同一个问题。
尝试修复其他许可证问题的新用户非常困惑。 以上来自于谷歌翻译 以下为原文 Yes I am using Vivado 2013.2, and yes this is the same issue. Very confusing for a new user that try to fix an other license problem. |
该问题在14.7 / 2013.3中得到修复,将于10月23日发布。
-------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 The issue is fixed in 14.7/2013.3, which will be released on 10/23. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
那么除了等待新版本之外,我如何在Windows中修复此问题呢?
以上来自于谷歌翻译 以下为原文 So how do I fix this in Windows, other than waiting for the new version? |
您可以使用以下命令:
lmutil lmdiag -c C: .Xilinx xilinx.lic 如描述http://www.xilinx.com/support/answers/56505.html。 以上来自于谷歌翻译 以下为原文 You can use the command: lmutil lmdiag -c C:.Xilinxxilinx.lic As described http://www.xilinx.com/support/answers/56505.html. |
bpwilliams写道:
那么除了等待新版本之外,我如何在Windows中修复此问题呢? 这只是一个显示问题,不应影响正确的许可证签出。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 bpwilliams wrote:This is just a display issue and shouldn't affect the correct checkout of the license. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2458 浏览 7 评论
2851 浏览 4 评论
2313 浏览 9 评论
3399 浏览 0 评论
2492 浏览 15 评论
1960浏览 1评论
636浏览 1评论
494浏览 1评论
2041浏览 0评论
768浏览 0评论
GMT+8, 2025-1-23 13:52 , Processed in 1.190282 second(s), Total 59, Slave 53 queries .
