使用PIC32毫米USB好奇号DMA320107PIC32 MM0256GPM064 MPLAB X4.05Windows 10 X64 MCC 3.45.1USB框架Lite V1.25.5xC32 1.44,生成OK。该代码运行并闪烁LED。USB枚举和Windows 10报告错误代码43“未知USB设备(设备描述符请求失败)”IH。AWE尝试了以前的USB版本1.25.4和1.25.3,同样的故障尝试了XC32 1.43,同样的故障编辑:添加解决。
PIC32 MyQualoStudio.Cip(178.74 KB)-下载83次 以上来自于百度翻译 以下为原文 Using PIC32MM USB Curiosity DM320107 PIC32MM0256GPM064 Mplab X 4.05 Windows 10 x64 MCC 3.45.1 USB Framework Lite v1.25.5 XC32 1.44 It generates ok. It builds ok. The code runs and blinks the leds. The USB enumerates and windows 10 reports error code 43 "Unknown USB Device (Device Descriptor Request Failed" I have tried the previous USB versions 1.25.4 and 1.25.3, same failure I tried xc32 1.43, same failure edit: add solved Attached Image(s) Attachment(s) MyConfig.zip (33.86 KB) - downloaded 85 times Pic32MmCuriosityCan.zip (178.74 KB) - downloaded 83 times |
5个回答
我改变了时钟,除法器工作了……
以上来自于百度翻译 以下为原文 I changed the clock and the divider now works...... Attached Image(s) |
是的,我还必须纠正CDC应用程序的MCC代码。我抓住了音频项目的所有设置。
以上来自于百度翻译 以下为原文 Yes, I also had to correct the MCC code for the CDC app. I grabbed all the settings from the AUDIO project. |
嘿,吉姆,以前的帖子是正确的,系统时钟需要24MHz的CPU和USB共享RAM。一些其他的提示应该帮助您的应用程序-在系统模块集自动调谐模式“使用USB主机时钟参考”,如果你计划使用FoSC为您的系统时钟-在CDCCUM端点描述符在文件“UbxDealthult.C'中将大小从0x08更改为0x0A/*端点描述符*//siZeof(UbjEppyDSC)、DSCyEP、YEP02IIN、γIN、CDCL IN ApEx大小、0x02、0x07、/*siZeof(UBS.EPU-DSC)*/UBS-描述符端点、/端点描述符αEP01IN、/ /端点地址中断、//ATun颂歌0x0a,0x00,//大小0x02,//际感谢,罗伊
以上来自于百度翻译 以下为原文 Hey Jim, The previous posts are correct, the system clock need to be 24MHz for the CPU and USB to share RAM. A couple of other tips that should help your application: - In the System Module set Auto Tuning Mode to 'Use USB Host Clock Reference' if you plan to use FOSC for your system clock - In the CDC Comm endpoint descriptor in the file 'u***_descriptors.c' change the size from 0x08 to 0x0A /* Endpoint Descriptor */ //sizeof(USB_EP_DSC),DSC_EP,_EP02_IN,_INT,CDC_INT_EP_SIZE,0x02, 0x07,/*sizeof(USB_EP_DSC)*/ USB_DESCRIPTOR_ENDPOINT, //Endpoint Descriptor _EP01_IN, //EndpointAddress _INTERRUPT, //Attributes 0x0A,0x00, //size 0x02, //Interval Thanks, Roy |
是的,请启动你自己的线程,而不是把这个旧线程重新使用。你的问题与这个老话题无关。
以上来自于百度翻译 以下为原文 Yes, Please could start your own thread, rather than bring this old thread back to life. Your question has nothing to do with this old topic. |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3106 浏览 3 评论
2177 浏览 5 评论
618浏览 1评论
495浏览 1评论
351浏览 1评论
520浏览 0评论
427浏览 0评论
GMT+8, 2024-9-22 04:08 , Processed in 1.286444 second(s), Total 86, Slave 70 queries .
