您好!
对于AD8343 S参数模型,解释如下,供您参考。 The S2P file provides differential impedance measurements. The S2P port assignments are as follows:
In most cases the 2-port data will be all you'll need to develop matching networks for the AD8343. LO port can be considered as a 50 ohm input. |
213123d 发表于 2018-11-29 07:33 您好! 请问我下面这个ADS仿真中Ref脚需要接什么? 当Ref脚悬空的时候,此时仿真出来的S(2,1)与S(1,2)的两条线的增益是重叠的。 请给予指导。 谢谢! |
213123d 发表于 2018-11-29 07:33 您好! 我现在ADS仿真中不知道如何接入二端口。请您解释一下哪个端口是输出,哪个端口是接50欧姆的电阻,还有接50欧姆电阻代替本振时,是需要接一个地还是信号源呢? 我是如下面这样接的: 仿真出来的结果是: 这样结果S(1,2)与S(2,1)的两条线的增益基本上是一样的了,请问这样有什么问题吗? 我还有一种二端口的接法如下: 其仿真出来的结果如下: 请问怎么样改进呢?由于课题时间比较紧张,请您快一点回复! 谢谢! 蒋相 桂林电子科技大学。 |
cdiwqjelidqd 发表于 2018-11-29 08:00 您好! 对于AD8343 S参数的使用产品线工程师解释如下,供您参考。 Is there any reason you chose AD8343 over its next generations: AD8342 and ADL5801? Both AD8342 and ADL5801are higher performance active mixers, and much easier to use because of their boardband characteristics. AD8343 s-parameters are provided for purposes of input/output matching, but not freqeuncy conversion simulation. If you look into the s2p file, you will see all 4 parameters were measured under the same corresponding freqeuncy. This means no freqeuncy translation was involved, or LO was zero. In this case, s12 and s21(aka gain for its magnitude) are not useful data for any mixer simulation, but s11 and s22 have valuable service for impedance matching. Once you find the proper matching for the mixer at desired band, you would need to implement the matching on a prototype board rather than relying on any simulation. Regarding the stability consideration, page 21 and 22 have the full discussion. I'm not sure if I can add anything else. Once you set up the mixer on board, you should be able to see if there is any oscillation to verify your stabilty. |
213123d 发表于 2018-11-29 08:19 您好! 非常感谢您的耐心讲解,我现在不明白的是:当实现阻抗匹配时,在ADS软件仿真时其电路怎样搭建。请您发一张有图片的例子来指导一下。 谢谢! |
213123d 发表于 2018-11-29 08:19 您好! 非常感谢您的耐心讲解,我现在不明白的是:当不考虑转换增益,要实现阻抗匹配时,在ADS软件仿真时其电路怎样搭建。请您发一张有图片的例子来指导一下。 还有就是上次您回复我说本振是用50欧姆的电阻来替代。我用的是2.4GHz的RF输入,需要350MHz的中频输出。两个不同的输入与输出的频率怎样来实现阻抗匹配呢?用微带线还是LC匹配,哪个匹配方法好呢? 谢谢! |
我也在做8434相关工作,发现RF输入匹配是个大问题,在低IF(例如3MHz)输出时发现功率太小大概-30dbm(RF和LO输入功率都是-10dbm),RF端口用的是推荐的巴伦转换电路,其s11只有-2db在430MHz,只能退而求其次在后级加入基带低噪放解决。可以联系我讨论。
张友芬1 发表于 2018-11-29 08:59 您好! 你的仿真出来了不?你是采用什么方法呢? |
您好! 对于AD8343仿真和匹配电路设计,建议您参考数据手册中第21页~第25页,其中有仿真和设计方法以及调试过程的详细介绍,供您参考。 |
此帖给我一种大学生在赶毕设的感觉。。。
2242个成员聚集在这个小组
加入小组ADP5092 SYS端口为2.09V,但是REG_OUT为0是什么原因?
1776 浏览 1 评论
4155 浏览 2 评论
8869 浏览 1 评论
3073 浏览 1 评论
7059 浏览 2 评论
1225浏览 3评论
1535浏览 2评论
1469浏览 2评论
1238浏览 1评论
1068浏览 1评论
GMT+8, 2024-9-21 00:45 , Processed in 1.121024 second(s), Total 100, Slave 84 queries .
