你好,
我在Windows 7,64位上运行Xilinx ISE 14.1。 我获得了WebPack许可证,ISE 14.1工作正常。 但是,当我打开PlanAhead 14.1时,我收到以下消息: “无法获得许可证。您的FLEXNet配置可能存在问题,或许可证服务器可能已关闭。您想要做什么?(重试,获取许可证,退出)” 如何解决此问题并运行PlanAhead? 谢谢。 以上来自于谷歌翻译 以下为原文 Hello, I am running Xilinx ISE 14.1 on Windows 7, 64 bit. I obtained a WebPack license and ISE 14.1 works fine. However, when I open PlanAhead 14.1, I get this message: "Unable to get a license. There may be a problem with your FLEXNet configuration, or your license server may be down. What would you like to do? (Retry, Get License, Exit)" How can I resolve this issue and run PlanAhead? Thanks. |
8个回答
嗨,单击以下网页中的“管理许可证”选项卡:www.xilinx.com/getlicense并查找webpack许可证。如果您以前没有生成webpack许可证,则无法在“管理许可证”选项卡中找到它
的网页。 如果是这种情况,请填写此表单与我们的客户支持部门联系:http://www.xilinx.com/askx/customer_service_form.htm以生成webpack许可证。谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, Click on "Manage Licenses" tab in the following webpage: www.xilinx.com/getlicense and look for webpack license. If you have not generated webpack license in the past, you will not find it in the "Manage License" tab of the webpage. If this is the case, contact our customer support by filling this form: http://www.xilinx.com/askx/customer_service_form.htm to generate a webpack license. Thanks-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
嗨,您可以附加机器的xinfo文件吗?K从开始 - >所有程序 - > Xilinx设计工具 - > ISE Design Suite 14.6 - >附件 - > Xinfo系统检查器生成xinfo运行xinfo。
谢谢,迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Can you attach xinfo file of your machine?K To generate xinfo run xinfo from Start --> All Programs --> Xilinx Design Tools --> ISE Design Suite 14.6 --> Accessories --> Xinfo System Checker. Thanks, Deepika.Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
嗨,
该工具未选择您的webpack许可证(xinfo文件中没有webpack许可证条目)。 试试以下: 1.打开XLCM(开始 - > ISE Desgin Suite - > Accesories - > Manage Xilinx许可证)。 2.在为XILINXD_LICENSE_FILE提供的框中输入webpack许可证的路径,例如C:/Xilinx/Xilinx.lic(如果webpack许可证位于C:/ Xilinx文件夹中)并单击set。 你可以在这里写出多条路径; 如果你有多个许可证。 3.重新打开Xilinx工具并检查许可证问题是否已解决。 如果这样做无效,请附上许可证文件。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Your webpack license is not picked by the tool (there are not entries of webpack license in the xinfo file). Try below: 1. Open XLCM (start --> ISE Desgin Suite--> Accesories --> Manage Xilinx licenses). 2. In the box provided for XILINXD_LICENSE_FILE enter the path to the webpack license say C:/Xilinx/Xilinx.lic (if the webpack license is located at C:/Xilinx folder) and click on set. You can write mutiple paths here seperated by ; in case if you have multiple licenses. 3. Reopen the Xilinx tools and check if the license problem is solved. If this does not help, attach your license file. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
我将许可证文件移动到C: Xilinx并设置路径。
这导致BOTH ISE和PlanAhead无法识别许可证文件。 我把它移回C:。Xilinx,然后ISE再次工作,但PlanAhead仍然没有。 我附上了我的许可证文件,以及“license_info.cache”文件以防它有用。 感谢你的协助。 Xilinx.lic 2 KB license_info.cache 1 KB 以上来自于谷歌翻译 以下为原文 I moved the license file to C:Xilinx and set the path. This caused BOTH ISE and PlanAhead to not recognize a license file. I moved it back to C:.Xilinx, and then ISE worked again, but PlanAhead still did not. I have attached my license file, as well as a "license_info.cache" file just in case it is helpful. Thanks for your assistance. |
嗨,OK。
如果您将许可证文件放在c:/。xilinx文件夹中,该工具将选择许可证(不需要在许可证管理器中设置路径)。您附加的许可证文件是petalinux evauation许可证。 它没有ISE或Planahead功能。 你有webpack许可证吗? 如果是,请附上相同的内容。 否则,您需要从www.xiinx.com/getlicense生成webpack许可证谢谢,Deepika。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Ok. If you put the license file in c:/.xilinx folder, the tool will pick the license ( there is not need to set path in license manager). The license file which you attached is petalinux evauation license. It does not have ISE or Planahead feature. Do you have webpack license? If yes, attach the same. Else you need to generate webpack license from www.xiinx.com/getlicense Thanks, Deepika.Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
我无法再生成许可证。
当我最初获得该软件时,Petalinux许可证是唯一可用的选项。 现在,当我去获得另一个许可证时,表中没有列出产品许可证。 以上来自于谷歌翻译 以下为原文 I can't generate any more licenses. That Petalinux license was the only option available when I originally got the software. Now when I go to get another license, no product licenses are listed in the table. |
的网页。 如果是这种情况,请填写此表单与我们的客户支持部门联系:http://www.xilinx.com/askx/customer_service_form.htm以生成webpack许可证。谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Click on "Manage Licenses" tab in the following webpage: www.xilinx.com/getlicense and look for webpack license. If you have not generated webpack license in the past, you will not find it in the "Manage License" tab of the webpage. If this is the case, contact our customer support by filling this form: http://www.xilinx.com/askx/customer_service_form.htm to generate a webpack license. Thanks-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2444浏览 1评论
658浏览 1评论
520浏览 1评论
2074浏览 0评论
800浏览 0评论
GMT+8, 2025-2-24 00:30 , Processed in 1.585197 second(s), Total 90, Slave 74 queries .
