我刚刚删除/重新安装了两次,我遇到了同样的问题。
一切似乎安装正确。 我甚至重新安装了7-Zip,但同样的事情发生了。 当我运行“ISE Design Suite 14.4”(点击桌面图标)时,我会在几分之一秒内获得一个CMD窗口 - 然后什么都没有。 当我尝试从命令行运行它时: C: Xilinx 14.4 ISE_DS common bin nt64> C: Xilinx 14.4 ISE_DS settings64.bat C: Xilinx 14.4 ISE_DS ISE bin nt64 ise.exe (这是安装期间在桌面上创建的快捷方式的“目标”)。 我只是IMMEDIATLEY获得另一个命令提示 - 没有任何启动或发生。 我似乎获得了有效的WebPack许可。 知道发生了什么事吗??? 以上来自于谷歌翻译 以下为原文 I just removed/reinstalled this twice and I get the same problem. Everything seems to install correctly. I even re-installed with 7-Zip, but same thing happens. When I run "ISE Design Suite 14.4" (clicking desktop icon) I get a CMD window for a fraction of a second - and then nothing. When I try to run it from the command line as such: C:Xilinx14.4ISE_DScommonbinnt64>C:Xilinx14.4ISE_DSsettings64.bat C:Xilinx14.4ISE_DSISEbinnt64ise.exe (This was the "target" of the shortcut created on the desktop during install). I just IMMEDIATLEY get another command prompt - nothing launches or happens. I seem to be licensed for the valid WebPack. Any idea what's going on??? |
10个回答
使用拆分下载分四部分解决的问题......似乎一部分的下载已损坏。
在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Problem resolved using the split download in four parts...seems that download in one part was corrupted. View solution in original post |
同样的问题,我不知道该怎么办......我已经尝试过完全重新安装,但它没有用。
Planahead和Vivado似乎工作正常......但套件中包含的其他程序(ISE IDE,Chipscope,XLMC,EDK无法启动)任何想法??? 谢谢 以上来自于谷歌翻译 以下为原文 Same problem and I don't know what to do...I've tried a complete reinstallation and it didn't work. Planahead and Vivado seems to work OK...but the other programs included in the suite (ISE IDE, Chipscope, XLMC, EDK fails to launch) Any ideas??? Thanks |
有时安装可能已损坏,可能是防病毒软件的原因。
如果您在系统上安装了具有防病毒功能的ISE和其他兼容软件,则可以隔离安装文件。 需要按照以下步骤来解决此问题 禁用所有防病毒软件 卸载ISE 卸载Matlab 安装ISE 问候, 维沙尔 以上来自于谷歌翻译 以下为原文 Sometimes installation may be corrupted and antivirus software may be the cause. If you install ISE and other compatible software with antivirus on your system, then it can quarantine an installation file. Need to follow following steps to solve this issue
我在上次安装ISE之前删除了(不仅禁用了)防病毒软件......我得到了相同的结果(ISE无法启动......)!
我很久以前安装了Matlab 2010b,我从来没有发现过ISE的问题......我最近安装的唯一东西就是Microsoft Express 2012 ......我会尝试取消它并重新安装ISE。 感谢您的回复,vishalm,非常感谢! 以上来自于谷歌翻译 以下为原文 I removed (not only disable) the antivirus before last ISE installation...and I got the same result (ISE fails to launch...)!! I have Matlab 2010b installed from a long time ago and I've never detected a problem with ISE...The only thing that I've installed recently is Microsoft Express 2012...I'll try unistall it and reinstall ISE. Thanks for your reply, vishalm, really appreciated! |
以上来自于谷歌翻译 以下为原文 Problem resolved using the split download in four parts...seems that download in one part was corrupted. |
很高兴知道问题已经解决。
是的,有时会发生。 但是如果要检查下载是否已损坏,则需要将下载文件的校验和值与xilinx网站上的校验和进行比较。 如果它是相同的,那么你的下载是好的或如果没有..这意味着下载不好。 问候, 维沙尔 以上来自于谷歌翻译 以下为原文 Glad to know issue is resolved. Yes, Some times it happens. but if you want to check whether the download was corrupted or not, you need to compare the checksum value of downloaded file with the checksum given at xilinx website. If it is same then your download is good or if not.. it means download was not good. Regards, Vishal |
我对ISE 14.5也有同样的问题。
我安装了webpack但设计工具似乎无法启动。 我删除了matlab但它没有帮助。 甚至检查了单个文件下载的MD5校验和,它完全匹配。 用7zip提取。 我不知道出了什么问题。 请帮助我...因此无法使用我的nexys 3。 以上来自于谷歌翻译 以下为原文 I have the same problem with ISE 14.5. I installed the webpack but the design tools to not seem to start. I removed matlab but it didn't help. Even checked the MD5 checksum of the single file download and it matches perfectly. Used 7zip to extract. I have no idea what is going wrong. Please help me... have been unable to use my nexys 3 due to this. |
这里有一些其他的东西来帮助解决这个问题
打开Xilinx命令shell并从那里运行 %SystemRoot% system32 cmd.exe / k C: Xilinx 14.5 ISE_DS settings64.bat 或开始 - > Xilinx设计工具 - > ISE Design Suite 14.5 - >附件 - > ISE Design Suite 64位命令提示符 从命令提示符运行C: Xilinx 14.5 ISE_DS ISE bin nt64 _pn.exe 通过运行map,par,xinfo等点工具命令来检查它是否是GUI特定问题 在打开工具之前,将CD转到新目录或更改“启动”选项 在_pn.exe上运行Dependency Walker 以上来自于谷歌翻译 以下为原文 Here are some other things to help trouble shoot the issue
如何对下载的文件进行校验和以验证下载是否已损坏?
是否有可以在此文件上运行的实用程序? 在哪里& 怎么样? 谢谢 以上来自于谷歌翻译 以下为原文 How to do the checksum of the downloaded file to verify that the download is not corrupted? Is there an utility to run on this file? where & how? Thx |
HiJitu,
在解压安装文件之前,您可以使用可从http://www.fastsum.com/下载(免费下载)的FastSum检查14.x / Vivado文件存档的MD5校验和值。 然后,您需要将此值与该特定文件的下载网站页面上的值进行比较。 因此,如果MD5校验和值不匹配,则下载过程中会出现损坏,您需要再次正确下载文件,直到MD5 Sum值匹配为止; 请参阅下面的示例,其中我为ISE 14.2(Win)生成了MD5Sum值,并且它与Xilinx下载页面上的MD5和值匹配: 问候, Anatoli Curran, Xilinx威廉希尔官方网站 支持 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hi Jitu, Before you untar the installation files, you can check the MD5 Checksum values of your 14.x/Vivado file archive using the FastSum which can be downloaded (free Download) from http://www.fastsum.com/. Then you need to compare this value with the value on the download website page for that specific file. So, if the MD5 Checksum values don't match, then there was corruption caused duringthe download and you would need to correctly download the file again until the MD5 Sum values are matching; Please see my example below where I’ve generated an MD5Sum value for ISE 14.2 (Win) and it’s matching with MD5 Sum Value on the Xilinx Downloads page: Regards, Anatoli Curran, Xilinx Technical Support Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2509 浏览 7 评论
2879 浏览 4 评论
2336 浏览 9 评论
3429 浏览 0 评论
2515 浏览 15 评论
2609浏览 1评论
669浏览 1评论
533浏览 1评论
820浏览 0评论
GMT+8, 2025-3-5 11:23 , Processed in 1.557031 second(s), Total 92, Slave 77 queries .
