嗨,大家好。
我已经激活了WebPack许可证并且最近下载了Vivado 2013.2。 我使用ZedBoard,因此Webpack许可证支持XC7Z020clg-484设备。 我收到以下警告: 信息:[通用17-78]试图获得许可证:实施警告:[通用17-301]无法获得许可证:实施警告:[Vivado 15-19]警告:未找到“实施”许可证。 如果在实施过程中使用Vivado WebPACK或电路板套件常用的设备锁定许可证,则可以安全地忽略此消息。 所以这可以忽略不计。 接下来的两个有点令人不安: 信息:[共17-78]试图获得许可证:SynthesisWARNING:[Common 17-301]无法获得许可证:综合 信息:[共17-78]试图获得许可证:Internal_bitstream警告:[Common 17-301]无法获得许可证:Internal_bitstream 比特流生成失败。 WebPack许可证和比特流生成是否存在问题? 问候 阿文德 以上来自于谷歌翻译 以下为原文 Hi Every One. I have activated a WebPack license and recently downloaded Vivado 2013.2. I use a ZedBoard so the XC7Z020clg-484 device is supported with the webpack license. I get the following warnings : INFO: [Common 17-78] Attempting to get a license: Implementation WARNING: [Common 17-301] Failed to get a license: Implementation WARNING: [Vivado 15-19] WARNING: No 'Implementation' license found. This message may be safely ignored if a Vivado WebPACK or device-locked license, common for board kits, will be used during implementation. So this can be ignored. The next two however are a bit unsettling : INFO: [Common 17-78] Attempting to get a license: Synthesis WARNING: [Common 17-301] Failed to get a license: Synthesis INFO: [Common 17-78] Attempting to get a license: Internal_bitstream WARNING: [Common 17-301] Failed to get a license: Internal_bitstream The bit stream generation fails. Is there a problem with WebPack License and Bitstream Generation ? Regards Arvind |
3个回答
嗨,
比特流生成过程是否因错误而失败? 你能检查一下日志中是否有错误吗? 内部比特流警告可以忽略。 请查看http://www.xilinx.com/support/answers/57408.html 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, Is the bitstream generation process failing with error? Can you check if there are any errors in the log? The internal bitstream warning can be ignored. Check this http://www.xilinx.com/support/answers/57408.html Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)View solution in original post |
嗨,
比特流生成过程是否因错误而失败? 你能检查一下日志中是否有错误吗? 内部比特流警告可以忽略。 请查看http://www.xilinx.com/support/answers/57408.html 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Is the bitstream generation process failing with error? Can you check if there are any errors in the log? The internal bitstream warning can be ignored. Check this http://www.xilinx.com/support/answers/57408.html Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
嗨,
非常感谢你的回复。 是的,我知道这个问题,因此忽略了警告。 但比特流发生了失败。 好的,现在我重新运行整个设计,它的工作原理。 猜猜新的许可证没有更新到系统或其他东西。 不确定发生了什么。 重启comp有帮助! 奇怪的.. 它解决了任何方式。 谢谢 问候 阿文德 以上来自于谷歌翻译 以下为原文 Hi , Thank you so much for your reply. Yes I knew about the issue and hence ignored the warning. But the bit stream gen failed. Okay now I re ran the entire design and it works. Guess the new licence was not updated into the system or something. Not sure what happened. Restarting the comp helped! Weird.. Any ways its solved. Thank you Regards Arvind |
2539 浏览 7 评论
2892 浏览 4 评论
2345 浏览 9 评论
3443 浏览 0 评论
2527 浏览 15 评论
2778浏览 1评论
683浏览 1评论
546浏览 1评论
838浏览 0评论
GMT+8, 2025-3-20 03:09 , Processed in 1.495352 second(s), Total 78, Slave 62 queries .
