有一天,我能够在Questasim中检索XILINX_AXI_BFM许可证,第二天它失败并且从那时起失败了。
许可证服务器已重置但仍然失败... 有任何想法吗? #BFM Xilinx:Xilinx_AXI_BFM版本2010.100000的许可证成功 然后一天后 #BFM Xilinx:Xilinx_AXI_BFM版本2010.100000的许可证失败 谢谢 蒂姆 以上来自于谷歌翻译 以下为原文 One day I was able to retrieve the XILINX_AXI_BFM license in Questasim, and the next day it fails and has failed since. License servers have been reset and still fails... Any ideas? # BFM Xilinx: License succeeded for Xilinx_AXI_BFM, version 2010.100000 Then one day later # BFM Xilinx: License failed for Xilinx_AXI_BFM, version 2010.100000 Thanks Tim |
3个回答
嗨,
在此处附加xinfo文件以调试问题。 谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Attach your xinfo file here to debug the issue. Thanks -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
看起来我的IT部门最终确信我们拥有该功能,并且它实际上位于另一个位置的服务器上。
它现在在哪里,我们不知道.......感谢您的回应 以上来自于谷歌翻译 以下为原文 Looks like my IT department finally is convinced we have that feature and it WAS actually located on a server in another location. Where it is now, we don't know....... Thanks for the response nonetheless |
嗨,请将您的帖子标记为“接受为解决方案”谢谢
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Mark your post as "Accept as Solution" Thanks-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
2308 浏览 7 评论
2718 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
632浏览 1评论
1684浏览 1评论
444浏览 1评论
201浏览 1评论
653浏览 0评论
GMT+8, 2024-9-21 14:47 , Processed in 1.080964 second(s), Total 49, Slave 44 queries .
