我拥有一台采用ICH10芯片组的英特尔DP45SG主板。
我一直在使用Raid 1卷,并且自从几年前升级到Windows 10以来,我一直在努力获得英特尔快速存储威廉希尔官方网站 应用程序的工作版本。 我可以在Ctrl-I Bios屏幕上看到Raid卷的状态,但我在Windows中看不到任何内容。 多次尝试安装英特尔矩阵存储控制器或英特尔RST的工作版本都失败了。 BIOS表示操作系统将在安装替换驱动器后执行Raid恢复,但如果没有支持的Raid监视器,我无法验证。 操作系统是否需要英特尔工具,或者Windows是否进行了卷影复制? 是否有适用于我的系统的版本? 维基百科上的英特尔Matrix Raid页面(英特尔矩阵RAID - 维基百科)称v12.9.0.1001是“支持ICH10R(RAID模式)的最新版本”。 英特尔下载页面称此版本仅适用于Windows 8。 Windows 10帮助论坛的另一篇文章称用户kbird能够将I1110和WIndows 10用于V11.7.4.1001。 在我花费更多时间从备份和系统恢复中恢复之前,我想看看这里是否有人有幸运行这些版本之一。 我的Raid 1卷都已转换回Non-Raid,在我再次进行Raid之前,我想知道如何继续。 谢谢, 布拉德豪泽尔 以上来自于谷歌翻译 以下为原文 I own an Intel DP45SG motherboard, that uses the ICH10 chipset. I have been using Raid 1 volumes, and since upgrading to Windows 10 several years ago, I have struggled with getting a working version of the Intel Rapid Storage Technology Application. I can see the status of the Raid volumes on the Ctrl-I Bios screen, but I cannot see anything from within Windows. Multiple attempts to install a working version of Intel Matrix Storage Controller or Intel RST have failed. The BIOS says the Operating System will do the Raid recovery after installing a replacement drive, but I have no way to verify that without a supported Raid monitor. Does the OS need the Intel tool, or does Windows do the shadow copy anyway? Is there a version that works with my system? The Intel Matrix Raid page at Wikipedia (Intel Matrix RAID - Wikipedia) says that v12.9.0.1001 is the "Last version to support ICH10R (RAID Mode)". The Intel Download page says this version only works up to Windows 8. Another post at Windows 10 Help Forums says the user kbird was able to use V11.7.4.1001 with ICH10 and WIndows 10. Before I spend any more time recovering from backups and system restores, I wanted to see if anyone here has had any luck getting one of these versions to work. Both of my Raid 1 volumes have been converted back to Non-Raid, and before I go Raid again, I would like to know how to proceed. Thanks, Brad Houser |
4个回答
Windows 10不支持您的硬件。
我找不到你的主板和windows 10的驱动程序: https://downloadcenter.intel.com/download/15251/?product=34683 也许英特尔支持工程师之一会有更好的答案。 文件 以上来自于谷歌翻译 以下为原文 Your hardware is not supported on Windows 10. I could find no drivers for your board and windows 10: https://downloadcenter.intel.com/download/15251/?product=34683 Perhaps one of the Intel support engineers will have a better answer. Doc |
HelloBHouser,我正在跟进您的情况并看到我们没有收到您的回复。有一个版本应该适用于您的设置:https://downloadcenter.intel.com/download/15251/Intel-Rapid
-Storage-Technology-RAID-for-Legacy-Intel-Desktop-Boards?product = 34683但这取决于Windows * 7,al.hilllied你的硬件在Windows 10 *上不受支持且这是正确的,你的硬件确实如此 没有任何驱动程序的Windows 10 *我为任何不便表示歉意。如果您需要更多帮助,请不要犹豫回复.Regards,David V 以上来自于谷歌翻译 以下为原文 Hello BHouser, I am following up with your case and see that we have not heard back from you. There is a version that should work with your setup which is: https://downloadcenter.intel.com/download/15251/Intel-Rapid-Storage-Technology-RAID-for-Legacy-Intel-Desktop-Boards?product=34683 But that would be up to Windows* 7, al.hill mentioned that your hardware is not supported on Windows 10* and that is correct, your hardware does not have any drivers for Windows 10* I apologize for any inconvenience. If you need more assistance do not hesitate to reply. Regards, David V |
jerry1978 发表于 2018-11-29 19:16 谢谢英特尔。 当你说我的主板和Windows 10没有驱动程序时,你的意思是没有英特尔RST应用程序的驱动程序或整体没有RAID驱动程序? 据我所知,通过固件设置,我一直在运行RAID 1配置。 我希望能够在Windows中看到RAID状态,而无需重新启动。 有没有其他方法可以通过操作系统工具查看Windows 10中的卷状态? 我只看到分配给Raid卷的驱动器号。 布拉德 PS:我在英特尔在圣克拉拉工作了22年。 离开2010年。 以上来自于谷歌翻译 以下为原文 Thanks Intel. When you say there are no drivers for my motherboard and Windows 10, do you mean no drivers for the Intel RST application or no RAID drivers overall? I have been running RAID 1 configurations, as far as I can tell, through the firmware setup. I would like to be able to see the RAID status in Windows without having to reboot. Is there any other way to see the volume status in Windows 10 through the OS tools? All I see are the Drive letters assigned to the Raid volumes. Brad PS: I worked at Intel for 22 years in Santa Clara. Left in 2010. |
cd340823 发表于 2018-11-29 19:29 如果从Windows 7升级到Windows 10,则将运行Microsoft“兼容性”驱动程序。 他们让你去,但如果出现任何问题,微软将不会提供任何支持或更新。 更糟糕的是,在某些情况下 - 我相信RST属于这一类 - 如果你升级到一个较新的Windows 10版本(1703,1709或1803;它因情况而异),最终会删除兼容性驱动程序(否) 消息,没有警告,刚刚走了)。 您可以使用传递功能来访问物理驱动器,并(以及其他方面)获取他们的S.M.A.R.T. 状态和属性数据。 这是通过公共存储管理接口(CSMI)完成的,该接口用于在Windows环境中实现对堆栈的访问。 几年前,我发布了支持此功能的DLL的源代码,作为Intel Quiet System Technology(QST)SDK的一部分。 我相信我甚至还提供了一种将其构建为示例实用程序的方法。 如果您感兴趣并且找不到SDK,请发送给我一个即时消息(我想我已经把它带到了某个地方)。 内容S 附: 我以为你的名字听起来很熟悉。 我在英特尔工作了21年(虽然在俄勒冈州)。 我在2015年初退休了。 以上来自于谷歌翻译 以下为原文 If you upgraded from Windows 7 to Windows 10, you will be running on the Microsoft "compatibility" drivers. They get you going, but if anything goes wrong, Microsoft will not provide any support or updates. Worse, in some cases - and I believe that RST falls into this category - if you upgrade to one of the newer Windows 10 releases (1703, 1709 or 1803; it varied from case to case), the compatibility driver eventually gets removed (no message, no warning, just gone). There is a pass-through capability that you can use to access the physical drives and (amongst other things) obtain their S.M.A.R.T. status and attribute data. This is done through the Common Storage Management Interface (CSMI) that was used to implement access to the stack in the Windows environment. Years ago, I published the source code for a DLL that supported this capability as part of the Intel Quiet System Technology (QST) SDK. I believe I even included a way to build it into a sample utility as well. If you are interested and cannot find the SDK, send me an IM (I think I have it squirreled away somewhere). ...S P.S. I thought your name sounded familiar. I was with Intel for 21 years (though in Oregon). I retired at the beginning of 2015. |
GMT+8, 2025-3-5 02:13 , Processed in 0.790971 second(s), Total 100, Slave 84 queries .
