你好,
我在一个只能通过代理设置和身份验证访问互联网的地方。 因此我无法直接访问Ai Devcloud。 我尝试使用各种组合更改为Putty中的代理设置,但它不起作用。 我也尝试过Linux,但它也有同样的问题。 错误 - > Putty致命错误:“服务器意外关闭网络连接”。 以上来自于谷歌翻译 以下为原文 Hello there, I am at a place where I can access the internet only with proxy setting and authentication. Hence I am unable to access the Ai Devcloud directly. I tried to change to proxy settings in Putty with various combinations but it didn't work. I also tried in Linux but it also has the same issue. Error -> Putty fatal error : "Server unexpectedly closed network connection". |
4个回答
嗨,请按照以下步骤和腻子设置进行操作,并告知我们任何进一步的问题:1)下载窗口访问密钥并将其与下载文件夹相同.2)将密钥加载到Pageant.3)打开PuTTY并在“主机名”下
输入:guest@cluster.colfaxresearch.com然后单击“打开”4)当提示将服务器密钥添加到PuTTY的缓存时,选择“是”5)如果一切顺利,您将看到“SSH-2.0-OpenSSH_6.6.1”您 可以关闭这个窗口,你不再需要它了.6)现在再次打开putty并按照屏幕保存设置保存在PuttyScrShtDevCloudAccs.zip.Thanks,Rishabh Kumar Jain PuttyScrShtDevCloudAccs.zip 82.3 K. 以上来自于谷歌翻译 以下为原文 Hi, Please go with following steps and putty settings and let us know for any further concern: 1) Download the window access key and same it to Downloads folder. 2) Load key to Pageant. 3) Open PuTTY and under "Host Name" enter: guest@cluster.colfaxresearch.com Then click "Open" 4) When prompted to add the server key to PuTTY's cache, choose "Yes" 5) If everything goes well, you will see "SSH-2.0-OpenSSH_6.6.1" You can close this window, you don't need it anymore. 6) Now again open putty and get settings saved as per screens in PuttyScrShtDevCloudAccs.zip. Thanks, Rishabh Kumar Jain
jerry1978 发表于 2018-11-29 16:21 嗨Aditya,希望你的问题得到解决。 请确认.Regards,Aswathy 以上来自于谷歌翻译 以下为原文 Hi Aditya, Hope your issue got resolved. Please confirm. Regards, Aswathy |
嗨,我们希望您的问题可能已得到解决。 如果再找到任何问题,请回来。谢谢,Rishabh 以上来自于谷歌翻译 以下为原文 Hi, We expect that your issue may have got resolved. Please come back if find any issue further. Thanks, Rishabh |
感谢您的支持,并对迟到的回复感到抱歉。 是的,当我执行Linux部分时,我的问题得到了解决,因此现在我使用Linux而不是Windows。 以上来自于谷歌翻译 以下为原文 Thanks for the support and sorry for the late reply. Yes my problem was resolved when I did the the Linux part hence now I am using Linux not windows. |
GMT+8, 2025-3-6 14:07 , Processed in 1.054715 second(s), Total 81, Slave 65 queries .
